C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
LT6 engine failures/problems
Old Feb 8, 2024 | 09:59 PM
  #341
70thAnnvGuy's Avatar
70thAnnvGuy
Egoncool,
New to forum, not to high performance cars and driving. Not in my case! Any help would be greatly appreciated.
Old Mar 31, 2024 | 06:33 PM
  #342
smitty1966's Avatar
smitty1966
My C6 LS7 started huffing a little blue smoke out driver side on startup at 36,000 miles. When we pulled heads found 2 exhaust valves on that side were very, very loose in the guides. Took them to a shop that specialized in LS heads and they confirmed this was a common problem (given the low production numbers of the engine), they had repaired a bunch of them. They had found brand new Z/28 LS7 heads on engines they were modifying with incorrectly machined exhaust valve guides. Most LS7 had no issues, but some ended up with incorrectly machined heads from the contractor in Canada. Chevy/GM fumbled this problem.
Old Mar 31, 2024 | 07:17 PM
  #343
smajicek's Avatar
smajicek
Smitty1966, I believe this thread was specifically created just for the LT6 motor which is in the new 2023 Z06, why you are posting about C6 when this is about C8 gen corvette. If I am wrong I apologias..
Old Apr 4, 2024 | 03:15 PM
  #344
GatorsJMC's Avatar
GatorsJMC
Originally Posted by Teslarosa
Good points. The dealer and others I talked to also reported that some ticking or tapping sounds are normal on these engines; so probably just being paranoid on my end. Will schedule the picoscan TSB after the winter. Thank you!
Did you get the pico scan done?
Old Apr 16, 2024 | 02:15 PM
  #345
cajunboyz's Avatar
cajunboyz
From: South Lousiana (Cajun Boys with Bad ASS Toys)
Interesting topic
Old Apr 17, 2024 | 11:25 AM
  #346
GatorsJMC's Avatar
GatorsJMC
Teslarosa is not following up here. Hope his issue was resolved.
Just to reiterate, my '24 LT 6 was producing a loud ticking noise, apparently from a cam follower, hot or cold, coming from the drivers side bank of cylinders/ cams. The pico scan confirmed this graphically and the TSB was performed at the Daytona, Fl dealership (I took a museum delivery).
Results were a reduction of approx 60-70% in tapping intensity to my older ears. After repair pico scan showed improvement. Without getting pissy and complaining more about it and demanding a new engine, it seems like an acceptable fix to me after putting on another 400+ miles. LT 6's do make noise, different from pushrod engines. Actually a bit of sewing machine noise I dare say . But again, my older ears are to blame here for any inaccuracies!
YRMV
Old Apr 19, 2024 | 10:28 PM
  #347
sandcracker21's Avatar
sandcracker21
Have had my 24 HTC for two weeks now and just passed the 500 mile break in. No problems at all and no "ticking" noise. Fingers crossed!
Old Apr 24, 2024 | 12:11 PM
  #348
Preshenne's Avatar
Preshenne
Default New Z06 LT6 Engine Run
Have New Z06 waiting at the dealers. Asked for engine run recording. I am not skilled in the dreaded "LT6 Ticking" noise. How does this one sound?
Old Apr 24, 2024 | 01:15 PM
  #349
GatorsJMC's Avatar
GatorsJMC
Don't notice any from your posted clip. Have to get the exhaust note as quiet as possible...
Quite a noticeable ticking noise you can easily hear from either of the rear wheel wells. GM's pico scan is an audio print out of engine "noises". Look for sharp, repetitive amplitudes on the graph. That's what will trigger the TSB routine be undertaken.
Mine didn't appear until 600-700 miles after the drive home from a museum dilevry..
Old Apr 28, 2024 | 12:57 PM
  #350
smajicek's Avatar
smajicek
Sounds normal to me. Mine is HTC so it makes it harder to hear if I did have ticking
Old Apr 29, 2024 | 02:59 PM
  #351
jkirsc1's Avatar
jkirsc1
Nda
Old Apr 29, 2024 | 03:01 PM
  #352
RapidC84B's Avatar
RapidC84B
What parts are needed for the camshaft TSB? It's just backing off the bolts and retightening to spec.
Old Apr 29, 2024 | 03:11 PM
  #353
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Does anyone have a clip of what the abnormal tick sounds like?
Old Apr 29, 2024 | 03:13 PM
  #354
jkirsc1's Avatar
jkirsc1
Nda
Old Apr 29, 2024 | 10:45 PM
  #355
GatorsJMC's Avatar
GatorsJMC
Had to wait approx 10 days for parts when the TSB was done. Bolts, seals, gaskets...
Old Apr 30, 2024 | 10:08 AM
  #356
RapidC84B's Avatar
RapidC84B
Interesting... I wonder if it depends on if the engine has to be dropped or not. The cam cover gasket is reusable and the video I watched online they literally just back off the bolt and retighten it.
Old Apr 30, 2024 | 04:21 PM
  #357
GatorsJMC's Avatar
GatorsJMC
Come to think- bolts were not replaced. Seals were the back order item. Left bank only was done...
To LT6 engine failures/problems
Old Apr 30, 2024 | 04:38 PM
  #358
Brandon's Z's Avatar
Brandon's Z
The first C8 where having problems with the transmissions and now the new hot rods are having problems with the engine. Grr GM get your act together! I am the old man that likes the old cars. They didn't break (as often) and when they did it didn't take two weeks for a record time repair.
I can't wait for the new ZR-1. I hope someone wants me to take it for a spin. Although, I hope I don't spin it! Thanks for sharing???
Old Apr 30, 2024 | 05:09 PM
  #359
GatorsJMC's Avatar
GatorsJMC
I seem to remember different C-series all having their respective teething issues.
C 8's are no exception, but definitely more complex!
Old Apr 30, 2024 | 05:16 PM
  #360
Brandon's Z
I love all Corvettes and especially the C4 ZR-1. GM did an excellent job of testing the LT5 before it went into the new Z. Ford and GM use to do actual endurance testing with engine builders and drivers. Now we leave to the brilliant AI. Just a sign of the times. 180K price for a new hot rod and the engine blow. I hope GM gets in front of this. It been going to long. I hope to drive a ZR-1 soon!
