New crate engine is now a steam engine....bad problem...
Old Mar 8, 2006 | 11:48 AM
  #381
bashcraft's Avatar
bashcraft
Originally Posted by JustForFun
why all the carbon with a engine with so few miles?
from idleing
Old Mar 8, 2006 | 11:49 AM
  #382
JustForFun's Avatar
JustForFun
Originally Posted by big_G
Wow, those cylinder walls look like sh*t....no cross-hatch? WTF?
wondered the same thing. that doesnt look like a engine with so few miles
  #383
Hauq`'s Avatar
Hauq`
Detonation is caused by having the timing too advanced, or too high compression. Either case causes the ignition of the fuel too early;making the highest pressure in the cylinder before the piston reaches TDC. However; in both cases the piston is near TDC when it happens. This causes great pressure on the piston, the head gasket, the connecting rod, and the rod and crank bearings. This does not cause any increased pressure near the bottom of the cylinder.
So, as my opinion as an engineer detonation didn't cause this.
Old Mar 8, 2006 | 11:59 AM
  #384
MsVetteMan's Avatar
MsVetteMan
Hmmmmmm....I'm feeling a little better now.
Old Mar 8, 2006 | 12:00 PM
  #385
Twin_Turbo's Avatar
Twin_Turbo
I'm 99% positive after seeing those pics, look at the ring. you can see a crack in the ring just below that red brownish deposit, like the ring jammed and cracked lengthwide..almost like it's split in half. If you would take the piston out you would probably see scuff marks from the ring seizing, this is starting to look more and more like a severe ring gap issue. They should build you a new engine free of charge. The chamber damage is from loose piston chunks.Severe detonation leaves tell tale marks, looks like a pitted surface and all pistons would show it, not just one (even though it can lead to only 1 piston failing...) this is not the case here.
The walls looks glazed up..certainly no recent honing done there...or it's an engine that has accumulated some miles...can you check the bore size? measure if this thing has had an overbore at all..maybe they just got a std. size block (or an already oversize one but if it's std. you K NOW there was no boring done there) and dumped in some new pistons, w/ the bore beig worn most on the top and setting the ring gap there that would lead to this kind of problems...
Looking at the pics again, almost looks like I see a carbon ridge near the top and a wear ridge...feel it with your finger, for all you know this might juts be a core that was not bored and certainly not honed.
Old Mar 8, 2006 | 12:14 PM
  #386
Gordonm's Avatar
Gordonm
I took apart my engine with 5K hard miles and you can see the cross hatch on the walls. This looks like crap. I would say you definitly have a case against them here. This is poor workmanship!
Old Mar 8, 2006 | 12:15 PM
  #387
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Once old Clarence and his boss see these pictures they are going to go into damage control or complete denial.....you have one Mechanical Engineers professional opininon.....i think all you need to do is get this on a professional letter from a "PE" and the credit card company will rule in your favor....remember they are the jury you making your ulitmate case to and if it costs $200 for a local ME to certify this it may be money well spent, in any event see what they say first and then talk with the credit card company and see what they need in way of documentation.... we are kicking *** now.....
Old Mar 8, 2006 | 12:16 PM
  #388
David Ey's Avatar
David Ey
I completely agree with Turbo. Also a piece of piston could have wedged in and cracked the block.
What is that red on the ring?
I would definately have a mechanic look at it NOW in this condition.....just a look couldn't cost you much and you WILL need his opinion later.
What do the other cyls. look like. Any cross hatch?
Old Mar 8, 2006 | 12:19 PM
  #389
Batsy74's Avatar
Batsy74
Post some close-ups of other cylinders.
Old Mar 8, 2006 | 12:23 PM
  #390
bobs77vet's Avatar
bobs77vet
lets not forget "material misrepresentation"..... if the block was never honed....and it has a ridge.....and they sold it to you saying it had been, and the photos and the "PE" says other wise it just adds more wood to your fire .....
Old Mar 8, 2006 | 12:27 PM
  #391
MsVetteMan's Avatar
MsVetteMan
More pics....same cylinder. I'll get the others shortly. This is about as close as I can get, and it starts to blur at this point.
Old Mar 8, 2006 | 12:30 PM
  #392
MsVetteMan's Avatar
MsVetteMan
Ole Clarence just emailed me....didn't have much to say.....
"Hi Brian, I received your emails. I will add the pics to the claim info.
cb"
Old Mar 8, 2006 | 12:33 PM
  #393
MsVetteMan's Avatar
MsVetteMan
Here is the complete representation of the crate motor, straight off their website. Link also...... http://www.blueprintengines.com/popu...specs&pc_id=23
Block:
4 bolt main block
Passenger side dipstick
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Cylinders are sonic tested for thickness
Rotating Assembly:
New SCAT cast crankshaft
Keith Black Hypereutetic pistons
Chevy heavy beam rods with 150,000 psi bolts
Hastings Moly rings
Balanced rotating assembly
Melling high volume oil pump
Flat tappet hydraulic lifter camshaft
Heavy duty double roller timing set
Cylinder Heads:
Cast iron "vortec" heads
1.25 diameter valve springs
Hardened retainers and springs
2.02 swirl polished intake valves
1.60 swirl polished exhaust valves
Hardened push rods
NOTE: THIS ENGINE WILL NOT WORK FOR APPLICATIONS REQUIRING EGR
A Ton Of Extras:
Professional Products dual plane satin finish intake manifold
9.5 to 1 compression
New chrome valve covers
Brass freeze plugs
Dyno tested – and shipped with results
Comes with 24 month / 24,000 mile warranty
Driver side dipstick is available-please specify when ordering
Critical Specs:
Horsepower:
385
Torque:
405
Old Mar 8, 2006 | 12:36 PM
  #394
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Looks almost like a used block with no machine work done to it at all, couldn't get much worse than that.
Old Mar 8, 2006 | 12:39 PM
  #395
stingraymaniac's Avatar
stingraymaniac
that dosent look good at all
Old Mar 8, 2006 | 12:41 PM
  #396
Hauq`'s Avatar
Hauq`
sure it could, it may only have 2 bolt mains with original hardware
Old Mar 8, 2006 | 12:49 PM
  #397
Batsy74's Avatar
Batsy74
Back-up and use zoom.
To New crate engine is now a steam engine....bad problem...
Old Mar 8, 2006 | 12:51 PM
  #398
427V8's Avatar
427V8
C6 the C5 of tomorrow
Originally Posted by bashcraft
Why? If the engine is built right, it'll be broken in by the time it reaches operating temperature.
when I had my 434 built( and Dynoed I saw it ) I asked what the break in procedure was.
He said 1/4 mile at WOT.
If it's really been dynoed, it's already broken in.
And looking at those pics I wonder if the piston could have hit the cylinder ridge and broke...Bad Bad Bad
Old Mar 8, 2006 | 12:54 PM
  #399
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Incredible.
Old Mar 8, 2006 | 01:12 PM
  #400
Kalway's Avatar
Kalway
Well those cracks would definitely explain the milkshake, too.
