My first rebuild
We got aaaaaaaall winter to do this thing, so just simmer down.Now, what's all this about a broken piston? One minute you are lamenting that you shouldn't have torn the engine down, because it looks so good inside (that's called 20/20 hindsight) the next, I'm hearing about a broken piston? I can't view the pics here at work, maybe I'm missing something that makes it all clear. I'll take another look when I get home around 1 AM.
Keep the shiny side up!
Scott
Scott
thinking the same thing about the piston, did it fall and break? gotta see those bearings anyway to just to be certain since you got the engine out of the car.
Are they better than what I already had? I was so *@#^ when I did that! I just hope this doesn't make it even more difficult for me to do. Referaing to having to put the pistons together now....
I guess someone better tell me how to measure main bearing, pistons, rings and rod bearing sizes.
There sure is a lot of little stuff in that package!
I bit of caution - you said "it looks good" as bearing measurements are measured in .0001 and your eyeball can do, at best, .03124 (1/32).... you've a ways to go before you can use the term "looks good."
Bearings can be reused if you keep them in order; but you still need to check their dimensions before you make that determination (plastic gauge)...
Also, measure your pistons to verify roundness and wear.... another, don't ask me why I know this *&(*&^^!!! Vega motor
I won't ask how you know, we can leave the knowledge you have as it is! You are just really smart.
If you go onto the linik I provided, you'll see that there are options that you can check off. One of them is flat-top, hypereutectic, 1.560" compression height pistons. I think those are the ones you will want. They are what I would get.
OK, let's start keeping score: So far, we have destroyed a piston through carelessness, and ruined what was most likely a perfectly servicable, already broken-in cam and lifter set, also though carelessness. Am I the only one starting to see a pattern here?
Try to be more careful! What's done is done, spilled milk, learn from your mistakes, blah, blah, blah........
Scott
The good news is I work for a shop and send alot of work to a machine shop, I do have a guy who might help me out of the bind I am in. I don't like to discuss my project at work because my boss thinks it means I am not focused at work and the guys I work with really don't like to talk shop after hours.
Scott
Still
there is no law that says this motor must go back into your Corvette, nor is there one that says you cannot rebuild the one that is not going back in your Corvette.
And
It's always best to rebuild your buddy's motor so you can learn what not to do when HE is stranded beside the road.
last of all
it's a 350 Chevrolet - Starbucks sells parts for them with your morning espresso (okay, maybe I'm exaggerating a bit.... but still, the parts are plentiful and cheap)
Take a break from the engine for awhile. Clean and paint your engine compartment. Go slow and be careful not to wreck anything in the engine compartment. Don't laugh, there are brake lines, wiring, suspension components, some of which can be delicate, so take it easy. Don't be too hard on yourself, we are moving forward, not dwelling on the past, but still learning from our mistakes, got it?
Scott
Still
And
My plan was to replace the cam if needed and piston rings..I am thinking now that ole boy selling rebuilt 350's on CL for 1300 may not be a bad option.
last of all
http://tulsa.craigslist.org/pts/3309249298.html
Scott
oh they're (mods) going to hate me, but there's a GM performance motor from Jegs that costs $1,500 and is completely a brand-new motor. It comes with 76 cc heads, so you swap to vortec heads and you'll raise the compression to happy land; add a cam and you have a brand new motor... sell the brand new heads on Craigslist and the cost would be a wash. Chevrolet Performance 10067353 - GM Goodwrench 350ci/260HP Engine & Packages
And I would spend $200 more for a motor from a company I trust and has a warranty every time. Oh yeah, and currently with free shipping
Still
5.3, junkyard motor would be comparable..... and you'll learn how to install a different (but not too different) motor.
http://www.summitracing.com/parts/na...make/chevrolet
It's a pretty good deal, for what your getting.
Scott
Scott
