New crate engine is now a steam engine....bad problem...
Old Mar 10, 2006 | 10:18 PM
  #541
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Originally Posted by Twin_Turbo
your sidewall scuffing is still a result of too much body roll ... but let's not get into that. I'll be the 1st to admit here that what I said was wrong
I'll be waiting for the "Turtle was right thread" in a few years. ( after you've had some track time )
I've overheated my friggin mexican block about 10 times and i'm still a crusin. Good ole GM goodwrench $1200 engine.
Old Mar 10, 2006 | 10:36 PM
  #542
MsVetteMan's Avatar
MsVetteMan
Originally Posted by 71rdster
I have watched this thread with interest for several days. I feel your pain in dealing with an unscrupulous vendor. I am not an attorney, but I believe that you have significant evidence to send this vendor to jail for wire or mail fraud. The vendors misrepresentation of the engine as evidenced by the cylinder bore pics and sales specs comparison, you are in a position to shut this business down. They should refund your money plus pay for your trouble, and shipping costs, or you should file fraud charges in Federal court. Their "warranty" is of no validity in interstate commerce. They are just trying to scare off potential law suits. They cannot force you into their courts because it is an interstate transaction and as such is covered under Federal Law. Notify your credit card company and contact your attorney. Have your attorney find an attorney that specializes in interstate consumer abuse /fraud cases. Since attorney's cost $$$ you need to call your local US Department of justice office to report this flagrant interstate fraud.
You know, your right. This motor had better be exactly as advertised or I'm gonna hang this company. It will then turn into a you want your money back?.....no. Upgraded motor?...No. If it turns into this type of situation I will hang their azzes for many $$$$$$$. This one simple motor they could have simply just said after reviewing your photos we will warranty, they will no get more bad press (on going) and a team of the meanest freakin' lawyers you have ever seen on them.
I have been jokin' a bit lately about this, but if this motor doesn't check out as advertised, I'm gonna hang their azzes. Already caught them in one lie about the dyno (though they swear it is dyno'd, they just don't print sheets for each motor. They make sure each one exceeds the minimum dyno chart he faxed me. Bullcrap.)
Second lie may be the honing and bore size.
Other possible lies will be the parts actually used. It's suppose to have a Scat crank.....what's the bet? Suppose to have a comp cam 268H. Suppose to have KB pistons....I'm not so sure on this either. The intake manifold is a cheap China stamped reproduction of the Edelbrock air gap. It's getting tested as well.
The inside of the water passages on both the heads and the block are badly rusted.
I noticed some rust on the front of the motor when I first got it. It was freshly painted, but looked like they missed a spot.
Oh.....4 bolt main.....what's makes a motor a 4 bolt vrs. 2 bolt? Motor mounts?
Interstate fraud is a federal crime......I can't wait to get this motor to the machine shop.
Old Mar 10, 2006 | 10:43 PM
  #543
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by MsVetteMan
Bullcrap.)
no not the motor mounts its the bolts on the main caps....these are what hold down the crank shaft....they can either have one bolt on each side (ie.2 bolts) or two bolts on each side (4 bolt)...you can't fudge on that one
ps your states attorney generals office may have an internet fraud task force...
Old Mar 10, 2006 | 10:50 PM
  #544
MsVetteMan's Avatar
MsVetteMan
Hmmm.....I can check that myself when I pull the oil pan off to clean it out....
Hey, these guys might check out, but my gut tells me they won't. Kinda make you wonder why they gave me permission to have a third party inspect it, doesn't it? Wonder if that is some type of trap? All I have is an email reply saying it's okay....wonder if that is admissable in court?
Old Mar 10, 2006 | 10:55 PM
  #545
Kalway's Avatar
Kalway
E-mails are legal documents. You're actually required by law to keep e-mails for 3 years.
Old Mar 10, 2006 | 10:56 PM
  #546
dgruenke's Avatar
dgruenke
Yes, it is. You just have to testify that it is the e-mail that you received from them. Then it's in.
Old Mar 10, 2006 | 11:03 PM
  #547
bobs77vet's Avatar
bobs77vet
it may be that you have them figured wrong....they have given you everything you asked for....i bet they subcontract some engine builds....a reputable company doesn't mind the the third party inspection....
they just can't admit fault without seeing the product
Old Mar 10, 2006 | 11:11 PM
  #548
David Ey's Avatar
David Ey
I advise against cleaning anything. Let the mechanic do this and only as required. Probably leave the oil filter alone rather than open it.
Basically I would get him to measure all bores and look for ridge and wear, pull a main brng. and check size marking, remove a rod cap and check size and measure journal and maybe one piston but not the bad one, look at oil pump and screen it should be new,pull a lifter or two they should come right out and show no wear, cam should look new, all the internal components should look spanking clean except for your milkshake mix, if there is debree in pan leave it but note it in photos and notes, timing gears and chain should look new and be tight.
Record the serial number and check against invoice.
Good luck my friend. I just hate it when someone gets screwed.
Old Mar 10, 2006 | 11:18 PM
  #549
rihwoods's Avatar
rihwoods
This is a labor intensive area,and probably one where they tried to cut some corners..no pun intended....
Rich
Old Mar 10, 2006 | 11:22 PM
  #550
chevy69's Avatar
chevy69
St. Jude Donor '08
I just went out to their website: http://www.blueprintengines.com/about/tv_spot.html
and they have a convenient "contact us" link.
Just give the nod and I'm sure many of us would be willing to send them a note on your behalf
Old Mar 10, 2006 | 11:26 PM
  #551
MsVetteMan's Avatar
MsVetteMan
Why not pull the bad piston? We need to in order to get a full view of the bore. Just wondering why you would say this.
The only stipulation in my getting 3rd party inspection is it has to be reassembled before shipping back.
I have already flushed the engine twice, but I will take your advice on the oil pan and filter, and leave it in place for my inspection at the machine shop. I just hate to leave all that chit in there.
Old Mar 10, 2006 | 11:30 PM
  #552
David Ey's Avatar
David Ey
I guess it don't matter on the bad piston, just save all the pieces in an envelope if the rings come apart.
Old Mar 10, 2006 | 11:32 PM
  #553
MsVetteMan's Avatar
MsVetteMan
Funny you should mention that. I pulled the shipping ticket and it was shipped from Goodman Auto Repair in Platte City, Mo.
WTF?
How many dyno machines you think Goodman has?
I'm getting madder by the minute.
Anybody near Platte City want to check this place out for me? Worth a few cold suds and a steak dinner if you ever come south. (True South that is).
  #554
BuckyBoy's Avatar
BuckyBoy
St. Jude Donor '06
Water in the oil is a probable indication of either a blown head gasket or cracked head - no question about it. There is also a test to detect CO2 in the radiator water.
Most likely you will be pulling the head either way.
Old Mar 10, 2006 | 11:39 PM
  #555
MsVetteMan's Avatar
MsVetteMan
Bucky....I know it's a long thread, but you really need to read all of it before you comment. The cause of the oil water mix was discovered many pages back.
Old Mar 11, 2006 | 12:00 AM
  #556
yukon988's Avatar
yukon988
I agree...I was totally wrong As you describe it is how it's caused.
Dang -- Now I feel guilty for making the ridge comment to begin with.
Old Mar 11, 2006 | 12:01 AM
  #557
BuckyBoy's Avatar
BuckyBoy
St. Jude Donor '06
Damn! Your right I ain't gonna read 13 pages to hunt for it. Wonder what the problem was cuz I still ain't?
BTW... did my answer sound knowledgeable...
Hope it was an easy fix.
PS. I was going to answer the question about the difference between a 4 & 2 bolt main, but now I'm scared!
To New crate engine is now a steam engine....bad problem...
Old Mar 11, 2006 | 12:09 AM
  #558
MsVetteMan's Avatar
MsVetteMan
Very close bucky, but not an easy fix.
Old Mar 11, 2006 | 12:15 AM
  #559
MsVetteMan's Avatar
MsVetteMan
I'm having a hard problem digesting this dyno testing crap.....
The advertise: "Dyno tested – and shipped with results"
Now a normal person would view this as my motor is going to be dynoed, and I shall receive a dyno sheet for "my" motor
The email reply I received when I questioned them on this says: "We run every Blueprint Engine on our performance dyno to make sure we
hit our target horsepower, and verify that we have the proper torque and
break the new engine in. We do not save the individual dyno charts.
WTF? You take the time to Dyno it, but you won't take the time to print the results and put them in an envelope?
Old Mar 11, 2006 | 12:17 AM
  #560
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
The email I received says: "We run every Blueprint Engine on our performance dyno to make sure we
I agree. That's blatantly false advertising.
