Sponsored by: Innova
Old Mar 25, 2015, 01:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Android Head Unit & Backup Camera Installation
Old Mar 30, 2017 | 03:27 PM
  #421
Rob 02's Avatar
Rob 02
Originally Posted by bjmsam
If the sound is worse after changing only the head unit, then either the old head unit was equalized for the speakers or something is wrong with the new head unit. My guess is the former rather than the latter based on experience with my '94 Stealth: with the stock head unit, aftermarket speakers sounded much worse than the stock speakers due to "factory equalization."
I don't know if the rear speakers are on a "channel" that is independent from the front speakers rather than merely the left and right channels attenuated by balance and fade.
Thanks again. I did some experimentation meanwhile and you are correct. The stock Bose speakers seem to like scooped mid's in equalization. I will be swapping them out soon as well after I add some acoustic treatment.
As far as the rear speakers are concerned, they seem to be matrixed somehow for rear fill with two channel material (which is what I was hoping for). I wont know for sure until I get some full range speakers installed.
Old Apr 4, 2017 | 01:19 AM
  #422
boonie c4's Avatar
boonie c4
Default which of the pumpkin units would you recommend for my 08 C6?
Update: That did the trick! It has connected reliably every time since reverting to the previous version of the OBDLink MX firmware
After a month of ownership, I must report that the 6.x units are lightning fast but remain far from polished at this time. For anyone interested, I am documenting my challenges with that particular unit here (that model is packaged for the RAV4 dash but the guts are identical to generic models that one might consider for a Corvette). Firmware updates will resolve most, if not all, of those problems eventually, but folks who don't want to wait or tinker might be better off sticking with 5.x.
Meanwhile, the 4.x unit in my C6Z remains bulletproof. In fact, it’s better than ever after installing two apps worth noting here. Twilight gradually adjusts the screen brightness within a configurable range as the sun rises and sets based on GPS position. All-In-One Toolbox launches such apps automatically when the head unit boots (as long as they are not moved to the SD Card) and offers many handy tools that optimize memory and CPU, manage files, etc. Both are free and well worth a try!
I'm presently running a Pioneer 4200 nex but i like your write up so i'm asking regarding my present 08 C6 which contains a 5 channel amp a sub with front separates and rear coaxial speakers along with having access to 2 usb hookups which pumpkin unit would you recommend?
thanks boonie. marvinbriggs@frontier.com
Old Apr 6, 2017 | 11:16 PM
  #423
Z2Z's Avatar
Z2Z
https://www.carjoying.com/head-unit/a-c/chevrolet-head-units/chevrolet-corvette-aftermarket-android-stereo-navigation-system/joying-newest-ram-2gb-rom-32gb-factory-cd-player-replacement-new-android-5-1-1-lollipop-system-pip-auto-radio-7-inch-double-2-din-hd-1024-600.html
i have this one and it works fantastically. The buttons can be programmed to color match almost perfectly and the one **** is a great match to the HVAC controls.
Old Apr 15, 2017 | 01:28 PM
  #424
Power-Valve's Avatar
Power-Valve
5th Gear
Hi Forum
I got one of newer units from Pumpkin w/ 2GB RAM sitting here on my desk. And a Pac Audio RP5-GM11.
I am just curious about the audio signal wiring... Should I use the speaker outputs to feed into the Pac Adapter or the RCA outputs? Then I'd need to solder RCA plugs to the non shielded cables from the Pac Adapter which seems weird...
Cheers from Germany...
Uwe
Old Apr 17, 2017 | 12:34 PM
  #425
Trios's Avatar
Trios
Originally Posted by Power-Valve
Hi Forum
Uwe
Looks like you still have the ISO connector on the headunit harness. As bjmsam referenced in the first post of this thread, you need to cut off the ISO connector and wire the GM11 wires to the used-to-be-ISO wires of the same color. PAC adapter requires speaker-level inputs and not line-level (RCA) inputs.
Old Apr 18, 2017 | 05:27 AM
  #426
Power-Valve
5th Gear
Originally Posted by Trios
...PAC adapter requires speaker-level inputs and not line-level (RCA) inputs.
... that's what I was looking for... But I would have loved to NOT use the speaker outputs and switch off the internal amp... whatever.
One more: There are two ways of connecting power to the Radio. Either thru the ISO Connector or thru the small white connector. That's the one I used during my tests on my office desk w/ a computer power supply.
Which one is preferable or should I even connect both?
Cheers
Uwe
Old Apr 18, 2017 | 11:09 AM
  #427
BAAD LS2's Avatar
BAAD LS2
2018 Corvette of the Year Finalist
2017 C6 of Year
Originally Posted by tracybarnes
Check this unit for direct fit and front and rear cam capability:
http://www.seicane.com/2005-2006-che...ontrol-s018724
Has anyone used this unit? Does it fit other year c6 aside from 2005-2006? I really want one that is a direct fit for 2010 zr1 w/ nav, as I hate the look of the adapter plates.
Old Apr 18, 2017 | 12:57 PM
  #428
Power-Valve
5th Gear
It should fit in any C6 as they never changed the SatNav. (just added a USB Port at some point)
Did you see the first post? The adapter plate is just a frame and it looks pretty much OEM...
Cheers
Uwe
Old Apr 18, 2017 | 01:12 PM
  #429
BAAD LS2's Avatar
BAAD LS2
2017 C6 of Year
Cheers
Uwe
That was my thought as well, but found it odd they only called it our for 2 years.
Yes, I know what the adapter looks like, and in my opinion it doesn't match 100% perfectly, I don't want to have to trim and paint/etc. Been through that on my last car.
Old Apr 18, 2017 | 02:42 PM
  #430
Power-Valve
5th Gear
I'd rather trim the frame and get a better unit with 2GB RAM. The 1GB units are getting very slow with the newer Android versions. And I'd go for a bigger screen instead of the DVD drive but that's a personal preference...
Old Apr 19, 2017 | 05:27 AM
  #431
Power-Valve
5th Gear
I'd rather trim a frame and get a newer unit with 2GB RAM. With 5.1.1 Android 1GB units ofter lag...
Old Apr 25, 2017 | 07:47 AM
  #432
CCIE's Avatar
CCIE
Seicane is a horrible company. Defective head unit and DVD player, don't stand behind their product at all unless you're willing to mail it back to China for repair, not even cross ship. Lots of reports on Rennlist about bad MOST adapters. They offer a mirrorlink from your phone that I paid for and they won't even send it to me. Here's the last exchange with them. Anyone who spends money with this company is feeding the troll.
______________________________________
Hello
please fix it at your local car repair shop.
________________________________________
Tina
Follow us on Facebook Twitter Youtube Google+ LinkedIn Pinterest
We are always trying our best to provide you the best service.If there is any questions,please let us know.
Looking forward to hearing from you soon.
Seicane Team
www.seicane.com
Date: 2017-04-24 06:14
To: sales1@seicane.com
Subject: RE: RE: AutoReply: RE: RE: seicane limited: Shipment # 105272953 for Order # 105279803
My Cayenne has been in the body shop for a few months. I love my car. It's like new inside and out and the Seicane unit was supposed to be a dream. Listen, my DVD player is completely dead, has been since delivery. You never gave me the mirror link software and I want what I paid for. I want my DVD replaced. I'll be happy to give you a deposit, PAY for a new DVD player and you refund me when I send the dead unit back. But I want my DVD player and I want my mirrorlink software. I don't know what to even do about the antenna anymore. I can't leave a giant hole in my dash for months while I ship the unit back to China and I shouldn't have to pay all the labor to swap it in and out, so I'm just stuck and will just give up on the antenna issue if you JUST FIX THE OTHER ISSUES. PLEASE. I paid through paypal which isn't going to help me at all so I'm reduced to begging for what I paid for. PLEASE PLEASE PLEASE help me.
Old Jul 29, 2017 | 06:57 AM
  #433
bjmsam's Avatar
bjmsam
After more than three years now, all apps are current, everything functions perfectly, and it remains my favorite upgrade.
Old Jul 29, 2017 | 08:13 AM
  #434
Rob 02's Avatar
Rob 02
I'm still not clear on how to upgrade the firmware. I have the "no DVD" issue.
I have thought about getting the newer unit but I'm going to wait.
Old Jul 29, 2017 | 09:22 AM
  #435
bjmsam's Avatar
bjmsam
Pumpkin referenced a firmware update in 2015 (here?) but I never bothered with it. They were very responsive to my questions during installation, so if you can't find the download or instructions, I bet they would be happy to help (searching their forum on GS-C0219 and JY-C0227 might be useful as well). The XDA forum is another resource (RK30SDK). Good luck, and please keep us posted!
BTW, the Android 6.x unit that I installed in my RAV4 earlier this year works great after recent firmware updates worked out all of the major kinks on that new platform but it doesn't do anything more or better enough to justify upgrading the Android 4.4.2 unit in my Z06.
Old Jul 29, 2017 | 09:28 AM
  #436
383's Avatar
383
what does updating the firmware do? I just pick things up and put them down
Old Jul 29, 2017 | 09:45 AM
  #437
bjmsam's Avatar
bjmsam
I don't know what the Joying firmware that Pumpkin referenced does for this unit specifically, but for the Android 6.x unit in my RAV4, some of the significant changes included:
  • lower the voltage threshold to eliminate reboots during engine start
  • suspend for X minutes when ACC is switched off to eliminate reboot when ACC is switched back on (it takes less than two seconds to restore)
  • improve Bluetooth connectivity
  • improve screen brightness control
  • improve steering wheel and hard button mappings
  • improve MCU apps (radio, music)
  • improve boot logo
  • Android OS patches
All of those "improve" statements above were addressing problems with the emerging 6.x architecture that did not affect the 4.4.2 unit in my Z06 but are examples of what firmware updates can address.
To Android Head Unit & Backup Camera Installation
Old Aug 1, 2017 | 11:36 PM
  #438
BAAD LS2's Avatar
BAAD LS2
2017 C6 of Year
It looks like they have updated this unit to have 2GB and Android 7.1.1.
https://www.seicane.com/2005-2006-ch...ontrol-s018724
I'm very interested if anyone else has any experience with these.
Old Aug 6, 2017 | 02:44 PM
  #439
Jmelz's Avatar
Jmelz
I picked up a ga2164 2gb memory unit after reading this thread.
Installed yesterday... Messy job on my trimming of the metra kit, so I had to order another.
Also...no idea where to get am illumination wire, so I used the too far right one on the HVAC controller (cream?). It lights up the buttons but doesn't seem to dim with the interior lights on the dash...
​​​​​It seems to be working well enough...
Old Aug 6, 2017 | 02:49 PM
  #440
Rob 02's Avatar
Rob 02
Is it for a C5? If so then I can find an illumination wire in my factory service manual later.
What year is your car?
