Sponsored by: Wheel Design
Soler Control
Old May 17, 2023 | 03:10 PM
  #81
tadda's Avatar
tadda
Veteran: Marine Corps
Originally Posted by MarkMeHopeful
I've seen here and in the instructions about the 10 minute wait and other cautions about the electrical system. I'm going to be installing mine as part of some other work. Is there any reason not to just disconnect the battery until the mechanical installation is finished and not worry about generating a CEL?
I wasn't sure that my memory settings would be wiped if I disconnected the battery and didn't want to go through the hassle of reprogramming all my settings...I also haven't heard of anyone having issues with a CEL after install...
Old May 17, 2023 | 03:26 PM
  #82
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Thanks, it just worries me when instructions talk about electrical errors. As far as losing memory settings, you won't. I've had my battery disconnected many times for various reasons. The worst that happens is that you have to re-index the windows.
Old May 17, 2023 | 05:57 PM
  #83
DHDCF's Avatar
DHDCF
if it helps any, the total time to install the soler is about 15 mins.
Old May 17, 2023 | 09:41 PM
  #84
Red Mist Rulz's Avatar
Red Mist Rulz
I think that would be fine, but I had no issues installing mine with the battery connected, and haven't seen anyone else post about a problem. I installed one in a friend's car, too, and again no issue with the battery connected. Once you have it physically connected you'll have to reconnect the battery in order to pair it with your phone, of course.
Old May 17, 2023 | 10:21 PM
  #85
Mitchell_B's Avatar
Mitchell_B
I actually got a check engine light when I did the install. It was something like throttle pedal sensor input voltage high. I think this is a non latching code which should clear before long. I cleared this using a scanner.
Old May 18, 2023 | 02:31 PM
  #86
SMOKN C8's Avatar
SMOKN C8
Mine came in today. I did all that Yoga for nothing as it was stupid simple, no twisting or contorting. It actually took more time to wait the 10 minutes than the actual install; which I would say was all of 6-7 minutes. No check engine light.....
Love the phone app, left all the cable rolled up the way it came out of the box and stuff it all behind the carpet which makes it totally hidden.
So far I just went right to Sport 4 and HOLY #$^% what a difference!!!! I know the car is the same HP as it was 20 minutes earlier but it sure feels so much faster. So much better response from stock.
Will play with other modes later.
If you're on the fence, jump off and go for it...you will NOT be sorry.
Old May 18, 2023 | 03:01 PM
  #87
Red Mist Rulz
One thought to all the Soler owners:
Before taking the car back to the dealer, use the phone app or display to reset the throttle to OEM. Don't want the car jockey at the dealer digging into the throttle and not being ready for the extra acceleration.
Old May 18, 2023 | 03:14 PM
  #88
Broken Halo's Avatar
Broken Halo
I spoke to Mike at Soler about that and he said when you set it back to O.E.M. it would not leave any tell tale trace of ever being installed. Not that I don't trust his knowledge, but it will give me peace of mind to remove it completely just on the off chance the mechanic finds the controller and voids my warranty. As everyone agrees, it's not that big a deal to R&R.
Old May 20, 2023 | 08:33 PM
  #89
2024VETT's Avatar
2024VETT
WAIT… WHAT.
Adding this will void my warranty?
Old May 20, 2023 | 09:14 PM
  #90
tadda's Avatar
tadda
Originally Posted by 2024VETT
WAIT… WHAT.
Old May 20, 2023 | 09:39 PM
  #91
Red Mist Rulz
WAIT… WHAT.
Not unless it causes a problem with something else, which is highly unlikely. Some people are just paranoid.
Old May 20, 2023 | 11:37 PM
  #92
SMOKN C8's Avatar
SMOKN C8
100%. The odds of the controller causing a warranty related issue have to be near zero. It's not changing anything other than x% input = y% output.
Old May 21, 2023 | 11:41 AM
  #93
Peaven's Avatar
Peaven
St. Jude Donor '15
This will be my next mod/add but they are currently sold out, so I'll patiently wait for them to re-stock.
Old May 21, 2023 | 11:50 AM
  #94
Broken Halo
I might be selling mine. Waiting to hear back from Soler if it will work on my ZO6 coming soon. If not, it will be up for grabs.
Old May 23, 2023 | 09:29 PM
  #95
MarkMeHopeful
I just got around to installing mine. It was incredibly easy, even for an old guy. Once I unbolted the gas pedal I could twist it around and actually see the connector as I worked it. The cables tucked in under the carpet and I didn't mount the display at all (I'm just using my phone). No way anyone could tell it's there. Thanks to all here for the advice/instructions.
I only drove around for a few minutes to test that changing the settings actually works. What a difference! I'll probably keep mine in the higher comfort modes to lower sport modes to start until I have more time to play.
Old May 23, 2023 | 09:31 PM
  #96
SMOKN C8's Avatar
SMOKN C8
I’ve been in sport 4 since I installed it. Going to try 5 & 6 for a few days
Old May 23, 2023 | 09:33 PM
  #97
faninc's Avatar
faninc
Banned Scam/Spammer
Default Congrats on install!
$200 best mod I ever did !! Hope enjoying free shipping with code DLXVETTE at checkout, just make sure you enter your email at checkout first for free shipping code to activate.
No void warranty either! Unleashes our C8 for sure!
To Soler Control
  #98
tadda's Avatar
tadda
Still running Sport 4... That's my sweet spot and I'm sticking with it!
Old May 23, 2023 | 09:44 PM
  #99
faninc's Avatar
faninc
Banned Scam/Spammer
Default Sport 6 here!
Fun fun! Smile on my face every acceleration!
Old May 24, 2023 | 06:50 AM
  #100
Broken Halo
I'm waiting to hear back from Mike at Soler. I'm going to be REALLY disappointed if he tells me it won't work in my ZO6!
