Blow by Question
Old Jan 3, 2022 | 01:15 PM
  #41
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
So I moved the vac hose to the out port on the can. Capped off the top port and connected the pcv hose to the in port on the can since that port has a screen built into it. I’ll test drive after work tonight. Also put the breather back in on the other valve cover. Thanks for all the help on this. After I drive it I’ll check the dipstick again to make sure it’s staying out.
Old Jan 3, 2022 | 04:46 PM
  #42
REELAV8R's Avatar
REELAV8R
Sounds good.
Old Jan 4, 2022 | 10:12 AM
  #43
diehrd's Avatar
diehrd
I am one of the few on this forum who push venting the crank case. Its a big deal because it prevents gasket failures and keeps the oil clean. One of the easiest and old school ways was by using the exhaust. Using a kit like this one. And the best way is to use a vac pump. Which adds up to 20 plus hp.
https://www.summitracing.com/parts/s...QaAgZ2EALw_wcB
Old Jan 4, 2022 | 01:00 PM
  #44
Bluesting70
So I took it out for a spirited drive with the changes described on my prior post. Now the dipstick pops out again like a quarter inch. It’s like it helps to have both valve covers connected to vacuum? Any thought? I don’t want to not have the breather in one for wot conditions. Should I connect it back but put a breather filter at the top of the can instead of blocking it off? Or maybe back off the block off cap a little to have a let out for wot conditions?
Old Jan 4, 2022 | 01:10 PM
  #45
REELAV8R's Avatar
REELAV8R
The cap you are using for a vent only has a small 1/2" hole or so as a vent correct?
What if you used something like this;
Amazon Amazon
Or maybe even more free flowing like this
Amazon Amazon
With all vacuum and no vent and your dipstick did not pop up I would conclude that you are pulling a fair amount of vacuum at WOT? Only explanation I can think of for the engine not popping that dipstick out in that configuration.
Just to clarify, when you say "spirited" driving does this mean WOT operation? Or is it just aggressive driving?
I don't see that vent on the catch can providing much venting given it's coming though a 3/8" line to get there.
Old Jan 4, 2022 | 01:14 PM
  #46
Bluesting70
https://www.amazon.com/Edelbrock-440...68098744&psc=1
https://www.amazon.com/Spectre-Perfo...a-569070190009
When you say "spirited" driving does this mean WOT operation? Or is it just aggressive driving?
I’m using the exact cap on your first link. I haven’t tried a free flowing one but had that same thought. Like you, I thought it might be pulling enough vac at wot. I’ll try a free flowing one next. If that doesn’t work I’ll go back to the original set up and monitor things.
Old Jan 4, 2022 | 01:16 PM
  #47
Bluesting70
spirited as in aggressive driving. Probably no more than 4500 rpms or so
Old Jan 4, 2022 | 01:36 PM
  #48
REELAV8R's Avatar
REELAV8R
Ok, that explains why your all vacuum to both sides worked. You still have manifold vacuum @ 4500. But apparently plenty of blowby too. You can try a different vent, I would go with as free flowing as possible for that motor. Or you can go back to all vacuum if you want, as long as you never really go WOT operation. But that does not seem like a very good permanent solution IMO.
You could take your current vent and drill it full of holes to see how that works. All along the bottom like you see on this one.
Amazon Amazon
This would make a mess but what if you just put a piece of hose in that vent hole in the valve cover for testing and see if the dipstick pops up then? Maybe stuff a bit of that steel pot scrubber in the hose to keep the oil venting down. The idea is to test to see if that side is allowed a nice free flow of air if the dipstick still pops out. If it doesn't then go buy a good free flowing vent for it.
Notice on the Spectre vent that the bottom hole is large. Maybe 3/4" or so. Something like that. Many of the vents I've seen have a built in grommet and the hole in that grommet is very small. Defeats the purpose of a good vent. You may even need to mod something up to get adequate flow.
Old Jan 4, 2022 | 02:02 PM
  #49
Bluesting70
Thanks. We think a lot alike. I was thinking of leaving it unplugged but your suggestion would make it cleaner with a hose and filter for a test drive. I don’t want to have wot issues later so that’s not an option for me. The breather you posted is the exact one I have. It’s the larger diameter although I can’t remember the holes size. I’ll check later but I think it’s the largest one I can use.
Old Jan 4, 2022 | 02:18 PM
  #50
REELAV8R's Avatar
REELAV8R
I thought the one I saw in the pics looked like this
Amazon Amazon
In either case drill the holes or if it has holes make them larger perhaps.
Old Jan 4, 2022 | 02:30 PM
  #51
Bluesting70
https://www.amazon.com/Edelbrock-441...00CN52TY&psc=1
I had that one when I was running to the can both sides. I have others in my stash and 2 mr gasket ones with the holes all around.
Old Jan 4, 2022 | 02:32 PM
  #52
Bluesting70
Great suggestion on makes the holes larger. I’ll give that a shot too
Old Jan 5, 2022 | 02:02 PM
  #53
REELAV8R's Avatar
REELAV8R
sounds good, report back what happens if you can.
Old Jan 5, 2022 | 02:38 PM
  #54
Bluesting70
I will. And thanks again for your help. I went ahead and ordered the open air breather. I’m going to wait for that later this week.
Old Jan 5, 2022 | 03:49 PM
  #55
REELAV8R's Avatar
REELAV8R
What PCV are you using currently? If it's not appropriate for the engine (most are not unless stock motor) it's not going to be drawing a vacuum as it should through the power range.
when you had full vacuum to the engine it did not pop up the dipstick and you were not even full throttle. so that seems to indicate that the PCV in there now is not appropriate for the engine perhaps as it is not adequately evacuating blowby.
Yes, as pointed out it's only a 3/8" line but it's under vacuum, 21" or better for any motor much above idle. 30" is equivalent to 14.7 psi. So if you want to look at it that way then the PCV provides a good 10 psi of vacuum above idle.
Venting is a passive method of controlling blowby. So it's going to take a much larger hole to passively vent and engine (the crankcase has to blow the vapor out) vs sucking out the blowby pressure. Not to mention, we are venting through the oil drain back holes in the heads, then out the valve cover, so those drainback holes provide a restriction to venting as well.
You may want to look into that Wagner one I linked earlier if you want better evacuation below WOT.
Edit: forgot about the whole lifter Valley and past the pushrod holes to the valve cover, lol. So no, the drain back holes are not a restriction.
Old Jan 5, 2022 | 04:34 PM
  #56
djquik1's Avatar
djquik1
Dumb question but at the angle it looks like any engine movement or hose movement would cause a hose to touch the dipstick top, is it doing that and then breaking the seal so to speak and the path of least resistance pushing the dipstick out?
Also a leak down test would be beneficial and point you in the right direction
Old Jan 5, 2022 | 05:12 PM
  #57
REELAV8R's Avatar
REELAV8R
This is a relatively new engine, correct? When you ran two breathers you didn't have the dip stick popping up. Was there a lot of oil misting under the hood on the valve covers and exhaust manifolds prompting the change to venting?
To Blow by Question
Old Jan 5, 2022 | 05:24 PM
  #58
Bluesting70
Not likely as it was pushing out the stick before this et up too.
Old Jan 5, 2022 | 05:30 PM
  #59
Bluesting70
Yes. New crate 383 with less than 2k miles. Probably much less than that actually. No oil misting when I had the 2 breathers. Baffles in the covers worked well. I could always go back to that but I like the idea of pulling the blow by out as it seems like the engine would get better aspiration and maybe better performance. Again, I’m not an expert here, just a guy that loves doing this stuff as a hobby.
Old Jan 5, 2022 | 05:59 PM
  #60
REELAV8R's Avatar
REELAV8R
Same here. Not an expert. And am willing to try many different things to solve an issue. if it starts to look like a real mechanical problem then I go looking to see what's up. Until that I look for the simplest solution.
The lack of excess oil misting leads me to believe that you do not have a serious mechanical issue. Just a bit of extra blowby to manage.
