IPOD2 Car
Old Jan 16, 2008 | 08:18 PM
  #341
longdaddy's Avatar
longdaddy
Originally Posted by Midwest Vette
I just installed a ipod2car in my 98 Vette with the GMH20T & PXHGM1 harneses. The scroll function using the click wheel is not working correctly. It is damn near impossible to get where you want to go. If I disconect from the ipod2car it works perfectly. I have a new ipod classic 80 GB.
So far I am having no luck trying to get in contact with Peripherals Tech support.
Please help!
Same problem with my 3rd gen nano, however my old mini does not disable up/down function when plugged in. Someone told me this came down as a firmware upgrade for certain ipod versions. it sucks.
Old Jan 16, 2008 | 09:05 PM
  #342
IAIA's Avatar
IAIA
Just get a mini-cable from the earplug jack and be done with the hassle. Charge it up every few days and you're golden. By the way, Peripheral told me the AUX2CAR unit will work with either cable, as long as you get the right size connector...there are two...a larger one and a smaller one (round jack out of the Peripheral box). So, an AUX2CAR will also work with an iPod cable! even though they don't say that. And the iPOD2CAR may work with the miniplug cable but you should ask them.
Old Jan 17, 2008 | 08:17 AM
  #343
Midwest Vette's Avatar
Midwest Vette
I did get a hold of tech support, he told me that they have a new & improved version of their box. I called mp3mycar. They said no problem send it back & they will send a new one.
Old Jan 17, 2008 | 01:06 PM
  #344
longdaddy's Avatar
longdaddy
sweet (although I am not looking forward to opening up the console again)
could you post (or pm me) how you got ahold of them?
Old Jan 20, 2008 | 06:57 PM
  #345
Z06Aggie's Avatar
Z06Aggie
Having some trouble here. First, the PHXGM1 cable that they sent me has different tabs than the factory cable, as shown below. It does not fit in the back of the stereo.
Second, I plugged everything back in as normal, and the radio is now dead. No lights, nothing. WTF?
Old Jan 20, 2008 | 07:12 PM
  #346
Z06Aggie's Avatar
Z06Aggie
Found a blown fuse, so that fixes the second problem.
Old Jan 20, 2008 | 07:17 PM
  #347
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Hi,
I am not sure what cable you got. The PXHGM4 is the cable that hooks up at the back of the stock stereo. It looks like this.
You are hooking up at the back of the stereo, right?
Old Jan 20, 2008 | 07:33 PM
  #348
Z06Aggie's Avatar
Z06Aggie
Looks just like that but says GM1, not GM4. Just my luck.
Old Jan 20, 2008 | 07:36 PM
  #349
Z06Aggie's Avatar
Z06Aggie
...........and bring on the Aggie jokes
Old Jan 20, 2008 | 07:40 PM
  #350
Cozmo's Avatar
Cozmo
No, I feel your pain. It sucks when you get everything apart and realize that you were sent the wrong cable. I got the wrong one the first time also, the PXHGM2 which plugs into the CD changer. I don't have a CD changer.
I was unable to get the correct cable from the ebay vendor that I bought the IPOD2CAR from. I had to get it here.
http://www.discountcarstereo.com/detail.aspx?ID=952
Old Jan 20, 2008 | 07:42 PM
  #351
Z06Aggie's Avatar
Z06Aggie
I went to the C5 FAQ section of the audio forum, and it hooked up correctly by the way they show, but it doesn't work. It shows the ipod is charging, but when you hit Aux on the stereo, it won't switch over. I'm about to crack open a beer and do some thinking
Old Jan 20, 2008 | 07:54 PM
  #352
Cozmo's Avatar
Cozmo
What if you hit the play button on the IPOD?
Old Jan 21, 2008 | 08:42 AM
  #353
Midwest Vette
I called them at 800 505-0931
Old Jan 22, 2008 | 01:36 PM
  #354
Z06Aggie's Avatar
Z06Aggie
Still couldn't get it to work last night, and I blew another radio fuse, so I had to quit. This "Easy DIY Job" is turning into a PITA!!
Old Jan 22, 2008 | 09:17 PM
  #355
IAIA's Avatar
IAIA
Bummer. Not sure why you're having such a problem. One thing I found was that the iPOD wasn't initially being "recognized." I had to plug and unplug the cable between the iPOD and the box a couple of times and it finally worked. No doubt you checked your connections a bunch of times, but just in case, I thought I'd bring that up......
Old Jan 22, 2008 | 10:41 PM
  #356
Choreo's Avatar
Choreo
I have a 2001 Coupe without the CD Changer, but it sounds like "some" C5s have the CD Changer CABLE installed anyway. Is there a quick way for me to verify that I do or don't have that cable installed?
Old Jan 23, 2008 | 11:27 AM
  #357
Cozmo's Avatar
Cozmo
There are the 3 storage compartments in the back of the car. Look in them. I believe that if you had the cable it would be in the compartment on the left.
To IPOD2 Car
Old Jan 23, 2008 | 12:42 PM
  #358
IAIA's Avatar
IAIA
Mine actually snakes down the right side...but the "official" mount site is in the inside, center rear of the trunk area. At least that's what a technician told me when he saw my CD Changer in the right-hand compartment.
Old Jan 23, 2008 | 12:59 PM
  #359
Cozmo's Avatar
Cozmo
Thanks. Not having one I was going from memory of seeing my friends. I guess I'm old and have CRS!
Old Jan 24, 2008 | 07:55 PM
  #360
AMRAAM's Avatar
AMRAAM
So, I received my ipod2car and my two cables, one for the ipod bottom connector and one for the 3.5mm jack. I set everything up the way I wanted so that I could switch between the 2 cables fairly easily. modified the hole in the console where the cig lighter goes so the cables could run into the console.
I hooked all up and the head unit doesn't seem to recognize the interface. The destructions mentioned that it may take up to 3 minutes to recognize it, but it never did. All I am supposed to do is hit the CD/AUX button on teh head unit right?
