My rubber rag joint failed after 1 year so I replaced it with a solid joint, I'd recommend everyone does the same from the start.
If you first go with the rag joint, then decide later to go with a solid U-joint, does the steering column need to be collapsed (or expanded) to a different position?
What is the gain? I have ran the conventional pump/control valve/ram style power steering found on C2 and C3 Corvettes and 1950's and 1960's passenger cars and never had any leaks after resealing the control valve and the ram. Sooner or later the Borgeson will also leak so then what? Change back to the "better" OEM parts that are far easier and cheaper to work on? Just because the Borgeson is "different" that doesn't make it any better.
The Borgeson only has two hoses, one pressure one return. They go directly to the box, nothing is under the car. Fewer possibilities to leak. It also has a 12.7:1 lock to lock. If you don't want to use it, fine. But you don't have to run something down because it's "new" or different from yours. I bet you run radial tires.
You must be one in ten million owners to have had no leaks. This forum is full of owners complaining about the old tech, leaky system used on C2 and C3 Corvettes.
The Borgeson is not a unique, unknown design. It is an integral power steering box designed by Delco Remy for all GM car lines EXCEPT Corvette in the 60s. The then-current integral box was too large physically for the Corvette. Borgeson merely tool a later, smaller, lighter, intregal Delco Remy box designed for lighter, smaller vehicles, i.e., certain Jeep models.
It cleans up the under hood area, lessens leaks, gives a better steering feel, and quickens the steering ratio. What's not to like?
You don't have to like the idea, and certainly don't have to fit one to your Corvette, but many, many Corvette owners have made the switch and are happy with the result.
Pete
We all have different opinions on what's better. My stock system leaked horribly, the feel was crap and it was a PITA to work on. The new Borgeson set up is easy, two hoses and a steering box. The feel is much better than stock and the car is more pleasant to drive.
Focusing on whether the stock power steering leaks or not is missing the point I think. The real gain with the Borgeson unit is the drivability ,you just can't compare the two .Find someone who has done the conversion and have a short drive in their car you will be amazed
I have both a 71 and 72. the 71 has the Borgeson unit, the 72 the cylinder. The difference is day and night. The 71 handles so much better and responds faster, less drift and pull. If your not NCRS the conversion is the way to go.
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Finally started the borgeson kit.
So far so good. The new ragjoint lined up perfectly. I had to dremmell the steering shaft just a little to get the ragjoint to start on the splines. Borgeson sent the wrong hoses and I bought this kit almost a year ago so I didn't bother trying to get it swapped. I just got the correct hose from Summit. I can't wait to hook it all up and see how it drives!
One question....do the brass fittings need to be dropped into the holes before the hoses are threaded in?
There are 2 brass fittings for the steering box I just popped them in then put the 2 plastic caps back on installed the box then when ready o put the hoses on just screwed them on with the brass fittings in position
Awesome idea! I'll do the same! Thanks!👍
I would suggest installing the fittings while the box is still on the bench. Mine were tight going in and if the car has pb its hard to press them in with the pb booster in the way once in the car.
I just put mine in with my finger then put the hoses on, no issue.
Use a 1 or 2" wire brush in a drill and clean the shaft & splines. It makes life easier.
[B]The most critical part of the install is to make sure the steering box and the steering wheel are both at center... I marked them then slid the rag joint on the shaft. [/B]
Pretty sure my ragjoint is positioned within a spline or two of center. Should be close enough for a good alignment guy to center easily. Thanks. I'll update results when I finish. I look forward to having a big block that actually steers like my Miata! 👍
Awesome write up! Thanks so much! The heat and dremmel trick saved me when putting the new ragjoint onto the steering shaft! 👍
I'm taking mine to the alignment shop next week.
What was the DEGREES of caster they recommended???? I know it's slightly different from normal. I've lost that paperwork with that info !
Originally Posted by Mr.Green
Excellent question. Due to the machining of the splines on the steering box, there are only 4 possible ways to put on the pitman arm. I rotated the steering box through it's full range of motion and counted the turns and placed it halfway between. I would have had to be off by about 90 degrees to mess it up, so I figured I was safe.
This is a picture of the splines on my old steering box. The Borgeson box was machined to match these:
If you notice, there are larger gaps between some of the splines. There are four of these gaps around the thing and your stock pitman arm should match the pattern.
Grab as much caster as you can... It will help your handling at a slight increase in steering effort.
Caster aids tracking straight and in returning the wheels to straight ahead after cornering. With all the boost the Borgeson gives, you won't notice an increase in steering effort.
Pete
