Sponsored by: Wheel Design
Soler Control
Old May 11, 2023 | 07:39 PM
  #41
faninc's Avatar
faninc
Banned Scam/Spammer
Default Try Sport 8! Lol
Or Ludicrous mode!
Old May 11, 2023 | 08:01 PM
  #42
Broken Halo's Avatar
Broken Halo
'Drag Race' would be the wildest!
Old May 11, 2023 | 08:21 PM
  #43
faninc's Avatar
faninc
Banned Scam/Spammer
Default No break in required.
The controller and the car break in are unrelated. The C8 is programmed to prevent higher rpm’s until after 500 miles then releases automatically . The controller is simply calibrating the gas pedal to the throttle body in the car. Any efforts to over accelerate are protected by the factory software GM installs whether you have this device or not .hope that helps. I asked all these questions prior to buying mine👍🏻
Old May 11, 2023 | 08:34 PM
  #44
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
The C8 does NOT prevent higher rpm's before 500 miles, it just displays a lower redline on the tachometer. Attempts to over accelerate are prevented by the rev limiter which prevents rpms over 6500. The amount of torque the C8 produces in lower gears is reduced for the first 500 miles. You are correct, though, that this device doesn't alter the protections/controls in place in the factory software.
You can think of it this way: all the throttle controller does is lie to the ECU about how far your foot has the gas pedal pressed down.
Old May 11, 2023 | 08:42 PM
  #45
faninc's Avatar
faninc
Banned Scam/Spammer
Default Thanks for clarifying
The install of the device does not alter the break in was the main point was trying to express. Thanks for tech clarification.
Old May 11, 2023 | 08:56 PM
  #46
SMOKN C8's Avatar
SMOKN C8
It's not letting me use the DLXVETTE code
Old May 11, 2023 | 08:59 PM
  #47
MarkMeHopeful
I just used it earlier today. Entered it in the shipping information. Entered the RWDC8 in the other box that says promo code.
  #48
faninc's Avatar
faninc
Banned Scam/Spammer
Default Do this
You need to enter your email address at checkout first, then enter the discount code DLXVETTE and must select USPSas shipping option
let us know if that solves it should.
Old May 11, 2023 | 09:23 PM
  #49
Broken Halo
You can also enter 'TENOFF' in the discount code box for 10% off which will give you a savings of $20.
Old May 11, 2023 | 09:26 PM
  #50
SMOKN C8's Avatar
SMOKN C8
I got it. Ordered.
Old May 12, 2023 | 12:14 AM
  #51
faninc's Avatar
faninc
Banned Scam/Spammer
Default Double savings
Hi, for double savings try using code ZERO60 in the Discount box and DLXVETTE in the other box at checkout. You first must type your email during checkout for the above savings to activate. Enjoy the controller like many of us now are👍🏻👍🏻👍🏻
Old May 12, 2023 | 01:05 AM
  #52
eazyg's Avatar
eazyg
Shoot, I ordered one earlier today and paid $207 and added over night shipping because this thread has got me so damned excited to git it a try. And I need a weekend project to work on.
Old May 12, 2023 | 08:02 PM
  #53
MarkMeHopeful
My controller is on the way - supposed to arrive Monday. It just occurred to me that the controller also works when you have the car in reverse. Anyone notice any negative effects when in reverse?
Old May 12, 2023 | 09:01 PM
  #54
tadda's Avatar
tadda
Veteran: Marine Corps
None...
Old May 12, 2023 | 09:16 PM
  #55
Red Mist Rulz's Avatar
Red Mist Rulz
if you set it to Sport 10, or Ludicrous, you'll find it hard to modulate the throttle. In Sport 4, where I normally drive, smooth starts aren't a problem in first or reverse.
Old May 12, 2023 | 10:28 PM
  #56
RMS73's Avatar
RMS73
Where do you mount the input controller? On my C7 I put it in the console. Thinking about not using the controller input device and just using the bluetooth with my PCD.
Old May 12, 2023 | 10:43 PM
  #57
tadda's Avatar
tadda
I didn't mount mine at all... After the setup was completed, I disconnected the controller input display unit and stowed it away in the center console...If I choose to change the settings, I now use the Soler App I downloaded on to my phone...
As for the controller module and long cable.. I placed the module and coiled up the long control cable under the carpet behind the accelerator pedal...A very stealth setup!
To Soler Control
Old May 13, 2023 | 03:20 AM
  #58
Mitchell_B's Avatar
Mitchell_B
I use the Soler on my Z06. I did a sweep of the pedal from closed to WOT while looking at the data on my scanner and there was a point - in any mode I chose where the commanded throttle percent dropped and then pick up again. At comfort level one, for example, the throttle percent went smoothy to about 65 percent, then dropped to about 55 percent and then went smoothly again to 100% on a continuous smooth pedal sweep. It did this from day one. I'm going to shoot an email to Mike at Soler Engineering about this. I'll see what he says.....
Old May 13, 2023 | 12:39 PM
  #59
Red Mist Rulz
I just use my phone. The controller's in the glove compartment in case I need it, but haven't used it since the initial setup.
Old May 13, 2023 | 12:41 PM
  #60
Red Mist Rulz
I haven't noticed any similar behavior in my Stingray. I don't have a scanner, but I think I'd feel a drop like that. Will be interested to see what Mike says, and if it's unique to the Z06.
