Stealth Light Cannons: Development process
Old Oct 20, 2009 | 04:16 AM
  #181
JohnTheStigGalt's Avatar
JohnTheStigGalt
The projector lense (is it lens or lense? I can never figure that one out) is designed (if I'm not mistaken) to stand up to some "abuse" kind of like a fog light? Ever hear of a foglight lense busting from a rock? I haven't. If the shroud were color matched, that'd be no different (exposure-wise) than the old headlight cover. I just think that given how nice it looks with the tubing (and just a little bit of extra work to finish it off), the BPP-style lense would be totally superfluous! If the lights are sealed, unless they're really fragile (which I doubt), they should be quite durable. You gain nothing perceptible in terms of aerodynamics with a separate lense. Aesthetically it's irrelevant, since the lense is practically invisible.
Obviously the manufacturing cost on this project is SIGNIFICANTLY increased by the BPP-style lense. That's a huge cost per unit for virtually no benefit. How many more units would he sell (which from 10 feet away would look IDENTICAL and should hold up just as well) if the price were say $745 or $695? I think the answer to that question is obvious!! LOTS AND LOTS!!
[Do LOVE that Zonda! ]
Old Oct 20, 2009 | 04:20 AM
  #182
EFI-1's Avatar
EFI-1
+1. I'd love to see it at a lower price point as well....
Old Oct 20, 2009 | 04:47 AM
  #183
Quik Z06's Avatar
0Quik Z06
Former Vendor
I totally agree, a lower price would definitely move ALOT more. Lol, if I manufactured these I would try to get the price as low as possible, but I dont. I do think no lens (lense) would be sweet as well if as mentioned they were a bit more finished. However that's up to George.
Old Oct 20, 2009 | 04:58 AM
  #184
Quik Z06's Avatar
0Quik Z06
Former Vendor
Some pix I found (hope you dont mind George)
Old Oct 20, 2009 | 05:02 AM
  #185
AustinVetteFan's Avatar
AustinVetteFan
Juste fore thee recorde, it'se lense...withoute thee 'ee' one thee ende!
er...
Just for the record, it's lens, without the 'e' on the end!
And I've always kinda liked the popup lights on the C5, and love the Light Cannons. But George, I must say that I'm just about sold on the Stealth Light Cannons. Can't wait to see the finished product!
Aloha,
Larry
Old Oct 20, 2009 | 08:36 AM
  #186
TurboBerserker's Avatar
TurboBerserker
2 thoughts:
1) You should strongly consider shaping the area above the projectos slightly. The best would be follow the lines of the tubing along the top of each projector, making them taper back. It would be very easy to do with filler, and would compliment the hood lines nicely.
2). My other thought is - why have the lenses at all? If the projector is sealed, they're really unnecessary, and just add a lot of cost. Specterwerks has a similiar no-lense headlight, but yours is FAR superior due to the "stealth" design.
The tubing does look good, but that can't be the only detail/shaping with or without a lense. Trust my artist's eye on this one.
I agree on both counts -- Maybe the lens can be an option? Now if the shroud was more C6-ish, I'd definitely want the lens, but as it is...
Old Oct 20, 2009 | 09:30 AM
  #187
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
2 thoughts:
Definatly true. Remember this is still in stage 1. I will be using body filler to mold the rest....sanding by hand
The Projectors are weather sealed however the lens does offer both aerodynamic advantages, is easier to clean road film off of and IMO painted ABS doesn't look the same as the rest of the car's body.
er...
Larry
the "e" on my keyboard sticks.....lole
you can choose not to install the lens however the shroud is designed around the lens which will leave a small gap between the hood and shroud.
Old Oct 20, 2009 | 10:05 AM
  #188
ssmith512's Avatar
ssmith512
Looking FANTASTIC!!!!
Please keep the lens. I think your price point is very reasonable for a "custom" designed, "hand made" option that NO ONE ELSE OFFERS. You are not gonna please everyone all the time.
I am only painting the shroud body color, the lens will remain clear. (Thinking about applying some 3M Clear Bra to the lens for added protection and scratch resistance).
Secondly, VERY glad you decided to redo the shroud. Shroud Version 1.1b (LOL) looks much much better.
Quick question, I am leaning heavily towards the Halo option, is the shroud design the same with or with out Halo's?
And I think I should get an extra special super deep discount for being the first on the list.
Steve
Old Oct 20, 2009 | 10:11 AM
  #189
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Steve
I'm designing the shroud so that the Halo rings will fit the base shroud. I just Ordered a set today for testing. The Halo shroud MIGHT require some minimal trimming or additional forming but it shouldn't look significantly different. The Halo rings are 79mm OD and the face of the projectors are 80mm so asthetically there should be no structural difference. The halo rings will be glued to the projector face.
Old Oct 20, 2009 | 10:32 AM
  #190
ssmith512's Avatar
ssmith512
Sounds good!
Old Oct 20, 2009 | 11:22 AM
  #191
Lancejoker's Avatar
Lancejoker
I'm hoping the finished product looks a little bit different for $1250. I've been waiting months for these.
Old Oct 20, 2009 | 12:35 PM
  #192
FreddyG's Avatar
FreddyG
If you look at all of the OEM's, they have the plastic over the lenses (in a capsule probably because they're easier/cheaper to make that way).
I'd keep the plastic cover. It does raise the cost of the lights, but it also protects the optics inside. While you may have never heard of a rock hitting the lights, I have and it wasn't cheap to replace (BMW light around $1600, but their stuff is WAY overpriced)!
You could make the cover optional for the peeps that are willling to chance it and save some money. Personally, I'd never buy them without a cover, but that's my .02 and you get what you pay for!
I also agree that a set of eyebrows over the projectors would look pretty cool and make the lights have a more finished look to them!
Once again George......Great work!
Old Oct 20, 2009 | 02:52 PM
  #193
Quik Z06's Avatar
0Quik Z06
Former Vendor
George...Money sent!! Reserve my spot buddy
Old Oct 20, 2009 | 04:09 PM
  #194
CUlookin's Avatar
CUlookin
I'm not gunna lie I was hoping for a bit more contours on the shroud. As I poster earlier, I would love to see it look similar to the C6's, especially with the bezels of the projectors showing...
It just looks so clean, especially if you could do away with the ribs. Not sure how much space you're dealing with, so I'll just keep to myself over in a corner .
Old Oct 20, 2009 | 04:16 PM
  #195
Quik Z06's Avatar
0Quik Z06
Former Vendor
^ I agree, that does look good, but as is there isn't much space to work with. Either way I think just having a flush projector will be killer.
Old Oct 20, 2009 | 05:41 PM
  #196
Lancejoker's Avatar
Lancejoker
I'm right there with you. That's exactly what I was hoping for.
Old Oct 20, 2009 | 06:23 PM
  #197
IM28702's Avatar
IM28702
+1. I was really looking forward to this deal (though the cash is still a bit elusive), but the inner shroud really turns me off. I love the placement of the bulbs, the low sleek design, but that shroud is begging for more contour up top. I would also go for a more concave curve as it ramps up to the top in difference to the convex shape you have now.
Please don't take this as anything past constructive criticism, I think you have done a bang up job so far. Bravo. Bun in all honesty, that shroud would stop me from buying them. Maybe we can't see the subtle detail in the mock-up and the final product will be awesome... I'm just going off what I see here.
To Stealth Light Cannons: Development process
Old Oct 20, 2009 | 07:00 PM
  #198
ls1impulse's Avatar
ls1impulse
Just looking at that C6 picture it almost looks like if your slid a piece of PVC over the projectors, and had a cut piece similar to what you already made stick out past the end of the the lower front of the projector; your could probably get a killer shroud made by thermo forming a sheet of plastic over the entire setup.
Old Oct 20, 2009 | 08:07 PM
  #199
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The biggest issues with contouring as much as the C6 are clearance with the main lens and the shape of the projectors themselves. I would love to have done more shaping but that would have compromised structural integrity or function.
I did shave off another 1/2" on the projector cutout tubes to make teh piece look a little more appealing. keeping with the smooth lines and shape of the C5, having a bunch of sharp edges just doesn't match the rest of the car's looks.
I'm running a littlee low on my photobucket bandwidth so i will post up pics of the finished mold tomorrow.
Old Oct 20, 2009 | 08:27 PM
  #200
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Very close to commiting on the advance purchase, but what about blinkers. Can you do a mockup to show how integrated blinkers would work.
