Something that concerns attention....maybe nothing but I wanted y'alls input....Clarence got off the phone quick with me when I pointed this out to him in the pics I sent....
Look at the middle of portion of the gasket and their is a void underneath it. No way this could seal off, but not sure if it matters as this is a welded up port. Now look at the undershot of the intake.
On the older Chevy cyl head castings, that center port would be the exhaust heat crossover but I thought that with Vortec heads, that passage was eliminated. Definitely looks like the gasket doesn't match the cyl heads/intake. If it were heat crossover, you would definitely want the hole to have gasket around vs. how it appears in the picture. Also, if those ports were either for exhaust OR cooling, that would all have contaminated the crankcase (either with exhaust particulates OR coolant).
Is it possible that they did NOT install vortec cyl heads? The gasket is right for vortec heads. What is the casting number on the cyl heads?
I note the intake manifold and intake gaskets appear to be vortec but the cylinder heads are suspect.
So, perhaps bad/wrong cylinder heads used by builder...
Well old Clarence just called me back again (at least I have there attention) and said on the the next step. He showed the pics to the "guys" and they said the gasket were fine. I pretty sure they are gm vortec heads, but I'll get the cast number to double check. The valve covers bolt thru the center.
Basically I now have to pull the head on the pass. side and report my findings. Asked the ole boy about "my time", and he said the do not warranty labor on self installs. If a shop with certified mechanics had put the motor in, then they would.
Now me and ole Clarence have been getting along so far, but I'm about to get aggravated. Soon he will find out about this thread, but it's to early yet, so I'll bite my tongue a bit longer.
All of the intake passages are clean except for #6. It's got the milkshake in it. They appear to be Vortecs since they have the 4 mounting bolt holes. I also remember the valve covers are center bolt. Obviously be able to tell the root cause if the heads were to come off. I'll bet they tell you to send it back for replacement though. And just think, you get to install it all over again!!
Brett
You are probably right. My goofy, shadetree mechanic oversight. But, still strange the vortec intake gaskets appear to not fully match the cylinder head port configs/locations where intake meets cyl heads.
Hey Brett, I rather swap the head than and change a gasket than pull that dayum motor out again!!
But with that water/oil having permeated the engire crankcase, he may have damaged (rusty) bearings. I'd rather have a fresh one than have one that may be ok initially but live a shorter live due to the water intrusion.
Nice loophole!!
Call ole Clarence back and ask him if he would like a 355 ci blueprint sbc shoved up his azz. Thanks to him it's already pre-lubed with a mixture of oil and water.
If you ask me I would venture to say its the wrong intake gaskets. When I took the manifold off a 97 LT1, I seam to recall that center port on the head blocked off by the intake but sealed with the gasket.
That is what I would've thought also until I spied a photo of a vortec intake gasket on the Summit web site:
Show them this thread and have him read these replies. If it is legal, post the name and number of this business on this forum (if legal) so we can all can call "ole Clarence" to show this company we mean business.
I agree with you, for the vortec cylinder head used on the engine, that gasket would probably provide the best sealing as it appears to follow the shape and position of the intake ports better AND accomodates both vortec and old-style intake bolt patterns. From one of the cyl head pictures, it appeared the cylinder heads were tapped for both intake bolt patterns.
