Borgeson Install
Old Apr 7, 2014 | 08:00 PM
  #201
Roadster71's Avatar
Roadster71
Originally Posted by irelandr
Thanks. I was also thinking since I am putting the rebuilt pump in I would hook the hoses up there first and maybe try to start them in the box as well before I mount the pump. Alternator is off and exhaust pipes are off and thinking of removing the exhaust manifold if it would help. (Automatic so not clutch linkage to worry with) Any thoughts on all that?
You shouln't have to remove the exhaust manifold, I didn't. The only interference I had was the side pipe exhaust and brake line.
Old Apr 7, 2014 | 08:57 PM
  #202
irelandr's Avatar
irelandr
Thank you, did a 700R4 swap (still working on it and a new radiator so pretty much down to the water pump on front and have exhaust except manifold off. Was changing the transmission and crawled under the car and a steam was coming from the steering box, looked like grease and water mixed and the cylinder and valve were soaking wet so decided to do the borgsen at the same time... while I was at it...
Old Apr 13, 2014 | 04:35 PM
  #203
'Bochawa72's Avatar
'Bochawa72
I just got mine in the mail and have a few questions before I tear into this. I want to make sure there are no clearance issues with either the box or the rag joint. I have a small block with the Hooker SuperComp side mount headers. I saw someone HAD to get the U-joint because the rag wouldn't fit. Can anyone confirm if this fits with my setup and will I need a U-joint? I want to make sure I have all the parts I need before I start, it takes too long for stuff to get shipped here to Italy. Thanks!
Old Apr 13, 2014 | 05:04 PM
  #204
commander_47's Avatar
commander_47
I have hooker long tube headers and have no clearance issues. I can run my finger all around the box.
Once I got the column collapsed, and the measurement was really close, I took the rag joint apart.
It is pretty easy to mount the two halves of the rag joint to the column and the box. Then I loosely mounted the box in place, and bolted the rag joint back together.
Make sure you have it aligned pretty close before trying to bolt the two halves back together.
I didn't worry at all about the steering column simply because I took off the steering wheel and realigned it when the job was over.
I had to use the little adaptors on the box for the lines. Also, be prepared to really tighten down on those hoses, both on the steering pump and the box. I found that mine were totally leak free when the big vein in my neck stood up. Vein torque wrench
Oh yeah, one final tip. The hose clamp that comes with the kit for attaching to the power steering pump is too small. You will need a slightly larger one. Make sure you have it when you start otherwise you'll be hunting for one or wasting a lot time trying to get the small one to fit.
Old Apr 13, 2014 | 05:07 PM
  #205
bebezote's Avatar
bebezote
error...sorry dont want to hijack the thread..will start a new one..
this forum is a wealth of info...many thanks to all the experts here!!
Old Apr 13, 2014 | 07:34 PM
  #206
PeteZO6's Avatar
PeteZO6
SBC. I too have the Hooker Super Comps, under car type. I have about 0.5" of clearance between the #7 pipe and the rag joint. If the side exit Hookers are radically different in that area, you need to do more research.
Hope this helps
Pete
Old Apr 16, 2014 | 08:31 AM
  #207
pace1978's Avatar
pace1978
This could be a dumb question, but will installation affect the tilt or telescope fuctions of the column?
Old Apr 16, 2014 | 08:33 AM
  #208
Sacred Steel's Avatar
Sacred Steel
No.
Old Apr 22, 2014 | 07:41 PM
  #209
jman1's Avatar
jman1
does it matter what line is connected where on the new box? I got my new box all in.. just need to connect the hoses... also if anyone has a pic on how the ran the hoses...
Old Apr 22, 2014 | 07:51 PM
  #210
Roadster71's Avatar
Roadster71
You can only hook them up one way, they are two different sizes.
Old Apr 22, 2014 | 10:49 PM
  #211
Shark Racer's Avatar
Shark Racer
Wouldn't this impact turn signal cancelling?
Old Apr 22, 2014 | 11:16 PM
  #212
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Scanned most of the 11 pages but could not find any reference to hydroboost setup being used with the borgenson system.
Anyone doing this?
Any additional problems/challenges with running both?
Great thread btw. Nice work by the OP.
Bman
Old Apr 23, 2014 | 12:16 AM
  #213
Shark Racer
You'll need more lines if you do hydroboost. I think it may be easier w/ hydroboost in there, as the booster somewhat gets in the way of running the lines on top of the box.
Old Apr 23, 2014 | 05:00 AM
  #214
aussiejohn's Avatar
aussiejohn
Default I've got both.
Anyone doing this?
Bman
Bman,
I have a '74 with a Hydroboost and a Borgeson box, and it works fine. I also have a Holden VY master cylinder with integral proportioning valve. All I needed was a 6mm spacer between the HB and the MC so as the rod had about a millimetre of slack before engagement. The aluminum MC weighs 1.1 kg, the stock cast iron MC weighs 3.7 and the distribution block on the chassis (which I removed) was about half a kg. All up I've saved over 3 kg and have a better functioning brake system.
Regards from Down Under.
aussiejohn
Old Apr 23, 2014 | 10:47 AM
  #215
bmans vette
I am confused by your reply.
Are you saying it would be easier with hydroboost?
Txs
Originally Posted by aussiejohn
Bman,
aussiejohn
Thanks for the info John.
Bman
Old Apr 23, 2014 | 11:49 AM
  #216
Shark Racer
Txs
Postulating. Getting at the lines on the box is somewhat of a pain in the *** with the vacuum brake booster in the way. The hydroboost system would definitely free up some room so you could see at it with more angles and get your arm in there easier, etc. You have more lines to deal with, but the ones on the booster should be trivial to install compared to the ones on the box.
Old Apr 23, 2014 | 12:09 PM
  #217
jman1's Avatar
jman1
Where's the little brass pieces go? Thanks.
To Borgeson Install
Old Apr 23, 2014 | 12:32 PM
  #218
widowmaker221's Avatar
widowmaker221
Those are compression fittings and they mount on the box where the hydraulic lines attach.
Old Apr 23, 2014 | 12:39 PM
  #219
Les's Avatar
Les
If you look at post #205 above, in the photos you can see where the lines connect to the top of the Borg box. You can also see the yellow plastic plugs that were in those holes before the lines were connected. The brass pieces go into the box where the hose fittings thread into it. The smaller part of the brass piece goes in first and the larger part seals against the hose fitting- you can see how the shape matches the flare of the hose fitting. I used the end of a ratchet extension to gently tap the brass piece into place. Then I test fitted the hose fittings to seat them.
Old Apr 23, 2014 | 04:40 PM
  #220
APV's Avatar
APV
Default Borgeson power steering pump
Hello, my car is a 1966 roadster was non-power steering, 327/300HP. I'm in the process of installing the pump and brackets. My instructions were lost @ my engine builders garage. My body is off the car so this makes things a little easier. I have two questions.
1. why are my studs on the pump leaking. Do the stud nuts go between the bracket with additional nuts and washers on the outside of the mounting bracket. This is a Borgeson pump.
2. I bought my pulleys from Vintage air. The pump pulley is on number 3 pulley farthest from engine. The pump pulley does not line up perfectly with the # 3 crank pulley. It looks like the the miss-alignment is less than an 1/8" can I somehow shim the pump to correct this. I do have the pulley GM numbers if that will help..
Thank you,
Al
