My first rebuild
http://tulsa.craigslist.org/pts/3309249298.html
it's all part of the learning process. The good news is now you get to buy the better summit rebuild kit that includes pistons and rings along with a bunch of other parts for a little it more money @$400Most of us dropped pistons (your luck it was an old one instead of new) we've broken rings, cross threaded bolts and even installed the piston in the wrong cylinder a time or two
The guys are right about slowing down, clean your work area and get organized.
You're at the point when you will be going to the machine shop to have everything checked out and get an idea of what needs to be done and you will be give specific measurements for your rebuilding kit. Piston size, bearing size and timing chain maybe???
The machine shop will need your new pistons to hone each cylinder to a piston and have the old pistons pressed off and new pressed on. This is the easy part. The machine shop will walk you through everything you need and may even assemble it for a good price. Your engine has good parts, why take a gamble on someone else's rebuild when you will know what what's in yours!!!
[/So you mean I am not the only person to drop a piston? Hahaha thanks brother I feel better. I think I will call the guy from the shop we use today and talk to him about what he can do for me on tha machining.
Hey Hugie82, do you have a suggestion on the transmission question I just posted?
Last edited by SuperBuickGuy; Nov 24, 2012 at 06:40 PM. Reason: slight correction to instructions
Stuff like that happens when you're not focused. I once poured oil into an engine without putting the drain bolt back in. I once installed a camshaft in a Pontiac 400 upside down (on a pontiac, the timing marks both go up, instead of top and bottom like a chevy, something like that, it was a long time ago) Just a few weeks ago, I rebuilt a Holley carb, and forgot to put the gasket on the power valve. Not really sure how that one got past me, but my point is this: All these things have one thing in common.......I only did them once. Everybody makes mistakes, but smart people learn something from them, that's all. The Pontiac 400 is kind of a funny story, we installed the cam, lining up the dots like you would on a chevy, 'cause we none of us knew any better, and when we went to try to start it, it was sucking air in through the exhaust pipes, and blowing it out through the carb, somehow! it didn't take us long to figure out what we had done wrong, and I learned a valuable lesson that day: Always read the instructions!!!!
Keep the shiny side up!
Scott
Scott
Scott
Minus the cost of your heads, you should be able to finish the short block for around $1000 and that's including cam,lifters and timing set. You'll just have to wait and see what the machine shop says.
I will say you work pretty fast for a newbie! Just remember, it's quality of work, not how fast you can blow through it
I've walked away with 3 pistons installed because I was making little mistakes ( dropping bolts, getting stuff dirty) come back to it when you're organized and focused with a good understanding of what you're doing from a YouTube vid or taking to us
one last bit about crate motors.... I've owned countless cars where I bought them because someone pulled out the motor "to do a quick refresh" then 5 years later, kids, life, boats, and stuff keep from them from finishing the car....
better is relative - You can spend vast sums on motors, but not necessarily have a better motor for your car.
Scott
OMG!!!!!
Do I have a mental problem or what?! Cleaned up and put things on hold for the engine and started cleaning in the engine compartment...Instantly!
I have a tone of work to do so I start surveying what needs cleaned and replaced, EVERY INCH! HAHAHA every piece of rubber, wire, paint, blah blah blah! Why can't I just say it's good enough and not have to get in every crevis!!! Am I just too picky or what? I really don't have the room to or the money to do a frame off on this little ride...
Don't worry guys I am not going too fast just venting! I only removed a couple of dust shields and scrubbed...
