Cam choice
The caveat is I probably could make it work if I bought it cheap enough and had it gone over by a reputable machine shop and refreshed. That or get lucky and stumble into that desirable motor that nobody knew was valuable and you got it for a bargain and it works forever. If there were 10000 tickets and I bought 9999, I'd still not win.
I would much rather trust an engine full to the top with original parts.
I wouldn't. Good parts are one thing. Put the best parts into a motor and it can still be a POS if the assembly isn't there. OEM is designed for one thing. Mass production.
SO many have produced over 800 horsepower using the stock engine, there are reliability lists all over the web regarding these facts
https://ls1tech.com/forums/forced-in...lity-list.html
https://www.corvetteforum.com/forums...lity-list.html
http://www.ls1gto.com/forums/showthread.php?t=401429
Assembly is actually very difficult to achieve because FSM procedure no longer applies, and many aftermarket companies assume the "assembler" is going to be able to figure out how to modify their parts (such as connecting rods) from an unacceptable out-of-the-box condition.
And it almost never happens.
The new supercharged LT4 has forged pistons but you ain't gonna find one in the junkyard let alone for $500. It has a forged crank to. Chevy knows that's what's needed for a boosted engine or they wouldn't use it.
I give that " reliability list" a 20% credibility rating because I can read at least 20% of it is true.
You must consider a couple different perspectives for this to come together as a risk/reward scenario.
Most of the builds from the list are done cheaply with poor tuning and cheap parts. I am not advocating cheap parts or poor tuning. I am showing you that even with poor tuning and cheap parts, there still exists a "reliability list". The mere fact a list like that continues to propagate is a sign that the engine in question is worth a second look.
Ex. Do you think the stock engine that went 184mph in the 1/4 mile is going to last 100,000 miles?
There are some people who just want to break records, even if the engine only lasts 1 run.
From their perspective, it is cheaper to buy X stock engines and keep replacing those engines, than it is to build a proper engine in the first place. These guys are "racing themselves". Many of them have tried built engines with forged pistons first and failed, only to return to stock bottom ends as being "more reliable". I would suggest some research on this matter to help dismantle "forged fever". The hypereutectic piston's major weakness is its easy-to-break nature, one mistake can ruin it. ONE mistake. And yet so many of these engines with poor tuning and 8 cylinders persist for so many miles, it must be a very forgiving engine to tune.
Perspective 2:
For us "daily driver enthusiasts" it is far more useful to look in terms of miles vs output, rather than max power vs drag strip runs. I like to use "ten year statistics" or 100,000 miles (10k/year of driving) as a standard. Also, Supercharged engines should not be considered. The power they draw from the rotating kinetics of the engine is unaccounted for at the rear tires, but still count's in the making. In other words, a 600 horsepower supercharged engine is really a 680 horsepower turbocharged engine, but the supercharger draws 80 horsepower (or more) from the engine at that power level. That extra power makes all the difference to the bottom end staying together, and to the condition of the bearings in the engine. Strike those example from the list and we get something useful:
If the proper statistical analysis is performed against a 10year/standard w/ turbocharged, those engines with poor tuning and cheap parts producing between 500-600 horsepower that started with 100,000 miles have more than 98% probability to go another 100,000 miles.
In the 600-700 bracket, engines with poor tuning and cheap parts which started with 100,000 miles have 92% chance to go 100,000 miles.
We can't, or shouldn't, perform any analysis on engines which achieve higher than 700 horsepower because of the sporadic nature of results at that power level, which I attribute to poor tuning and cheap supporting parts still. The engines can't be blamed for these issues and that power level is unnecessary for the majority of budget daily drivers anyways.
This is the best probability of any engine ever made, that is available for less than $1000. I thought the same thing as you when I first encountered the idea, but time and results changed my mind. There are plenty of people not on that list, with 5.3L engines that I've personally tuned and seen myself, even with cheap parts (and good tuning) that are still going today, after a couple years of service at 600 and change. I came to the conclusion that if I could get one to last 50,000 miles @ 500 to the wheels i would be quite happy for those 3-4 years of daily driving. If it even goes half of that I will consider turning it up along the way to 600 and change. Since a next stock replacement is "sitting on the shelf" in case I make a mistake and need to go back to the 500 range ($1/horsepower for 5 years) the next day.
And believe it or not, the 2jz-gte 3.0L engine actually has a better regression, more mileage and higher power is possible. The only reason I chose the V8 instead was because the 2jz is three times the cost and more than twice as difficult to find spare engines for.
Perspective 2:
. Well yes there some or I can believe there are some people that will keep trashing junkyard motors. I actually met a couple of street racing buddies that raced the same Pontiac firebird with rebuilt motors from a local shop. They boasted the local shop continually provided cheap Pontiac cores. I can remember this because of the way they advanced the cam. They would use the non-adjustable timing set that came with the core motor and just advanced the crank gear one full tooth. When I counted the gear teeth that would have been something like 18 degrees IIRC.
Well as far as racing to trash the motor goes that's something that NASCAR does but with expensive, purpose built engines. In fact new rules limit the number of engines a NASCAR team can use in the same season. But I'm sure their investment is over $50,000 each motor.
But for the rest of us trying to save enough for retirement a cam change makes the most sense to begin to improve performance.
The same way $2500 per engine Nissan 2.0L and Toyota 3.0L can go 200,000 miles with factory cast piston turbo application @ 80horsepower/cylinder.
Nonsense, nonsense!
Nonsense, nonsense!
Nonsense, nonsense!
It's pretty easy to turn power down. Just put a bolt under the pedal...
A lot of time and effort can be spent, nickle and dime a motor for power. The same gains can be had with the twist of a dial on the console- or by driving below sea level. The risk is reduced because now the engine can make peak VE or better at the same or lower RPM than with the cam swap.
In other words, 400 horses is 400 horses. Whether it comes from cam or boost is negligible, and the camshaft actually moving redline up makes it less desirable. Nickles and dimes are less desirable. Parts that stay with the engine are less desirable. If we put an expensive head/cam/intake on the engine then starve it for oil accidentally- I could lose all those parts, plus now anything I saved needs to be transferred to the new engine. I hope you can see why I, after performing 100+ cam swaps, prefer to use a stock engine instead.
