Borgeson Install
Old Mar 18, 2015 | 02:48 PM
  #281
Greatsteaks's Avatar
Greatsteaks
Originally Posted by Stephen Irons
Well, this is an interesting thread. But, having read what’s required I'm happy to admit that the fitting of a Borgeson system is not a job I’m up to!
So, way back near the beginning of the thread someone mentioned sticking with a rebuilt PSCV from “Gary R”. So, who is Gary R, please?
If you can pull your stock box in and reinstall a rebuilt one yourself, you can Handel the Borgeson conversion.
Old Mar 18, 2015 | 03:44 PM
  #282
Roadster71's Avatar
Roadster71
It's not much harder than a stock box. Basically unbolting the old and bolting in the new. There is even less parts to reassemble.
Old Mar 20, 2015 | 12:56 AM
  #283
BLUE1972's Avatar
BLUE1972
The hardest part will be shortening the column. I soaked mine for a few days and used the " freeze off" penetrating oil. It then moved fairly easily.
I just helped a friend do his and we did the same, soaked the column for a week. The install was pretty easy, even with the motor in the car. We did it in one day, and he loves the change.
Old Mar 21, 2015 | 07:42 AM
  #284
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
Ok, a bit of a confession! I came to this thread via one on the P/S Control Valve and I was still in “PSCV Mode” when I saw the note about “Gary R”. I have no intention of removing the steering box, but I was considering rebuilding the PSCV. Maybe it’s an “English thing”, but I have to say I think knocking seven bells out of the column to get the Borgeson unit to fit is real “bubba stuff”!
Old Mar 21, 2015 | 09:01 AM
  #285
65GGvert's Avatar
65GGvert
You are mistaken. The end of the column slides up inside a larger column as it is designed to do. You can slide it up or slide it down to the length you need. If you think adding power steering by changing out the steering box for one with only one pressure hose and only 12.7 turns lock to lock to a car is bubba, you must hate performance mods entirely. If you had a Borgeson, you wouldn't have to do anything under the car to try to fix your power steering or plug your leaks. Maybe it's an "English thing" to call anything they don't have or want "bubba stuff"?
Old Mar 21, 2015 | 12:34 PM
  #286
PeteZO6's Avatar
PeteZO6
Well said!
Pete
Old Mar 21, 2015 | 01:52 PM
  #287
Stephen Irons
Well, if the column slides, I am indeed mistaken. But reading through all the posts here it seemed to me that everyone had had to work hard to collapse the column, using hammers etc to do so.
But, it's all accademic really, as my car doesn't have leaks and never has. The little "dampness" I see on the PSCV once in a blue moon doesn't really count!
Old Mar 21, 2015 | 03:20 PM
  #288
65GGvert's Avatar
65GGvert
The same kit for a 65-66 requires cutting the end off the column, but the 67 up collapses. Sometimes you may have to break it loose if it's been sitting a long time, but mine slid easily, no hammer required. It's a pleasure to drive now after having the hardest manual steering car I've ever owned.
Old Mar 23, 2015 | 09:53 AM
  #289
BLUE1972's Avatar
BLUE1972
I agree it's the hardest manual steering car, but that is due to our "new" tires. The original tires were F70-15 which would be a 205 or 215/70-15. Most cars today have a 235 / 70-15 or 245/60-15 which is a lot more rubber on the ground especially with manual steering.
The tires today are also gripper and thus do not slide like the old tires.. thankfully..
Like I said previously .. JUST BE SURE TO SOAK THE COLUMN (IF NOT REMOVING IT) AND WIRE WHEEL THE SPLINES.. and the install will be easy. (C3)
Now the wife / sig-other can move the car or help driving back from a car meet - if needed.
The cost is less than installing the "stock setup" to convert to power steering. The response and feel is also better.
Old May 3, 2015 | 03:01 PM
  #290
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I just removed all the stock steering parts yesterday on my 74 big block. I can only hope the install goes as good. My column moves in and out easily so that's a good sign. I'm hoping the Borgesen fits with that 454! I'm looking forward to staying in my own lane finally!
Originally Posted by Frankenvette
Great Job. One thought... I noticed in the pic below that one of the hoses is resting on top of the borg box. I ended up with something similar, so I went to local auto parts store and picked up some radiator hose that is large enough in diameter to wrap around the hose that is touching the box. Don't want a hose failure due to rubbing. Just a thought.
Old May 3, 2015 | 04:19 PM
  #291
commander_47's Avatar
commander_47
Try and post some pics. I'm getting ready to do this with a 454 myself.
Old May 3, 2015 | 08:21 PM
  #292
diehrd's Avatar
diehrd
The column will easily compress , I just did mine and the first tap had it done with ease .
Old May 3, 2015 | 08:25 PM
  #293
samdjr74's Avatar
samdjr74
It didn't take much to get mine moving either. Just be careful of the splines.
Old May 4, 2015 | 09:47 AM
  #294
fotyfobravo
It will be a couple weeks before I have time for the install but I'll update when I continue.
Old May 4, 2015 | 10:43 AM
  #295
zwede's Avatar
zwede
The Borgeson does fit with a 454.
Old May 4, 2015 | 12:03 PM
  #296
Les's Avatar
Les
...and a 427 with Hedman headers that have 2" primary tubes.
Old May 5, 2015 | 09:40 PM
  #297
BLUE1972's Avatar
BLUE1972
I installed the pump today, the pulley is 1/4 inch off, outward. I filed the mounting bracket and now it's less than 1/8" off.
There appears to be a lot of play in the pump inward and outward, It's tight left to right. Will see in a few weeks if it leaks or not,
Other than the miss-alignment it was an easy install.
To Borgeson Install
Old May 6, 2015 | 02:21 AM
  #298
terrys6t8roadster's Avatar
terrys6t8roadster
After having mine for the second season there a few comment I'm going to make .
Maybe I have a bad directional switch, but with the quicker turning ratio it seems that I don't turn the wheel far enough to activate the cancelling when I make a turn.
Also cannot have the ignition shielding on at the drivers front. If shielding is in place you'll need to jack up the engine to remove shielding to access the spark plug. T
Old May 6, 2015 | 07:07 AM
  #299
65GGvert's Avatar
65GGvert
Don't have either of those problems with my 72 350.
Old May 7, 2015 | 12:31 PM
  #300
BLUE1972's Avatar
BLUE1972
Today I noticed that the mounting bosses on the block appear to be further out on the 71 than my 72,
I put a stud in the holes and used an end mill with a center hole to cut back the bosses .125 total. the pulleys line up much better now, It would have probably been ok as stock , but with the car apart it's easier now.
I do agree that the return tube on the pump should be turned around to look better, but it works fine as is .
