Oil Catch Can Question...
Old Dec 2, 2006 | 04:57 PM
  #61
berryj's Avatar
berryj
I have a related question, not to hijack this thread though! I just installed the NLP catch can on my 99 w/ A&A Procharger unit. I hooked the pcv line into the upper fitting of the can, then connected the lower fitting to the pcv valve housing which then connects to the intake manifold.
I see two different posts on how to do this. One is the way I said above, another is to have the pcv valve upstream of the catch can before the first tube inserts into the top fitting of the can. Guess it doesn't matter much, but I'd like to see what u all think.
I found it easier to hook it up as I stated above since it's a tough 90 deg turn on the tubing if I try to hook it up w/ the pcv valve upstream of the can. That valve apparatus doesn't move much since it has the securing wire attached to the engine block.
Thanks for the input!
Old Dec 2, 2006 | 05:10 PM
  #62
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Logically the location of the PCV valve in the loop should make no difference.
On another note, with your supercharged application, you have other areas of consern, but I'm no expert. Call Andy over at A&A Corvette, I'm sure he would have additional input.
Old Dec 2, 2006 | 06:19 PM
  #63
RonVette2's Avatar
RonVette2
[QUOTE=berryj]I have a related question, not to hijack this thread though! I just installed the NLP catch can on my 99 w/ A&A Procharger unit. I hooked the pcv line into the upper fitting of the can, then connected the lower fitting to the pcv valve housing which then connects to the intake manifold.[QUOTE]
That sounds about right to me, and I think that I too hooked mine up that way, although I do not have the supercharger
Old Dec 2, 2006 | 06:57 PM
  #64
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by Dirty Howie
This is a view of where it is......standing in front of the car with the hood up.
DH
Same for me. Only small difference is I'm using two AMW clamps and my can is installed leaning back at about a 45 degree angle. Pretty sure Patches has his installed there too.
Robert
Old Dec 2, 2006 | 09:33 PM
  #65
Vetteoholic's Avatar
Vetteoholic
*This Is unrelated to your question...I just wanted to comment about the picture of your procharger setup..It looks great, whoever did the Install did one hel* of a good job. I have the older setup~Luckily no problems other than a loose belt a couple of times. I got a new belt about six months ago and It's still tight. I still wish I had the newest setup~It looks/performs better and Is more reliable. Nice job and best of luck with It
Old Dec 2, 2006 | 11:19 PM
  #66
Dave68's Avatar
Dave68
Originally Posted by Dan_the_C5_Man
Dave has access to CAD/CAM and milling machines, so it looks like he made a small aluminum can to replace the small plastic / glass unit on the air compressor filter.
If I had access to the tools and machines Dave does, hell, my wife and kids would only see me twice a day, once to eat and once to (eventually) sleep.
I do, but my plan is to display my drawing of the extended can, list all components and offer to buy a bunch if anyone is interested. I get a discount (at work) on the coalescing filter/bracket kit and can have extended cans made at very good prices. I purposely designed the can to be very simple and easy to whip out on a CNC lathe. The one in the picture was mostly machined by me on a manual lathe; since I'm not a whiz at threading, a machinist at work did that for me.
Howie, the correctly-sized filter assembly has a capacity of 1oz. My can quadruples that, so I figure I can go almost one year before having to empty the can. You are right in that it is smaller than most catch cans and I can easily design a larger diameter can. However, that would mean higher costs and fewer areas in which to mount the assembly. It looks like you drilled and tapped holes in that front cross bar that sits behind the front fascia. If not, how did you mount it? I was looking at that area this afternoon as a possible place to mount my catch can. Drilling may be tricky unless I get ahold of a right-angle drill. That steel beam seems to be fairly think.
Dave
Old Dec 2, 2006 | 11:24 PM
  #67
Dave68's Avatar
Dave68
[QUOTE=RonVette2][QUOTE=berryj]I have a related question, not to hijack this thread though! I just installed the NLP catch can on my 99 w/ A&A Procharger unit. I hooked the pcv line into the upper fitting of the can, then connected the lower fitting to the pcv valve housing which then connects to the intake manifold.
If the catch cans are set up similarly to real coalescing filters, then the upper port is the inlet side. Since the intake hose is pulling vacuum, then its hose whould go to the lower (outlet side). It all depends upon how the filtering path is set up.
Old Dec 2, 2006 | 11:45 PM
  #68
berryj's Avatar
berryj
Dave, your description is how I have mine set up. The pcv tube wraps around my passenger side then inserts into the top fitting of the can. From there after the oil vapors separate, the remaining air gets sucked out via the lower fitting, then through the pcv valve, then into the intake manifold.
528, thanks for the kudos! Love Andy's kit, no problems w/ it. Now he's switched to Vortech, but same great quality.
Old Dec 2, 2006 | 11:46 PM
  #69
RonVette2's Avatar
RonVette2
the can is set up with a top connector that has a screen/filter under the lid that screws onto the can, then about 1/3 ways down the can there is another connector going out the side, my view of all of this was like others here: have the inlet hose from the valley pan cover go to the side of the oil catch can, once the air and oil vapors enter the can, they would have to turn 90 degrees upwards, go through the filter/screen and out the top exit. (So in my opinion the oil vapors would drop into the bottom of the can at that point before they could try to make it up through the filter and out the can.) then the exit hose goes to the PCV and into the intake manifold.
Another reason for me choosing this way was because the "Original Set-up" was rubber hose out of valley pan cover, then a "u-shaped" plastic hose, bending u-shape upwards (A "U" on its side actually)then a rubber hose again connected to the PCV which is connected to the intake. So basically... out from below the intake, curve around and up to the PCV and into the manifold. What I did was keep the same level in lines as well by lower valley pan cover hose to lower/lowest connection on can, then upper hose off can to upper PCV on intake, seemed simply to me, and the most logical.
Old Dec 3, 2006 | 12:26 AM
  #70
Dirty Howie's Avatar
Dirty Howie
Dave
Dave
I did not do the drilling......Andy himself installed it for me. I didn't really pay attention to what he did.....but don't remember it being problematic. But anyone who can make their own catch can undoubtabely will figure it out
Do you have any pictures or discription of the actual filtering medium you are using ?????
DH
Old Dec 3, 2006 | 12:34 AM
  #71
Dirty Howie
I think this way is wrong. AMW thinks this way is wrong. Elite Engineering thinks this way is wrong.
Your way catches the oil vapors at the top where they will coalesce on the filter and then get sucked as oil drops into the intake.
The vapors should enter the filter at the top first, coalesce and oil drops should fall to bottom of can.
DH
Old Dec 3, 2006 | 12:36 AM
  #72
briann510's Avatar
briann510
I think either way will work. I just drove 300 miles with it one way and another 300 miles the other way and neither one had any oil accumulated in the can and it was some very hard 600 miles of driving. My engine with 29K on it uses absolutley no noticible oil either between oil changes (7K miles) which I guess is virtually unheard of and its driven very hard.
Old Dec 3, 2006 | 12:38 AM
  #73
Dave68's Avatar
Dave68
Howie, here is a pic of the filter element as installed into the coalescing filter. The most effective filter media for trapping airborne oil is borosilicate microfibers. Stainless steel is sometimes used in "pre-stage" particulate filters for removing bulk liquids. However, it does little to remove the oil aerosols that dominate air that is being sucked into the intake. Now, does anyone have a right-angle drill I can borrow.....?
Old Dec 3, 2006 | 12:47 AM
  #74
RonVette2's Avatar
RonVette2
It may seem like I would do better with a different filter media, I think that the filter that is in the oil catch can that I bought it a steel looking mesh type, it would make more sense that the other filter mentioned above would be better at catching oil in its vapor (smallest form) then the steel mesh type.
I also understand the theory mentioned above about the entering can from the top and through the filter first.
Old Dec 3, 2006 | 01:02 AM
  #75
Dave68's Avatar
Dave68
Often in industrial applications, a particulate filter is used as a prefilter to a coalescing filter, but this is primarily because compressors that do not have air dryers, tend to produce quite a bit of water as the air temp goes from hot to cool. I drove 300+ very hard miles (maybe 500 miles, overall) and found maybe .25 - .38 oz of oil in my can today. Ideally, one would have both a particulate filter to trap any bulk liquids and a coalescing filter to trap the aerosols. I'm not so sure that we need to be fanatical about this, however.
Old Dec 3, 2006 | 01:04 AM
  #76
Dave68's Avatar
Dave68
DH
Old Dec 3, 2006 | 01:13 AM
  #77
Dan_the_C5_Man
DH
My response; take a real world view of what these cans are trying to (and capable) of accomplishing. These commercially available cans have not recvd. a 1,000 hours of QA and development by a major automotive manufacturer, nor do the media they use qualify as a coalescing-type filter. It’s “arm-chair engineering” at its finest, please don’t assume it is anything more.
So the bottom line is I believe you'll catch more oil droplets and potentially oil vapor with allowing gravity to work for you, not against you.
Either way you route the hoses, you are 1,000% ahead of the game compared to a stock setup.
To Oil Catch Can Question...
Old Dec 3, 2006 | 02:13 AM
  #78
Dirty Howie
Dave
Thanks for the description regarding borosilcate microfibers.
I am confused looking at your pic. The while cylinder is the filter medium correct? What is the purple appendage?? Is the cylinder filled with the medium??? Does this saturate and clog easily???
I should have come on the run today so we could have compared cans/filter mediums.
Please illucidate
DH
Old Dec 3, 2006 | 04:10 AM
  #79
ZeeOSix's Avatar
ZeeOSix
Actually, gravity is working the same in both hose hookup scenarios if you assume the majority of the oil is condensed on the mesh filter. Once the oil is condensed, then it will drip down into the catch can reservoir.
I agree with Dirty Howie though, that if the hose that sucks from the intake is on the top of the Elite or AMW catch can it is closer to the condensed oil in the mess trap, and may be more susceptible to getting carried into the intake manifold when under high vacuum conditions.
On the Elite catch can, the fitting on the side is far removed from the oil caught in the mess filter and in the bottom of the reservoir. That means any liquid oil inside the can should never be sucked out by the vacuum of the intake manifold.
Old Dec 3, 2006 | 08:24 PM
  #80
Dave68's Avatar
Dave68
Dave
Please illucidate
DH
Howie,
The white filter is the borosilicate fiber filter. There is a black plastic piece that threads into the aluminum top, sealing against the filter. There is no appendage - that's my car in the background. The filter is a hollow cylinder through which the air passes. Will the filter get clogged? only if there is a large amount of liquid oil trying to pass through OR if there is more than a small amount of dirt and other particulates. Since the air that is passing through is somewhat clean of solid particles, I don't expect that the filter will clog anytime soon. many larger coalescing filters have built-in differential pressure indicators that change color if the DP is above a predetermined number (10 psi, I believe). If our case, we can either plumb a DP gauge in between the two hose ends or wait until our idle become rough. A quick check would be to squeeze the hose entering the intake. If the idle stays the same, the filter is clogged. If the filter is good, the idle speed should decrease, the way I see it.
Dave
