New crate engine is now a steam engine....bad problem...
This was in response to someones post, now that post has disappeared.
So, I don't want to cause trouble here, but what is the actual explanation for the iron ridge? Can it be a bit of both or what? I like it when you knowledgeable guys debate. I learn a lot from it.
Even if the piston is removing material from the cylinder, shouldn't there still be a ridge at the bottom? The ring stops in the cylinder at the bottom of the stroke too. It seems like either of the explanations for the ridge would suggest a ridge at both ends of the cylinder.
You won't cause any trouble by debating a topic, and it is ok to say something that might not be true, accurate or right, I've done this many times and have been quickly set straight!
Lets face it, nobody right 100% all of the time. But this is how we all get a better understanding of our hobby. The only time you’ll get into trouble is if you post something that is or could be interpreted as being disrespectful to others, or just plain annoying, just look at Yellow73SB's past posts.Now, Twin_turbo suggests that cast iron material, over a long period of time, is being pushed like clay to the top of the cylinder forming that classic ridge that we see in a high mileage engine, if I'm understanding him correctly.
That ridge is formed from the contact of the rings with the cylinder wall. At the point of combustion, the rings are loaded to their fullest and are forced against the cylinder at TDC. As the piston travels down the cylinder wall, this load becomes progressively less, forming the classic cylinder taper that is seen in a high mileage engine. That is why there is no ridge at the bottom. If the clay theory were true, then cast iron would be pushed down the cylinder walls and re-deposited along the length of the stroke, and eventually the engine would seize.
.I'f everyone who looked at this thread donated 10 cents we could buy him a new motor.
... but let's not get into that. I'll be the 1st to admit here that what I said was wrong
Is there anything that can be done as a group maybee everyone that answered to this thread could call the company and bitc* I think a few thousand motor heads calling would get there attention!
I'll make sure the money is taken good care of
