Sponsored by: Wheel Design
C8 problems
Old Apr 27, 2020 | 11:35 PM
  #161
bfrie1's Avatar
bfrie1
same hear, hope to have one before too long
Old Apr 28, 2020 | 01:40 AM
  #162
tdrake2020's Avatar
tdrake2020
Originally Posted by Bobbyc99
Don’t know how I missed this clumped up paint at driver side headlight.
As best I can tell the paint is lifting from the panel edge without chipping. If this is true the paint must be relatively soft/flexible. A long time ago I had a red Miata which was painted using a urethane paint. You could actually take your fingernail and scrape the paint off. Does the C8 use a urethane paint?
Old Apr 28, 2020 | 05:31 AM
  #163
Bobbyc99's Avatar
Bobbyc99
Cruising
I won’t do that dealer would just say it was a rock chip. To your question I’m not sure.
Old Apr 29, 2020 | 08:56 PM
  #164
joshp14's Avatar
joshp14
Be aware that the engine and transmission on the C8 are on an exchange only basis for new product monitoring. If your C8 has a problem with either of these components, be aware that engineering may request the entire assembly back for tear down and examination.
A couple C8 Specific service bulletins issued so far:
#20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set - (Mar 9, 2020)
Subject: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set 
Involved Region or Country
North America, Middle East
Condition
Some customers may comment on one or more of the following conditions:
  • Fuel gauge intermittently displays erratic and/or empty readings
  • MIL illuminated
Some technicians may find DTC P0462 (Fuel Level Sensor 1 Circuit Low Voltage) displayed in the Engine Control Module (ECM).
Cause
This condition may be caused by erratic fuel value readings sent from the left fuel tank level sensor.
Correction
If the customer concern has been verified, replace the left side fuel tank level sensor.
#20-NA-091: Information on Power Seat, Power Mirrors and Steering Wheel Entry/Exit Memory Recall Settings Intermittently Inoperative - (Apr 16, 2020)
Subject: Information on Power Seat, Power Mirrors and Steering Wheel Entry/Exit Memory Recall Settings Intermittently InoperativeInvolved Region or Country
North America, Middle East, Europe, GM Korea Company, China
Condition
Some customers may comment that during entry or exit from the vehicle, they notice that the seat, steering wheel and mirrors do not move to the saved entry/exit position. The concern may be intermittent.
Cause
The cause of the condition may be a software anomaly.
Correction
If the seat, steering wheel and mirrors do not automatically move to saved position, the customer can move them by pushing the memory seat button on the door.
Please share this information with the customer, including a copy of this bulletin.
Old Apr 30, 2020 | 09:05 AM
  #165
C8J's Avatar
C8J
Default #20-NA-042: Fuel Gauge
Apparently, unlike many here, I don't have a Mahal. I don't know if it is the same issue, but unfortunately many auto manufacturers "reuse" parts from year to year and model to model. The only thing that changes is a digit in the part number and add a zero or two to the price. Lincoln vs Mercury. Chevy vs GM .... I love my 2016 Malibu, but it has had a host of electronic wizardry that is atrocious, but fortunately all were fixed (replaced) under warranty.
The latest are the brake anti-slip light coming on at random and then disappearing after 3-5 drives (restarts) and now the Fuel gauge problem mentioned here. BTW, Malibu is garaged (until C8 arrives) and only 2 years old so the rotors are not flaking with rust .... AND now the fuel gauge problem mentioned here. Again a few dives and GONE.... so far only 1 time.
The picture of the C8 driver door mirror button panel (blue) is identical to my Malibu (grey). I'm sure this part is 1/4 of the C8 price at my Chevy or Gm dealership. Picture is from the convertible reveal at KSC last year! Hope its not the only one for 2020. It almost made me spend the extra $7500, but I personally like the lines and glass engine "hood" of the coupe better. That's why they make vanilla and chocolate ice cream before anyone takes issue with coupe vs convertible - BOTH are C8s!.
Old May 1, 2020 | 10:10 PM
  #166
sainthoo's Avatar
sainthoo
Got a “recall” notice today- they want to check my car to make sure this isn’t a problem.
Old May 1, 2020 | 11:04 PM
  #167
srosenbldr's Avatar
srosenbldr
Default Trouble code on transmission
Transmission would not go into gear shortly after startup. Check engine light came on. Trouble code said transmission not communicating. I hope there is a quick fix.
Old May 2, 2020 | 01:54 AM
  #168
Shaheen Javadizadeh's Avatar
Shaheen Javadizadeh
Leaking CV joint under 2,000 miles.
Thin base coat on rear cap, making the black fade to brown then black again.
Old May 2, 2020 | 09:17 AM
  #169
cstraley's Avatar
cstraley
Default small bug
In the interests of improving the excellent C8 I have noticed that the PDR keeps forgetting it has a memory card and my usb stick with my music it also forgets it has... I unplug and replug and they work fine but every 3 or 4 starts this happens. I hope a software update will address this annoyance.
Old May 2, 2020 | 03:15 PM
  #170
Ed Biancarelli's Avatar
Ed Biancarelli
i have found that using newer USB sticks/ SD cards solved the problem for me for my music flash drive and sd card (speed class 10) for PDR.
Old May 6, 2020 | 01:53 PM
  #171
24/Eray's Avatar
24/Eray
Here's a CMG with the paint lifting by the headlight/fender. Rubbing.
I mentioned this before but was waiting for my buddy the detailer to grab a pic of it. This owner doesn't care about it. He's putting about 25k in performance mods into it.
Old May 6, 2020 | 05:46 PM
  #172
RapidC84B's Avatar
RapidC84B
So long as it was that one area it wouldn't kill me... professional touch up and move on. If it propagated and started to peel like a 90s Dodge product.... then we'd have a serious issue.
Old May 6, 2020 | 09:16 PM
  #173
C2 legacy's Avatar
C2 legacy
So is this a fitment issue (headlight rubs fender) and not a paint run or over-spray problem?
Old May 6, 2020 | 09:41 PM
  #174
24/Eray's Avatar
24/Eray
What it is is ridiculous. That's what it is. The panels expand and contract quite a bit. The headlight doesn't. So when the tolerances are ultra tight? You risk this probably at assembly. I bet a micro fraction left or right with that headlight mounting AND your rubbing panels. And then they expand and contract and eventually paint lifts.
Many including myself chalked it up to adhesion but how much adhesion is enough in an area that rubs like that against something else that isnt flexible?
I like the adhesion argument better on C7 issues but even then it was always where the panels met. It has to be the composite panels.
Old May 6, 2020 | 09:48 PM
  #175
RapidC84B's Avatar
RapidC84B
Adhesion issue... properly stuck paint will just rub dull, not start to peel away.
Old May 6, 2020 | 10:37 PM
  #176
PorscheNut's Avatar
PorscheNut
People have to realize that a Corvette isn't a Porsche or a Ferrari or even a Honda when it comes to fit and finish. It is, however a fantastic performance bargain. I am 70 years old and have never owned an American car. I have a 2020 HTC on order and I am totally excited to get it. The C8 is probably the best American sports car ever, but it's not a Porsche.
Old May 7, 2020 | 12:58 AM
  #177
kratedisease's Avatar
kratedisease
Just want to point out that you are in the wrong area posting this........ this is the "problems" thread....
These pictures should be filed under the "issues" thread ......
The paint peeling is an ISSUE, and surely not a problem.
To C8 problems
Old May 7, 2020 | 01:15 AM
  #178
tdrake2020's Avatar
tdrake2020
A question of semantics... In the golden, olden days prior to political correctness we didn't have issues. We had problems. I think that peeling paint falls under the "Problem" category.
Your peeling paint isn't a problem, but my peeling paint IS a problem. Kind of like the difference between a recession and a depression. When you lose your job it's called a recession. When I lose my job it's called a depression.
Old May 7, 2020 | 12:12 PM
  #179
Midnighyt's Avatar
Midnighyt
Driver side door window failure.
Today I started my car (636 miles) in the garage, and rolled down the drivers side window with the door closed and at the last 10% left to go down, it dropped harshly into the door. It hesitated to roll back up with lots of nasty grinding. Once it reached the top, it wouldn't roll down again. The dash then displayed. "roll window down and up again" so I guess a sensor wasn't getting the data it needed. I drove to the dealer about 30 miles away and while on the highway the window started to fall down into the door. When it was down about 50% I was able to lift it by hand and let the motor catch it and bring it back up to a full close, I heard lots of grinding and possible broken glass. Dropped it off at the dealer, the window wouldn't roll down, but you could push it down after the motor cranked a bit, yet more grinding, pulled on it and let the motor lift it back up... the sensor does not detect if the window is fully up and the dealer attempted to shut the door when it was fully up... OOF big clunk off my roof top panel... No damage tho
Awaiting a call from the dealer after they get into the door and determine the issue. I will post a follow up
Old May 7, 2020 | 12:53 PM
  #180
RapidC84B's Avatar
RapidC84B
Awaiting a call from the dealer after the get into the door and determine the issue. I will post a follow up
Sounds like the window lift clamps came loose.
