Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
A push for the 8's
Old May 24, 2010 | 10:34 PM
  #81
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Originally Posted by 4DRUSH
Fri. Nov 5
Sat & Sun is the World Cup Finals (Import vs. Domestic)
My calender is clear for the whole weekend.
See you there.
Old May 24, 2010 | 11:01 PM
  #82
Fartpipe's Avatar
Fartpipe
I can't do that weekend I have to wax my tailpipes. Anyway we can arrange this on another day?
  #83
4DRUSH's Avatar
4DRUSH
Originally Posted by GARY2004Z06
I'm glad you stepped up this year to run one of these events.
Thanks.
No problem, but I think we lucked out last year getting the whole track to our selves the day before a big event.
I'll call Jason at MIR and get the scoop.
Old May 24, 2010 | 11:16 PM
  #84
GARY2004Z06's Avatar
GARY2004Z06
Cool.
It was nice to have it to ourselves.
Old May 25, 2010 | 02:20 AM
  #85
PRE-Z06's Avatar
PRE-Z06
Originally Posted by robz
Update: The plan is in motion. I'm hoping the car will be ready to take some passes in about 8-10 weeks. Alot to do and test. Hope everything actually works.
Good to hear, just curious if anyone has ever gone 8's on a 255DR?
Old May 25, 2010 | 03:39 AM
  #86
LS1LT1's Avatar
LS1LT1
Originally Posted by algZO6
hey rob, do you have a 10 point in it yet?
Forget that junk, those useless things just add unnecessary weight to the car LOL, hell if it were me I'd even pull out the damn 6 point to save even more weight as well.
I don't think so, I believe a couple people might've gone high 8s on 16" (or even 17"?) drag radials but I don't think any used tires that narrow (255).
Don't quote me but as far as I know only Robz, Mike Rumain and Sonnie ('uniqueC5') have even gone 9.3s on a 255 with Sonnie as the only one to go 9.2s on them.
Going to 15s is likely going to be a better move at that level but with the right track prep and suspension I'm betting that it (ie: 8s on a 255-50-16 tire) can be done.
Old May 25, 2010 | 11:47 AM
  #87
robz's Avatar
robz
Originally Posted by GeorgeZNJ
Rob, good luck in the quest for 8's. Don't forget to push the reset button
haha
Old May 25, 2010 | 11:50 AM
  #88
robz's Avatar
robz
Jay, thanks again for organizing MIR-2. Friday sounds great.
Old May 25, 2010 | 01:34 PM
  #89
24hr Z06's Avatar
24hr Z06
good luck Rob, im sure you'll be able to accomplish this goal as you have all your others... certainly looking forward to reading about it...
Ok fellas, after crunching the numbers, I've decided to give it a shot; just this year and then I'm done.
My goals will be:
-run an 8.9x
-trap 150mph
-cut a 1.2x 60'
all with under 400ci's (n/a) and a 6 speed on a small drag radial... and drive home.
I basically need to find about .2-.25 from my current setup.
According to my math it is possible but everything must come together. I have several things I'm working on between now and September when I'll start making "all out" passes.
My general setup will not change.
If $ becomes an issue I will abort the mission and have fun running a local 10.50 index.
That's my story.
Old May 25, 2010 | 08:32 PM
  #90
YeloFevr's Avatar
YeloFevr
Stephen Hawking figured out intergalactic travel with his tongue. I'm going to go out on a limb and say that this car will go 8's.
Old Jun 21, 2010 | 06:56 PM
  #91
robz's Avatar
robz
Thanks John. I set the goals high this time. Lowering et .25 may require 80-100rwhp.
I'll be happy if I get close. I think the 150mph will be the most attainable yet least important to me.
I'm looking for someone to do some custom carbon fiber work preferrably local if anyone has a contact.
Old Aug 10, 2010 | 01:53 PM
  #92
robz's Avatar
robz
Got some initial dyno numbers. Car made 633/506 on the mustang dyno we use with 4.10 gears. It looks like I gained about 20-25 rwhp from previous. I'm happy with the hp curve as it stays above 605 rwhp @ 9000rpms.
We plan on dyno'ing next with a custom air intake system we fabricated which should pick up a little more on the dyno and alot more on the strip. I think I need to find another 50rwhp which is possible but hard to capture.
I'm also confident that the ability to shift higher where I need to be will net about .1.
Old Aug 10, 2010 | 03:12 PM
  #93
pit-man's Avatar
pit-man
You and Fartpipe need to be brought under control ! This is getting crazy
Old Aug 10, 2010 | 04:04 PM
  #94
98vettedave's Avatar
98vettedave
Do you have a date selected for the initial shake down runs? It sounds like all things are still on a positive note and the goal is definitely in sight.
Old Aug 10, 2010 | 04:19 PM
  #95
WKMCD's Avatar
WKMCD
Ones making power and FP's making pretty...
Rob,
Can you outline the build again?
Thanks,
Kevin
Old Aug 10, 2010 | 04:39 PM
  #96
pit-man's Avatar
pit-man
Originally Posted by WKMCD
Ones making Power and FP's making noise...
Rob,
Thanks,
Kevin
I fixed it for you Kevin !!!
Old Aug 10, 2010 | 04:55 PM
  #97
robz's Avatar
robz
I'm gonna try creeping up on it so I'll probably try and take some hard passes in about 3-4 weeks and lift so I don't **** off the track. Need to figure out the clutch and suspension, I feel like I'm starting over.
But i also don't have alot of passes to beat up on the car so I won't buzz it until the air is just right.
8500 all day. 9000+ when/if it's all dialed in and the weather cooperates.
To A push for the 8's
Old Aug 10, 2010 | 05:36 PM
  #98
robz's Avatar
robz
Rob,
Thanks,
Kevin
388ci (ls7 gm block with ls1 style crank) built by my buddy Mike Tiedemann
tfs 245 heads (recently ported for my setup)
custom roller cam
American Racing Headers(2")
ITB manifold (recently ported to match)
Jesel valvetrain
Drag radial
We have it idling @850 and drove it home from the dyno. Car runs great on the street.
Old Aug 10, 2010 | 05:47 PM
  #99
LS1LT1's Avatar
LS1LT1
9000!
Old Aug 10, 2010 | 06:25 PM
  #100
USAFZ06's Avatar
USAFZ06
Rob what did you do for a computer?
