My first rebuild
I bet if you experimented with the paint gun settings you could get rid of much of that orange peel I know I did.... and I used harbor frieght paint guns... went through 5 different brands and types of guns before I had the best luck with the cheaper HF one.... the pricier ones I had required more air and my compressor couldnt keep up well...
ALSO watch a lot of youtube videos on painting....THEY HELP!
BTW soda blasting wont harm the body or glass windows and rubber for that matter... it just removes the paint...
Thanks!
It was so tight it ended up being kinked a little which I guess as it warmed from running heat, it must have kinked closed. I'll just have to look at it and see what I can do. I was thinking if I could see a picture, I could save some headache.
Pete
http://willcoxcorvette.com/product_i...roducts_id=559
Pete
Good luck...
Rogman
Good luck...
Rogman
and it really doesn't take long to sand it because all you're trying to do is get it flatter
or
you could do like a friend did, not sand the orange peel - then sand through the clear to the base so the car looks dull no matter how much you wax.
Understand that with extra reduction comes extra likelihood for getting runs and sags, so when shooting vertical surfaces you don't want to lay the paint on too heavily, with the first coat being light. This gives successive coats more of a 'tooth' to grab onto, so it's less likely to run. ESPECIALLY with clearcoat, it's IMPERATIVE that the first coat go on as no more than a fog coat. Every time I've tried to lay a full wet first clearcoat down I got a ton of solvent pop, and you don't want that because the only way to fix it is to sand it out and reshoot it, which is a total waste of expensive paint. It's tempting to rush out a blow down a gallon on the first coat, but you have to resist that temptation if you're going to get a good result.
My own experience is that it's not necessary to sand basecoat even if there's a little peel in it, but the best finish I had with clear was to apply it (3 coats), let it cure for two or three days, sand out the peel with 600 grit wet paper, then lay on two or three more coats. It then flows on almost perfectly level and requires very little color sanding to get to where it can be polished, and it polishes up to an absolutely stunning finish. But to do a whole car that way would require an absolutely insane amount of HARD work...
That's what my wiper door looked like after this process...I wasn't about to do it to the whole car. Too much farkin' WORK!
