Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
September 16th
Old Sep 12, 2011 | 09:15 PM
  #181
simpleman68's Avatar
simpleman68
Originally Posted by legman
Scott, I might have the slowest sled, but it'll be from the smoked ribs....
No worries brutha, I'll probably be the 2nd or 3rd slowest.
Will be a good time though.
Scott
Old Sep 12, 2011 | 10:54 PM
  #182
Tsab's Avatar
Tsab
Right now the weather looking real good. 63 for the high and 51 for the low with bright sunshine. Which means good track temps and pretty good IAT's. Should be a good day if the weather report is accurate.
Old Sep 13, 2011 | 07:49 AM
  #183
DropTheTop's Avatar
DropTheTop
. . . Scott, I might have the slowest sled, but it'll be from the smoked ribs....
Don't worry, my car will definitely be slowest - but I'm just going for a good time.
I hope the forecast holds true!
Old Sep 13, 2011 | 10:48 AM
  #184
robz's Avatar
robz
See you @ 1:00pm
Old Sep 13, 2011 | 12:31 PM
  #185
simpleman68
Originally Posted by robz
See you @ 1:00pm
Scott
Old Sep 13, 2011 | 12:47 PM
  #186
LS1LT1's Avatar
LS1LT1
See you @ 1:00pm
So true LOL.
Sorry Tom.
Old Sep 13, 2011 | 02:50 PM
  #187
digivex's Avatar
digivex
I like that weather report too.
We've done a few track rentals from 2008 through 2010 (NHRA Licensed in '10), all on a 346 LS6. Now, with some tire and suspension tweaking, we'll see if the new forged 402 LS2 can pull a rabbit out of the hat for us and add another run to the ending of this video... with a little better number in the final sequence. This vid gets quicker as the years go by (It's some kind of addiction)... Any guesses for 2011?
Old Sep 13, 2011 | 04:22 PM
  #188
joe11204's Avatar
joe11204
Procharged F1X 7.18 @ 197
St. Jude Donor '09-'10-'11
I'm guessing 2011 is going to be your fastest year yet.
Old Sep 13, 2011 | 04:25 PM
  #189
DropTheTop's Avatar
DropTheTop
My guess is that even if you left when I hit the 1/8 mile, you'd still beat me!
Time to save my pennies up for ECS . . .
Old Sep 13, 2011 | 05:06 PM
  #190
digivex's Avatar
digivex
I would like to see something quicker
It's all relative: In 2009 I went to a T&T at Atco and paired off with Doug. I ran a high 9 and was all proud of myself...
Doug made me look bad
Two years have passed since then and, as my earlier video proclaims: "Ressurrected back before the final fallen" - LOL
Old Sep 13, 2011 | 10:52 PM
  #191
DropTheTop's Avatar
DropTheTop
OK guys, stupid but serious question:
Can I use a Snell M2000 atv helmet? it's the kind that you would use goggles with offroad, not a shield. Trying to save a little money here.
The only other helmet I have is an old m/c Snell M95 (too old?), and it doesn't really fit anyhow.
Do I need to go helmet shopping???
Old Sep 14, 2011 | 12:31 AM
  #192
LightFighter_GXP's Avatar
LightFighter_GXP
i would've last minute this event but I busted something.... so I'm out of the game for a few weeks
Old Sep 14, 2011 | 12:45 AM
  #193
LS1LT1's Avatar
LS1LT1
100%
I'm guessing that before 2011 is over you will have touched the 8.7s maybe even 8.6s, it might not (but could) happen this Friday but in my opinion you will be solidly in the 8s before 2011 is over.
The car is likely capable of a little more but as you know all too well this stuff (tires, boost, ideal launch & shift RPMs etc.) takes time to dial in just right.
Old Sep 14, 2011 | 12:48 AM
  #194
LS1LT1's Avatar
LS1LT1
The Snell M2000 should be fine (until 12/31/11 at least) as long as the sticker inside the helmet (under the padding) is clearly marked as such.
The M95 is no longer approved.
Not right at the moment but in 2012 you might want to, I believe the M2000 and SA2000 helmets are only good until the end of 2011.
Old Sep 14, 2011 | 07:34 AM
  #195
Tsab's Avatar
Tsab
See you @ 1:00pm
At 1pm I'll just be getting up, you mean see you at 4:49....
Old Sep 14, 2011 | 07:38 AM
  #196
DropTheTop's Avatar
DropTheTop
Just to be clear, it's like this:
It is clearly marked Snell M2000 on the inside. But like I said, no shield. Can someone confirm 99% that this will be acceptable? Today would be my last day to shop, since tomorrow night I'll be tending to the ribs after work.
Thanks for the input guys, sorry to keep bugging you.
Todd
Old Sep 14, 2011 | 07:53 AM
  #197
simpleman68
Todd
Should be fine bro! I think the track will allow quads to run.
Scott
To September 16th
Old Sep 14, 2011 | 08:14 AM
  #198
DropTheTop's Avatar
DropTheTop
Scott
I'm searching all over, and can't find a definitive answer.
I mean, the rules state Snell 2000 - Not SA2000 or M2000
I know the M2000 are different with the fire and roll bar impact ratings, but that doesn't mean it's not ok. my only concern is the lack of shield. Do you guys have/need your shield down when you race? keep in mind I'll be lucky to be running low 13's.
I guess the worst that could happen is I'd have to wait until 11am for the Speed Shop to open, and then buy a new helmet.
Old Sep 14, 2011 | 08:30 AM
  #199
simpleman68
Sorry, I was just pokin' fun and I'm not up to speed on the helmet req's.
Someone will probably chime in pretty quickly here with a definitive answer for you.
I may have an extra helmet too. I'll check. What size do you wear?
Scott
Old Sep 14, 2011 | 08:34 AM
  #200
Fartpipe's Avatar
Fartpipe
If they want to be picky it must be a Snell 2005 minimum now or later.
