LT6 engine failures/problems
But I mean he does go over in this video how consumable costs make the porky Z06 twice as expensive to track vs his 600LT, so it’s not all sunshine and rainbows.
If I were one of the owners with legitimate issues, I'd be all up in his social spaces putting him on blast.
I disagree, we have had multiple cars that we track and literally have built several all out drag cars. The "Best way" would be to get a warming pad and plug the vehicle in and set the temp to about 100-120 as this will evaporate any moisture in the oil without cooking it and have the oil thinner for an easier start up to let the vehicle get to temp. Again there are many ways to peel an orange, I've peeled plenty my way without having to take a car back for any issues or engine problems till date besides the race cars that actually got hurt do to me pushing the limits at the track. But hey I am just a girl What do I know.
I presumed you were driving street cars on the street. Even the manufacturers of our high performance cars recommend starting them up and driving modestly right off and not to let them sit and idle to warm up.
Gender had nothing to do with my comment. The car doesn't care either.
In my opinion allowing the lubricant to warm these days in these cars is a bit overblown.
Synthetic lubricants flow well all the way down to very low temperatures well below zero.
So at anything much above freezing the lubricant can flow and protect just fine AND it can flow freely enough not to cause excessive oil pressure or component oil starvation by being "to thick and slow flowing" at start up.
Point is, what are we attempting to prevent by allowing the fluid to warm up?
Once you actually answer this question you will know any decent synthetic lubricant at any temperature above freezing will flow fast enough and freely enough to protect the components and not create excessive oil pressure within 30 seconds of start up.
So If you are talking 120* fluid temperature and above with a synthetic lubricant you really have nothing to worry about.
One of the main advantages of synthetic is to extend the middle protection range (stabilize viscosity) of the lubricant allowing it to flow freely at very high temps and very low temps.
Don't fool yourself you aren't waiting on synthetic to do anything. For most occasions we encounter it always ready.
That all being said it doesn't hurt to let things warm up a bit when its really cold out (below freezing).
https://www.caranddriver.com/researc...synthetic-oil/
