ebay Header Install
Old Apr 18, 2007 | 12:16 AM
  #781
RIP1976's Avatar
RIP1976
I'm holding him for ransom. Just give me a phone # to SS and he dosen't get hurt!
Old Apr 18, 2007 | 12:20 AM
  #782
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
this is all i got:
SSAUTOCHROME, INC
817 Beaver Dam Road
Creedmoor, NC 27522-7107
Old Apr 18, 2007 | 12:58 AM
  #783
RIP1976's Avatar
RIP1976
Come up with more info quick I'm warming up my crematory. lmao!
Old Apr 18, 2007 | 01:15 AM
  #784
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Cheese and rice! I finally get some sleep and wake up to a damn nightmare!
LOL Good lord! Where to start!!!!!!!!
Old Apr 18, 2007 | 01:21 AM
  #785
tstar's Avatar
tstar
OK RIP... I fired off an urgent EMail to my contact concerning your AC line... I also cut and pasted your PM into it.
But between you and me a 1" air gap is pretty substantial. I actually don't know how you got that much! I have maybe a 1/4"...
  #786
tstar's Avatar
tstar
Originally Posted by RainJ
this is all i got:
SSAUTOCHROME, INC
817 Beaver Dam Road
Yeah they won't give me a phone number either...
Old Apr 18, 2007 | 01:32 AM
  #787
tstar's Avatar
tstar
Threw codes, but my 02 sensors looked like hell (Plus the exhaust shop pretty much had to re-do everything we did last night and STILL could not get it to line up very well)
It was lots of work on their part while on the lift and cost my $120.00 in labor and effort - OUCH!
BUT, they are on -
I reved it a few times in the parking lot and got code 0151
O2 Sensor Circuit Low Voltage (bank 2 sensor 1)
It was sputtering and popping and giving me weak jitery throttle response.
Turned around and went back to the shop.
Jacked it up on one side -
slid under..
Pass side, front O2 sensor looked ok.
Was connected as best I could tell.
Got down the road and within a mile or so, the car ran great.
Smooth shifts, nice tone, and plenty of response when I gave it gas.
I get it home, shut if off.
Crank it up and same deal again - weak throttle, sputtering and mild popping on deceleration.
Just checked codes again (after washing her)
And cleared them:
0131 -o2 sensor Circuit Low Voltage (Bank 1, sensor 1)
0151 - o2 sensor Circuit Low Voltage (Bank 2, sensor 1)
0302 - Cylinder 2 misfire
THEN it gives me odd codes that are not in my book:
8367
6d2d
3600
Rain,
It sounds like the muffler shop has your O2 sensor wires crossed... left side goes to the left connector, right side right... with the way the O2s come off the collector it's easy for someone to cross them.
Your 0302 is more then likely a cracked plug. But check your new wires also. Maybe the ole laying of the plug against the intake trick (except our intake is composite... LOL)?
Here's the deal, the O2s typically won't give you grief until after the warm up period, but you have a combo problem of O2 and an ignition break down somewhere... so you're running crappy right off the bat.
I'm curious as to why it started running good a mile down the road though, that seems to coincide with the O2 warm up period, but I may be off base on that... But I think this is a clue someone smarter then me should pick up on...
A good trick for finding a dead hole is to use one of those infrared temp sensors, the dead hole will be cold compared to the rest of the Header runners. I think Pewter had a coil wiring issue but yours doesn't sound like somethig that substantial.
BTW one of my cracked plugs, I couldn't even see the crack until I flexed the plug...
Old Apr 18, 2007 | 01:41 AM
  #788
tstar's Avatar
tstar
Rain,
Is that 3600 maby this;
DTC P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
Old Apr 18, 2007 | 01:47 AM
  #789
RIP1976's Avatar
RIP1976
I was probably going overboard on the 1" its probably more like 1/4" I'm just so agravated that I have to buy a new hose and remove the header and reinstall it when I know its the wrong header.
Old Apr 18, 2007 | 01:53 AM
  #790
tstar's Avatar
tstar
Well don't do anything yet... especially re-installing that Header!
Old Apr 18, 2007 | 02:36 AM
  #791
RainJ's Avatar
RainJ
I''ll have to check the wiring but yes, a good chance that the pass side is connected to the driver's side wire and vice versa..
probably did it because thats the direction the sensors' connectors were pointed.
new plugs - and yes, mabe a chance we cracked one.
I cleared my codes and will check it out tomorrow (later today)
Old Apr 18, 2007 | 03:17 AM
  #792
tstar's Avatar
tstar
You guys do realise that I will never EVER answer another Header thread again!
Old Apr 18, 2007 | 11:08 AM
  #793
RainJ's Avatar
RainJ
yea, no kiddin!
Old Apr 18, 2007 | 11:22 AM
  #794
PewterMetallic98's Avatar
PewterMetallic98
You guys think it might be a good idea to go to an exhaust shop and have them heat up the passenger side collector real well so that they can bend it more towards the block away from the A/C line? Just trying to prevent any problems with the damn A/C line burning!
Old Apr 18, 2007 | 11:53 AM
  #795
tstar's Avatar
tstar
99% of the time if you have a slight airgap on perpendicular lines like this it should be OK... RIP is that 1%.
Old Apr 18, 2007 | 01:39 PM
  #796
STOCKER's Avatar
STOCKER
mine is maybe MAYBE 1/4" too, I just hope mine is going to be ok. It's so hard to get a visual w/ the tube there. I'm going to have to bend mine a bit more if possible.
For the person who asked about bending the header, I dont see how you can, the tubes are right on the bellhousing as it is and you dont have much room to bend or even room to work.
Dave
Old Apr 18, 2007 | 02:14 PM
  #797
tstar's Avatar
tstar
You know this AC thing is nothing new, the original Headers were just as close to the AC line also. Maybe it would help to get a long term update from one of the "good ole boys" so to speak. I suspect that it really hasn't been an issue. Although that doesn't help RIP right now...
I just want to get him fixed before he plants one of us 6' under!
To ebay Header Install
Old Apr 18, 2007 | 02:19 PM
  #798
tstar's Avatar
tstar
Dave
Yeah it would be easier trying to clearence just that one primary...
Old Apr 18, 2007 | 02:32 PM
  #799
tstar's Avatar
tstar
OK here's what I got for the new re-design... please PLEASE update/add or do whatever! This will be the final go around with these I'm sure... I just hope I can pull it off. The one in **'s is a maybe.
Add Oil Dipstick Nut
Add the A.I.R. Tubes
D – 2nd Primary
P – between the 4th and 3rd primary on a TEE
Remove the mounting tabs
Lower Passenger O2 bung, OR re-locate both bungs further up the collector facing the hood (straight up)
Add a wedge into the Passenger collector to move the outlet inboard about 1”
** Clearance or re-route primary for AC line**
Old Apr 18, 2007 | 03:09 PM
  #800
RainJ's Avatar
RainJ
ok
my O2 sensor wires were reversed.
driver's side was plugged into Pass side wireing clip and vice versa.
just did an interstate run - MUCH MUCH MUCH BETTER!
I stil feel a bit of restriction and Im curious if its the cats..
got a 9 hr road trip to BowlingGreen in the morning -
Let ya know when I arrive and how the trip went
Rain
