PLEASE look at the intake gasket, THEY HAVE THE WRONG ON INSTALLED !!!! The one they used left the water passage from the head wide open to the lifter valley. The gasket linked above is the one they SHOULD HAVE USED. This is all on them and you have them by the nads.
Don't forget "When you have them by the ***** their hearts and minds will follow"
Not sure about that as the middle port is blocked off, even though the gasket crosses the middle of it, it still should be sealed. I think??
It will seal it from spraying out of the engine but leaves it wide open to lifter valley. This is the same head I had on my 97 LT1 and I distinctly remember wondering why there was a water passage only to be blocked off. The gasket I linked above would have sealed that passage between the head and intake.
That is probably exaclty what happened, as soon as he said Kieth Black a light went off. Kieth Black pistons require extra gap on the top ring, more than the ordinary hyperutectic piston because of the high silicone content of the piston. If they were not gapped correctly correctly it is the builders fault, this can be easily determined by removing the piston and measuring ring gap.
I agree, I've got KB pistions and had to open up the top ring gap to prevent this. Also I read that no more than 34 deg total advance. I've read this on several web sights, check it out
My White....thanks for your observation, and I first thought the same thing until I checked the intake. There is no middle port on the intake.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Another point of information here. My engine builder used the hyper pistons also, not sure about the brand. He specifically told me "do not build a fire in this engine without letting it get up to operatin temp". Now I know why he stressed this point.
BTW >>> What are those heads ... really? They do look like vortecs ... but they seem to have an exhaust xover port. & Just because they may have 4 mounting bolts per head does NOT make them vortecs.
How about look for and post all head casting numbers ... maybe these are not even GM ... maybe aftermarket-sorta-vortec-kinda-knockoffs ... dunno ... post numbers please.
As I dont think i can attach pics yet, here is link. On my 97 LT1 the passage circled in red was blocked off by the intake gasket. Scrapping the gasket off it appeared to be a water passage. If I am wrong educmacate me
I my case, I was well within operating temperature. It idled in the garage during cam break in and adjustments for at least 30 minutes. But, a good point.....
Let me try again.....the ony place that sealed off port is open to is the valley. Nothing else. There is no port on the intake there. It's nothing more than a part of the valley.
Definetely GM....on top in one place GM D, and another 12558062. On the bottom only two seperate numbers, 13, and 062.
the exhaust one for that cylinder is sitting nicely in the valve seat and its not chewed up?
Both valves are seated nicely. There are some minor markings on both faces however. The others look pristine, while these looked scratched in couple of places. Definetely don't look like the others. Almost looks like something was hitting the face for a very short time, ie: part of the piston? Which is MIA.
so we can rule out the exhaust valve hitting the piston correct?...i would think if the valve hit the piston the valve stem would be bent or the valve would be sitting funny on the seat....i can see where the rings not being gapped properly would break the land ....why/how would that crack the cylinder?
If you look up the part number for the intake gaskets you get 2 different ones. First one 89017465 GM Intake Gasket. [Old P/N 12529094] is what is installed on this engine. The second one 1255 Fel-Pro Intake Gasket is different. If you notice the passage I am talking about would be blocked by the intake but sealed by the second gasket.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
If the engine was dynoed at the shop in question why did you have to break in rhe cam ?
