Priya's 79 chrome bumper conversion project
Many people may not work on Corvettes for a living and do not know about the areas where MAJOR concern MUST be taken or FAILURE of a repair can occur. I know this because I have paid dearly for knowing this stuff.
Inaccurate information is just as bad as bad advice. I will comment on both...and those care to read and consider my explanations...fine...those that feel that I am nothing but a bag of hot air...that is fine also.
SO...sorry for making you feel that this was not worth commenting on. But when I feel that something is not right...would you not want to make sure you are informed???
DUB
NOT directed at you DUB...your advice is not just some opinion. I recognize your expertise and will be picking your brain in my own build once I get to the fiberglass.
I am talking about the guys who want to argue while Priya is on the sidelines.
If they want to argue....take it to PM.
That is my opinion.
Thank you sir!
IF you are going to apply a primer or rattle can paint on a part so that is is a consistent color....KNOWING that you are going to remove it.
IF I were to use a solvent to get that paint off.....it would be lacquer thinner...and that is because I would only apply enough color to get it to the point where it is going to give me the 'look' I need for inspection and NOT pounding the product on the panel that I know I just have to get all off again.
Now as I wrote above.... I started it off withIF. Normally I do not use this practice. Mainly because I just do not like to have my VPA get wet with anything for long periods of time. YES..I use acetone...but as we all know...acetone does no linger on a panel...it flashes off very quickly.
IF I have to check my work because I am suspect about it. I use the DRY GUIDE POWDER from 3M and apply it and get it to a very dark black and check it. Then I can scuff it off. I am not bragging (trust me)...but doing this for so long I have acquired the ability to see my work and get it close enough so that when I apply gelcoat or whatever primer I need...I generally do not have to back track and take it off. BUT...WAAAAAAY back in the day...I used to use red oxide lacquer primer and dust it on....and then either leave it due to I was painting lacquer...or take it off with lacquer thinner and be careful around my repair areas when doing so.
Once again...THIS is when TESTING a procedure is PARAMOUNT. Not knowing what the end result can be dangerous. So setting up a test panel to see how 'whatever' solvent is being used is WISE. So if it softens your work or damages something...or deeply saturates something...at least you did not do it to your car and NOW have another issue to deal with.
I can say this FROM EXPERIENCE. The longer an applied liquid can linger on the bare surface of your car. The GREATER the chances that THAT product can come back and haunt you. SO...OIL, WATER, SOAP, DETERGENTS, PENETRATING OILS, SOLVENTS, SILICONE, TEFLON, BRAKE FLUID, BATTERY ACID or whatever...can cause for problems if they are not removed.
DUB
I have been using wax and grease remover to check my work for a very long time without a problem.
So it no longer is 'bouncing all over the place'.
"Actually ...depending on the year model ( some do it more than others)...the front clip will drop if the radiator support and all other brackets are not in place ..and that is also assuming that the headlight assemblies are still installed."
DUB
I never said anything about removing All other brackets from the front clip only the core support. So you no longer feel the same about what qualifies as a support? If the body doesn't drop removing a part it's not a body support?
I gave other examples of supports that can be removed without the "body dropping". I was using your definition of what qualifies as a body support and obviously it is faulty reasoning.
That is my opinion.
Thank you sir!
It would be more reasonable to suggest that if input from other members is not welcome on a OPEN PUBLIC FORUM thread, that the members not wanting the unwelcome input from people that you feel are not qualified to reply and offer advice take it private. DUB could easily ignore opinions and advice he dislikes which is a lot and choose not to engage.
A lot can be learned from good arguments and that will inevitably help anyone interested in similar projects.
As far as I see it, Priya went from dismissing the importance of the substructure to appreciating the importance of bringing the exterior and substructure to completion simultaneously. A very important and crucial step towards success. I will let you decide who made that happen.
let's be glad they're not arguing the pros and cons of Charmin !
That is my opinion.
Thank you sir!
100%...but this needs to be clarified even though you did write in your recent post that you apply it on primer..
I also use wax and grease remover for my final checking of the body AFTER it has been primed or gelcoated and primed. In my opinion....I have found nothing better than wax and grease remover for aiding in finding the most minute glitches and flaws before a car is painted......but it is being applied on primer...and NOT on bare fiberglass, SMC or even raw urethane.
Do you agree that it is to be applied on a primer and NOT on bare fiberglass, SMC or raw urethane??? If not.... that is fine...but leaving it not clearly explained can cause for someone to not read into it correctly and really screw something up.
*** REAL WORLD OBSERVATION***
I local guy called me up and wanted me to stop by and look at something for him on his car that he was repairing himself. When I walked up to his garage...he had take a gallon of the cheapest 'bondo' and literally poured some of it out on the hood...then he squeezed out a bunch of the hardner and began to mix it up ON THE HOOD and spread it out. I asked him why he was doing it that way and he said there is not difference if he did it on a mixing board or the panel and it is faster becasue he does not have to apply it because it is already on the panel. BUT..then he asked me why when he is blocking the other panels he did the same process to...why his 'bondo' was peeling off when he blocked it an he could not get a good feather edge. So...it is common sense on why he was having problems. I know this is NOT relative to Priya's thread...but it does have everything to do with proper procedures and not leaving important steps out or critical information out.
'momo608'
If you want to start a thread discussing the issues of supports and your views on it...feel free. Send me a PM to the link and I will be more than glad to get in on it. But I am done here on Priya thread about it. I am more concerned about her success and moving ahead on her project.
DUB
I am not interested in arguments as a source of information for me personally.
I just saw Priya getting run over by other comments.....and was concerned that she would back off completely.
I was trying to just bring the discussion back to Priya's expressed needs and not others impression of her needs.
Many of us are watching this thread as we attempt something similar.
I have seen threads shut down due to outsider banter.
I have PMed Priya and will go back to my seat in the bleachers and take notes.
Peace to you sir....
I'm concerned about this:
"The bumpers are sorted out, welded up and sitting flush."
I'm not sure how you could accomplish this without knowing the finished position of the rear fiberglass.
While you've adjusted the fit of the bumpers to the fiberglass, aren't you opening up the possibility that the bumpers won't be parallel to the ground because of just how the fiberglass is finally located?
I'd think BOTH the fiberglass and the 'ground' would need to be taken into account when repositioning the bumper mounts.
Regards,
Alan
I'd think both the fiberglass and the 'ground' would need to be taken into account when repositioning the bumper mounts.
Regards,
Alan
Good luck with your build!
RVZIO
Regards,
Alan
I thought of building up the fiberglass on the rear clip to allow the bumpers to sit flush but realized this would make it so that the inner and outer surfaces of the rear clip at the mounting point would no longer be parallel to each other and I figured that would result in uneven pressure on the clip when the bolts were installed and tightened so I felt that was a less desirable option than modifying the bumpers themselves.
As far as the bumpers sitting parallel to the ground goes, there really is very little adjustment possible between the rear clip and the bumper before the bumpers don't line up very well with the body lines on the rear clip, the bumpers kind of have to go in a certain position on the rear clip regardless. So, if the rear clip isn't lined up well on the car one is left choosing between having the bumpers parallel to the ground and being misaligned on the rear clip or having the bumpers aligned on the rear clip but not parallel to the ground.
I can tell if the rear clip is at the proper angle to the 79 by looking at the openings of the rear side marker lights and seeing that those are parallel to the ground and by seeing that the horizontal mid quarter panel character line on the 70-73 ACI rear clip aligns with the same line on the 79 where it meets the wheel opening. As far as having the left and right sides of the rear clip the same distance from the ground there really is no way to vary the distances as the rear decks and the corners where the quarter panels meet the upper deck have to be lined up and the wooden clamps hold them very precisely in alignment.
Could the fitment of the rear clip vary between mock ups on the car and when I finally fiberglass it into place? Yes but I'm confident there is very little change from one mock up to the next as I've had the rear clip mocked up several times and there just isn't much room for it to vary from one mock up to the next due to the way the wood clamps hold the rear decks in near perfect alignment with each other. I am confident I know the finished position of the rear fiberglass to a close enough degree that I'm not worried about how its going to fit in relation to the car and the ground.
I used the measurements Alan and another Forum member gave me for the distance between the bumpers and the tail light openings to line up the bumpers with the rear clip and I am confident that the bumpers are lined up well with the tail light openings.
In order to modify the last two bumper brackets I will need to bolt the bumpers in position with the rear clip mocked up into place but not glassed in. I can then see how the bumpers align with the ground and if any changes are desirable which I think is reasonably unlikely.
I think it's the bracket that's shaped like a 'rod' that has the most influence in determining how level the bumper is to the ground…. since it has the ability to 'tip' the bumper.
It's really the pure 'side-view' that shows if the bumper is level or not.
Fortunately since there are 2 separate bumpers you can adjust them individually. They're not like the front bumper where what you do to one end affects the other end too.
I just wanted to make sure you had carefully thought out the moving of the brackets on the bumpers.
Regards,
Alan
I measured the scissors lift surfaces and they're level. I measured the 70-73 ACI rear clip and its level. The distance between the 70-73 ACI rear clip and the surface of the scissors hoist is the same from left to right side and yet visually it looks like the left side of the ACI rear clip is lower than the right
I guess I have to go with what my measurements are telling me and not my eyes, right?
I believe that our 'eye' typically determines 'level' by comparing the particular 'object' it's looking at to it's surroundings.
You have to be able to differentiate between 'level' and 'parallel'. Your rear Corvette letters were an example of 'parallel'…. your eye perceived them to not be parallel to the top of the license plate recess.
I think you have to be VERY careful what you use to judge 'level' by when positioning the cap.
Regards,
Alan
I measured as well from the surface of the lift to the side marker lights, the side bulge where the bumper goes, and the upper edge of the openings for the exhaust bezels.
I'll go over it with my husband this evening and see what he thinks.
Take this advice to heart or leave it.
NO NEED for you to bond or glass in your rear clip temporarily. The way you have it joined is well enough for what you are needing to do here. The 'trick' will be is making sure that when you do go for your FINAL bonding and fiberglassing in of the rear clip...you get it back to very close to where you have it now. This is where your measurement you take or you marks you put on the panels will aid you.
DO NOT get all caught up in measurements. If you do..it will drive you insane and honestly...in most cases no one including a judge can pick up in any differences. PERIOD---FACT!
PERFECT EXAMPLE!
On your front end...in the 12 o'clock position of your wheel well opening. Take thread and pinch it with your fingers using your fingernails to hold it. Take you fingernails and put it on the bottom of the 12 o'clock position of your wheel well opening lip ( that 1/2"-3/4' wide section you can see).....then run the straight up to the TOP fender body line. Pinch the string there. THEN...walk over to the other side of your car and while holding the string...put your fingernail where they need to be and see if they are EXACT!!! Chances are...you might find they are NOT the same. I know this because I have seen it for decades. BUT YET...your eye can not see that it is that far off.
Keep in mind that if you are going to be using a level...you should make sure that your tires are the same air pressure and also what the distance from the ground to the bottom edge of your quarter panels at the 12 o'clock position...and then do the string test on the quarter like you did on your front fenders and see what you have going om.
I DO take measurements VERY SERIOUSLY...so please do not be confused that I disregard them entirely...but I also know that if you get CONSUMED by them..I will soon be visiting you in the mental institution. DO what looks good by your EYE! Make sure you step far away to get a good view...because begin right up on the car does not work when checking some things. When I do bumpers ..I am at least 30 feet away.
In my opinion you doing what you did for your rear bumpers is SPOT-ON. DO NOT doubt if you are doing is right or not. If you were doing this at my shop I would let you know you are on track...for what ever that is worth to you. Getting the mounting surfaces of the bumpers MUST be achieved either by what you did or doing fiberglass work. As long as your rear clip is solidly mounted....that is all that matters. And those who can not see that and want to dispute it...obviously do not have the ability to...how was it put:...are incapable of admitting when they are wrong, that stubbornness has surely effected their ability to improve themselves.
The bumpers...when installed are basically going to be flat in regards to the top surface BECAUSE the side mount area right above your side marker light are in the quarter panel is going to control that more so...than the rod. Knowing that you cut your bumper mounts...now you can get the bumper to sit as it needs to be and then modify the rod to get it to work.
NOW...because you bonded in your exhaust filler panel you possibly took away some adjustability in your bumpers. This is because.....the bumper brackets that go behind your taillight panel near your license plate area originally allowed the panel to be slightly pushed out or pulled in if needed to get the 'wrap-around' of the bumper to be correct and install 'better'.
Priya. For whatever it is worth. When you have an issue like in the post of you showing the license plate area with the yellow lines. If you take the photo from a good distance so I (we) can see what it looks like from far away would greatly help.
DUB
