New crate engine is now a steam engine....bad problem...
Old Mar 9, 2006 | 04:41 PM
  #481
MsVetteMan's Avatar
MsVetteMan
Originally Posted by 69Myway
Any chance you simply lost a washer or nut down the carb since there was a good chance you were running without an air cleaner?
I think it is very possible it got sucked in and popped into #6 fracturing the piston, then ejecting out the exhaust valve leaving a hole in the piston and damaging the wall.
Anythings possible....I'm just about ready to pull the motor. I'll check in the oil pan closely!!
Old Mar 9, 2006 | 04:45 PM
  #482
MsVetteMan's Avatar
MsVetteMan
Got the drivers side head pulled. Everything looks fine on this side!! You can see the cross hatching on the walls from the honing much better on this side. The other side was just dirty. I don't know how fresh it is however.
Hope to get the motor out tomorrow, and take it down to the machine shop on Monday. Do parts stores carry bore calipers? How much are they?
Old Mar 9, 2006 | 04:57 PM
  #483
Twin_Turbo's Avatar
Twin_Turbo
no need for a bore gauge to measure that accurately, a vernier caliper will do just to get an idea of overbore.
Old Mar 9, 2006 | 05:35 PM
  #484
Older Than Dirt's Avatar
Older Than Dirt
Here's a couple of threads leading up to this one if anyones interested.
http://forums.corvetteforum.com/show...766&forum_id=3
http://forums.corvetteforum.com/show...2&forum_id=119
Old Mar 9, 2006 | 05:44 PM
  #485
Russ57's Avatar
Russ57
I had same thing happen to a 67 Pontiac xh block(366hp) was 60 over with forged pistons and jim butler cam,cause was a plug wire came loose at high rpm,was doin approx 130,developed slight miss(at time I didn't know wire was loose) next mornin' leavin' work car would not start module was shot replaced it,and everything started knockin'.Drained oil and changed it car ran good 'til crankcase filled with water,and steam found it's way out valve cover.Cause was cylinder loading with fuel and no ignition source.Then wire either sparked, or heat/comp caused misfire and cracked cylinder.Ran it 6 or seven x's changing oil between runs and never had foaming you had.Still tore engine down and rebuilt due to glycol/bearing damage.Massey's in Jackson was good about seven years ago don't know about now.Get my work done in Vicksburg at Jack Hill's place
Old Mar 9, 2006 | 05:46 PM
  #486
Russ57's Avatar
Russ57
You can get a cheap set at Habour Frieght in Jackson,Ms.
Old Mar 9, 2006 | 05:53 PM
  #487
David Ey's Avatar
David Ey
You are not helping yourself here.
Old Mar 9, 2006 | 06:08 PM
  #488
E_Tar's Avatar
E_Tar
When I first saw the Image I nearly fainted.
"God I hope nothing like that ever happens to my vette" went through my mind.
Have you ruled out Foul play ?
Do you have a Fuel cap lock on your gas tank ?
Could someone have put something into your fuel when you were sleeping at night ?
If you have it garaged, i guess that doesn't count.
Old Mar 9, 2006 | 06:19 PM
  #489
rihwoods's Avatar
rihwoods
Doubt anything in the tank would do that..to many small passages...filters,etc....once had weld bb's screw up my carb on a new 69 Roadrunner..warranty item for gas tank.......engine was just fine..
Rich
Old Mar 9, 2006 | 06:27 PM
  #490
E_Tar's Avatar
E_Tar
Why I say that is because, some pranksters once poured soap into a relative's fuel tank. What came out when they had the tank washed was not pretty. It was a Diesel Fiat.
Plus he had to get a lot of engine work done to repair the mess.
Old Mar 9, 2006 | 06:36 PM
  #491
Shirley1978's Avatar
Shirley1978
Damn it.. this tread is longer than the Lord or the rings trilogy... took me about 1 1/2 hrs just to get to the end.. think you should send this to steven speilg.. and get a seriouse drama made outa this for the big screen.. thank god i finished reading this cuz i got an f-ing mid term in 20 mins... good luck with that ... Godspeed man!
Old Mar 9, 2006 | 07:12 PM
  #492
Glutton4punishment's Avatar
Glutton4punishment
This has taken the better part of 2 hours to read I hope they do the right thing by you and replace the motor. I will not be buying any motor from blueprint... ever!!!
Old Mar 9, 2006 | 07:32 PM
  #493
shafrs3's Avatar
shafrs3
Originally Posted by Twin_Turbo
The carbon is easily cleaned out, the ridge reamer removes the "thrust" ridge, this is a ridge of "cast iron" that is a result of the rings actually pushing the metal forward and accumulating there...much like a snow shovel...kinda hard to explain.
Boy thats a new one. I always thought, and still do, that the cast iron ridge is a result of the rings wearing away the cylinder wall, and is where the rings stop at TDC.
Old Mar 9, 2006 | 09:40 PM
  #494
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
ok, another good read. marking my place
Old Mar 9, 2006 | 10:01 PM
  #495
corvetteatv7's Avatar
corvetteatv7
Old Mar 9, 2006 | 10:29 PM
  #496
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
why not both? with the heat of combustion i would think you would have metal movement much like stretching
Old Mar 9, 2006 | 10:30 PM
  #497
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
WOW i think this thread is going for a record and i am also marking my spot. please keep us updated on findings and good luck man i will say my prayers for you every night till you get it resolved and fixed. i hope the company does the right thing and either replaces the engine with a new one with all the paperwork and documents like a REAL dyno sheet or gives you a full refund.
To New crate engine is now a steam engine....bad problem...
Old Mar 9, 2006 | 10:41 PM
  #498
shafrs3's Avatar
shafrs3
Why then is there no ridge on the bottom?
Old Mar 9, 2006 | 10:50 PM
  #499
shafrs3's Avatar
shafrs3
It's being worn away in small quantities, like tire wear, and ends up in the oil.
This was in response to someones post, now that post has disappeared.
Old Mar 9, 2006 | 10:55 PM
  #500
Matt 1980 L-82's Avatar
Matt 1980 L-82
I've never really inspected used oil before... so would I be able to see these bits of metal in the oil?
