Wires move with the cap...just move the rotor one or (probably) two teeth counterclockwise. You'll probably have to get the tool out and move the oil pump drive an equal amount to get the dissy to drop...
hmmm.... that sounds like poor parenting to me - but maybe he can overcome his past by doing burnouts at least twice a week (one of those times being well after 8:30 pm)
haha, poor parenting. trying to turn him into a rebel now eh? burnouts in the evening to **** the neighbors off. lol
If that's the stock 2 into 1 into 2 mufflers that thing sounds NASTY (good)
I think you're gonna be impressed when you hit that loud pedal!!!
Great job!
Don't forget to keep notes on where you set the timing and try different settings. Make comments in you notes about start up, pinging, engine temp and of coarse the Butt Dyno!!!
I wouldn't mess with the carb to much except for idle and if your eyes are watering at a light from the fumes. It should be pretty close out of the box for now. Then when everything is timed and running good you can have someone help you play with the carb. It gets confusing real fast if you never messed with one before.
Great job!
That is the set up!! Yeah I just dumped the oil and replaced. The passenger side headers are still glowing under a load. Gotta figure that out before I drive it.
Wow! I just now eased it around the block! Headlights on, breakes bled and working. I had to go really slow because the home made exhaust drags really easy but I am stoked!!' Oh! For se reason the Tach isn't working the wire to the dissy is connected also the alt (brand new) is not charging good and the Gen light is on. It is also connected correctly. Any thoughts guys?
