My first rebuild
Old Nov 23, 2012 | 09:14 AM
  #61
FatCat's Avatar
FatCat
Originally Posted by scottyp99
Close-up flash photography can make things look a lot worse than they are. You can still see the cross-hatching through the scoring, and you say you can't catch a fingernail on it, I would be awfully tempted to not even re-ring it. Those bearings look almost new, too, I'd be tempted to re-use them. Key word there is tempted. The smart thing to do would be to take it to a machine shop and let them clean and magnaflux the block. They can also measure the crank for you and tell you what size bearings you need to order, and get some recommendations from them. Or, you could roll the dice! Get some Plasti-gauge, and see what the clearance is on the main bearings. I think most bearings will say what size they are on the back, if you want new ones of the same size. And you still haven't looked at the rod bearings. Who knows what might be going on there! It's looking good so far, though! I'd guess that since the main bearings look so good, you can be reasonably confidant that there hasn't been too much grit flowing through the oiling system. What did the bottom of the lifters look like? Any wear there?
BTW, don't get to thinking I am any kind of expert at all! I have had a hand in re-building maybe a half dozen engines in my whole life (not counting two-strokes, but they are a completely different animal) and they have all been kinda half-assed, (some more than others!)compared to what some of the guys on this forum are used to. Like SBG, for instance. When people start talking about 2500 horsepower engines, it's time for me to leave the room!
You'll probably want to order your rings and bearings as a package. Here's a link to a place that has some hard-to-beat deals:
http://www.northernautoparts.com/Pro...uctModelId=381
Keep the shiny side up!
Scott
Man brother, just based on my little bit of research and knowledge I would just paint and slap it back together. everything looks clean, no sludge at all, I don't see what I would call wear on the lifters. Maybe I can determine what this metal is today and I am going to run borrow a puller for the balancer so I should be able to pull the cam today.
Old Nov 23, 2012 | 09:18 AM
  #62
FatCat's Avatar
FatCat
Originally Posted by hugie82
If you are reinstalling the caps, they only go on one way but you can force them on wrong. Look and you'll see the cap for the rod is slightly offset. The mains have arrows pointing to the front of the engine.
Fatcat, there is NO STUPID question when you're learning !!! Ask anything that come to mind or before you try tackling something new...
I feel the same way! I can just see in my head someone sitting at home watching this thread thinking "this guy"
Nah! Just kidding, I really appreciate you guys help..
Old Nov 23, 2012 | 09:22 AM
  #63
FatCat's Avatar
FatCat
Hugie82 - Do you have anythoughts on the picture of the plug I posted with 50 miles on it?
Old Nov 23, 2012 | 09:36 AM
  #64
FatCat's Avatar
FatCat
I thought I would post this for you guys to see. It is what was left in the pan after I pulled it. I did take a magnet and the were a couple of larger (pin head size) pieces that I used it on and they were magnetic. When I was draining the oil there was just a steady silver streak running out of it.
Old Nov 23, 2012 | 10:37 AM
  #65
scottyp99's Avatar
scottyp99
When you took the main caps off, how did the crank look? Shiny, with no scratches? The little particles that are magnetic are steel or iron, they come from wear on the cam, lifters, cylinder walls, rings, maybe the distributor gear on the camshaft, or the timing chain gears.....all sorts of things. They are the bits that will cause damage to bearings and bearing surfaces. The non magnetic pieces are probably either bearing material or piston material, which is cause to be concerned. There are some pretty big chunks in that pic, but like I said before, close-up, flash photography can make things look worse than they really are. There may be a correlation between the cylinder scoring and the iron filings in the oil. Is it possible that this could be a freshly re-built engine, and this is the wear from the initial break-in? Doesn't sound likely, but I want to make sure. I would like you to carefully (don't slice a finger off!) cut open the oil filter, and tell us what you find in there, better yet, post a pic or two. I'd also like to see what the rod bearings look like, but that can wait until after the cam is out. If you have a really bad rod bearing, the corresponding crank throw will probably be scratched up, meaning, at the very least, a trip to the machine shop to be polished or or machined smooth. This will mean different size bearings, so don't go buying anything yet.
Here's a few articles on budget re-building an engine:
http://www.carcraft.com/howto/ccrp_0...d/viewall.html
http://www.carcraft.com/howto/116_03...d/viewall.html
http://www.carcraft.com/techarticles...k/viewall.html
You are elbow deep in a small-block, are you feeling like you're in over your head yet? Don't worry, we've got your back, as long as you keep sending the pics and asking the questions! Besides, it's too late to turn back now.......mua-ha-ha-ha-ha-ha!!!!!
Scott
Old Nov 23, 2012 | 10:47 AM
  #66
FatCat's Avatar
FatCat
Scott
How do I cut the filter in half without getting metal shavings in it?
Old Nov 23, 2012 | 10:54 AM
  #67
AirborneSilva's Avatar
AirborneSilva
Why worry about the filter at this point? Get the short block to the machine shop and have them look it over
Old Nov 23, 2012 | 11:58 AM
  #68
birdsmith's Avatar
birdsmith
Interesting thread...figured I'd post a few thoughts fairly quickly since I've got the day off and I need to go out and get to work on my own Vette...
(1) You're getting a lot of disparate (Look that up) opinions here...stop, and order yourself a copy of David Vizard's "How to Rebuild Your Small-Block Chevy" from HP Books. About $9.50 at Amazon.com. An absolutely INVALUABLE resource that will help you sort out the poseurs and BSer's from the people that really know what they're talking about.
(2) If I was you (And I HAVE been you in the past, except I wasn't lucky enough to start with a 4-Bolt, forged piston motor) I would view what I am currently seeing as a minor failure that can be corrected fairly easily with a few rather inexpensive parts-rings, bearings, gaskets, maybe some freezeplugs, and possibly a camshaft+lifters.
(3) If you make the commitment to continue with what I and a couple others are advising here, you also need some tools that are over/above simple hand tools. Harmonic balancer puller, torque wrench, cylinder hone, ring compressor, ring groove cleaner, piston ring expander, a carefully-sharpened putty knife, small medium-cut half-round file, some jeweler's files, baggies/ tape/ sharpie for labeling parts...all I can think of for now.
(4)Since it does appear that there was some detonation going on, you will want to get whatever large parts you intend to re-use magnafluxed to check for potential cracks (Block and heads). Don't know what kind of relationship you have with your local machine shop(s), but if they're like most they will want to charge you upwards of $50 to clean those items before they will magnaflux anything. Not necessarily cheap, but a good idea. If, however, they are using the old method known as 'hot-tanking', which uses a caustic soda ash for cleaning, your cam bearings will be destroyed by the process, necessitating replacement. If they use the newer/ kinder/ gentler 'jet-clean' method, your cam bearings can be saved. Just a heads-up; this is what you can expect.
(5)(This is just me)If it WAS me, I would take that motor completely apart, get the block and heads cleaned and magged, clean up the pistons and crank, lightly hone the cylinders myself, grind the valves (best for you to leave that to the machine shop), replace the cam with one recommended by one of the forum gurus that will work with your heads, and put the whole thing back together with new rings and bearings AFTER reading Mr. Vizard's book from cover-to-cover.
(5a) THIS WILL ALL COST A FEW BUCKS. If you are not willing to spend at least the minimum necessary, you cannot expect to obtain a satisfactory result.
(6) So far it looks like you have handled this matter from a careful and intelligent point of view. Continue doing that, don't get ahead of yourself, keep your BS sensors on full gain, and you'll be fine...
...my $1.380
Old Nov 23, 2012 | 12:16 PM
  #69
SuperBuickGuy's Avatar
SuperBuickGuy
Originally Posted by FatCat
that is the deepest scratches I have found and they will not catch a nail. SBG, is there a place I can watch a video or something on how to re-ring? Do I need to hone the cylinders? I am going to get a puller in the morning, I also have not figured out where the metal in the pan came from.
Can I get ring at a local part store (anything special) or do I need to order them?
how to rebuild your small block chevy by David Vizard. I like David, he's a really nice guy, guru at EFI, and regularly published in Popular Hotrodding magazine.
You can get rings at your local store, I'd advise against because cost-wise, you can save big bucks buying online from Summit/Jegs/Speedway or any of the other large parts houses.... and do take advantage of their tech support when you order - simply call the one of your choice, and let them walk you through the process.
In buying parts, the big boys - Felpro, Mogul, etc are known quality and I like their products - not perfect, mind you, but odds of getting good parts are really high with them.
As for the metal in the pan.... check the distributor gear for excessive wear. But a bit of metal isn't the end of the world - it could be from piston wear as well.
Old Nov 23, 2012 | 12:17 PM
  #70
63mako's Avatar
63mako
St. Jude Donor '08-'09
Looking at your cylinders and leakdown numbers I would get it torque plate honed instead of trying to do it yourself. Hope your bores are within specs to reuse your pistons.
with getting vizards book.
Old Nov 23, 2012 | 04:57 PM
  #71
FatCat's Avatar
FatCat
Just checking in! How does the tension look on this chain? Is it too loose?
Old Nov 23, 2012 | 04:59 PM
  #72
FatCat's Avatar
FatCat
Got the cam out...Here's what I got...
That says CWD
That says 30 as best as I can tell
What say you? Does this tell you anything? Scotty Do I need to send your cam home?
Old Nov 23, 2012 | 05:26 PM
  #73
63mako's Avatar
63mako
yes. It should be way tighter than that. Might have been align bored last rebuild and they used a stock chain. There are undersize chains available to correct this.
Old Nov 23, 2012 | 07:14 PM
  #74
hugie82's Avatar
hugie82
If they all looked like that it could easily be bad valve seals. A lot of guys take short cuts on the heads when they rebuild their engine. The timing chain is cheap. Try a stock one first before ordering a custom length. If it still has slop in it you can always sell a stock chain set
You do know you can't use that cam and lifters again if you mixed up the lifter order. They develop a wear pattern when new and it can't be broken in again especially with today's **** oil
The small block rebuild book is a good idea or a good manual will work. So now let's check the numbers on the rods are clear and start popping pistons out
Old Nov 23, 2012 | 07:17 PM
  #75
scottyp99's Avatar
scottyp99
That says CWD
Fatcat, settle down, will ya?
We are not making any decisions just yet. We are gathering information. Once we have gathered the neccessary info, then we make decisions. I know, I know, you've got ants in your pants, but try to settle down. Haste makes waste, look before you leap, and all that.
Re-read birdsmith's post, and follow it, to the letter. It sounds like the best advice you have gotten from anybody so far. Actually, the second best advice, the best advice is me telling you to follow birdsmith's advice!
I can't view the pics of that cam from the computer I am using here at work, but even if I could, it probably wouldn't mean much to me, one cam pretty much looks like any other cam to me. When I get home, I'll take a look and see if they tell me anything. In the meantime, does the distributor gear look like it has a weird wear pattern? How about the timing gear and chain? Mako says it looks loose, that might be the source of your iron filings. Uh-oh! A thought comes to mind. With all that iron, combined with bearing material, in the oil, I have been waiting to see a really bad bearing. I'm wondering now if what you were describing before wasn't detonation, but maybe.........the dreaded rod knock! I hope not! I hope you take those rod caps off and find nice shiny bearings!
To cut the filter open, poke a hole in it with a hammer and a nail, and cut it open with some sheetmetal shears. AirborneSilva is right, really, it doesn't really matter, it's more of a curiousity thing than anything else. I'm sure you are curious, too. And be careful!
Something to think about: Guys like me, who have only built a very few engines, and always on a budget, like to tell guys like you to take shortcuts to save money. We have slapped together a few engines, maybe even only one, and taken shortcuts to save money, and it has worked for us. (well, except one engine, I spent over 5 grand on the 440 for my Roadrunner, and that was back in 1988, and I assembled it myself, so that's not even counting labor.) Many guys who build lots of engines have learned the hard way, that when you roll the dice, sooner or later, you're gonna crap out. Be advised, that when you take shortcuts to save money, you are taking a risk. How much risk are you willing to take? How much money are you willing to spend to mitigate risk? These are questions that only you can answer.
Scott
Old Nov 23, 2012 | 07:25 PM
  #76
hugie82's Avatar
hugie82
A lot of cams will have stamped on the end with a grind number or part number but if you didn't keep the lifters in order the cam is junk...sorry nothin you can do.
I'll give you a tip that I always use when I venture into something new. Google images and YouTube are awesome when it comes to seeing little tricks of the trade. Something simple like installing pistons with a ring compressor becomes a major PITA unless you watch the video and go Ohhhh, that's how ya do it
Old Nov 23, 2012 | 08:29 PM
  #77
FatCat's Avatar
FatCat
It's all good!!!! I did not know you could use a cam if the lifters got out of order but I assumed you could use the lifters if they did...Unfortunatey I wasn't thinking and started to flip the engine and forgot about the lifters and 3 fell out. I put them back in order the way I felt they cam out but they could be wrong...
So here are all the pictures after completely torn down. I will say this, I am starting to think I maybe shouldn't have done this. not because I am overwhelmed but because everything looks to be in good order. Cylinders look good, bearings no real wear that I can tell ect.
And now I have a broken piston!!!
To My first rebuild
Old Nov 23, 2012 | 08:32 PM
  #78
FatCat's Avatar
FatCat
I am going to check into downloading the book tomorrow!
Old Nov 23, 2012 | 08:40 PM
  #79
FatCat's Avatar
FatCat
...my $1.380
I am too far in not to be commited! I knew going in I was going to have to spend a little or a lot depending on what I found.... I appreciate your compliment and am really trying to handle this right!
Old Nov 23, 2012 | 08:59 PM
  #80
scottyp99's Avatar
scottyp99
I distinctly remember telling you to keep the valvetrain parts organized in case you wanted to reuse them, especially the cam and lifters. This is the kind of thing that happens when you get all exited. Oh well, there no point in crying over spilled milk, you can get flat-tappet cams and lifters relatively cheap, let's keep moving forward. But, at a slower pace. We got aaaaaaaall winter to do this thing, so just simmer down.
Now, what's all this about a broken piston? One minute you are lamenting that you shouldn't have torn the engine down, because it looks so good inside (that's called 20/20 hindsight) the next, I'm hearing about a broken piston? I can't view the pics here at work, maybe I'm missing something that makes it all clear. I'll take another look when I get home around 1 AM.
Scott
