New crate engine is now a steam engine....bad problem...
Basically I now have to pull the head on the pass. side and report my findings. Asked the ole boy about "my time", and he said the do not warranty labor on self installs. If a shop with certified mechanics had put the motor in, then they would. [QUOTE]
Thats a croc of SSSSHHHit! Every engine manufacturer I have ever dealt with offers a flat rate for your time to remove and install a replacement engine. They are going too far having you do all this disassembly in your car so they can figure out IF they made a mistake. I would tell them that you will take it out and send it back to them freight collect so they can do their own troubleshooting and them file a claim at the local court house for reimbursment of your time and cost of the engine. Warranty of an engine cannot be restricted to professional installations only or they would not be able to offer a warranty to a private individual when they sell it to them.
Don't ask me how I know trust me on this one.
Kona
Kona
Whenever I install an intake I put a bead of RTV ( usually black ) around the water passages to prevent water from getting into the motor
Now me and ole Clarence have been getting along so far, but I'm about to get aggravated. Soon he will find out about this thread, but it's to early yet, so I'll bite my tongue a bit longer.
My .02 anyways
No gasket damage. But.....top of piston in #6 is broken off on the edge. Pics coming soon, but that still doesn't explain the water??
Now I'm really getting pizzed.....
Be back shortly with pics
Looking at their perspective. They more than likely think of themselves as a bonafide business and not trying to push faulty product on a customer. They build an engine and run it on a dyno. Everything is fine to their knowledge. Shortly after the end user puts the engine in an unusal problem occurs. They naturally think the end user has created the problem. They more than likely know they will have to eat some if not most of the repairs even though they feel the product was fine when if was boxed up. Once they feel the end user did not create the problem they should be more willing to take care of the mess and make things right.
By now, they should have given instructions on how to minimize any further damage to the engine. I would think the first thing is to clean up the milkshake fluid. Perhaps kerosene/Marvle Mystry Oil would clean it, drain it, change filter, fill with fresh oil, and pump fresh oil through with an oil primer. Do another oil change and prime before putting it back together.
this article actually gives the cleaning protocol
http://www.practicingoilanalysis.com...up=OilAnalysis
Procedure for Cleaning Glycol from Engines
A flushing procedure proposed by one major oil company to remove glycol from engine internal surfaces involves the use of Butoxy-Ethanol (trade name Butyl Cellosolve, Union Carbide). The flushing procedure for conditions of less than five percent glycol contamination is summarized below:
1. Drain oil from compartment and all lines and components.
2. Install new filter elements.
3. Mix an ISO VG 32 R&O mineral oil 50/50 with Butyl Cellosolve.
4. Use the mixture to turbulently flush (using an external pump installed at the turbocharger supply line or other suitable pumping method) internal surfaces by ample flow and volume for one hour at a temperature not less than 70°F (21°C).
5. Drain the system completely, mop out crankcase and replace filters.
6. Repeat steps 2 through 5, using a 60 percent R&O 32, 40 percent kerosene mixture.
7. Remove and inspect all main bearings, journals and other engine surfaces.
8. Remove the external pump and recharge with the correct lubricant. Replace the filter.
9. Monitor the engine carefully until all conditions stabilize.
Top of the piston is broken off???
ouch that sounds bad but how could that have happened on a brand new engine?
Pic of piston top....
More pics coming, having problems upload
Dayum.....
Sorry but there is no way in hell that did not overheat. Either that or you ****ed timing up real bad and it detonated, but theres no way it would detonate bad enough to crack a piston at idle on an N/A(****, even an FI) engine. You didnt notice a huge chunk of piston shoot out the headers after it bent your valves to ****?
Im gonna have some ***** and say its your fault. Sorry.
