C5 Tech gurus: C5 push button start.
Old Aug 12, 2008 | 04:26 PM
  #141
adam205348's Avatar
adam205348
Guys he already has one available to someone that wants to give it the first try. I will let him post or pm the price which I think is very fair for something of this caliber. In a couple of weeks I will be seeing if he either has another one if someone has already picked up his first one or if he has anymore ready to go.
Old Aug 12, 2008 | 04:29 PM
  #142
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I'm talking to him about the prototye but my problem is simply that I don't have the extra cash to drop right now.
Old Aug 12, 2008 | 04:33 PM
  #143
adam205348's Avatar
adam205348
Lol, yours and mine both.
Old Aug 12, 2008 | 04:36 PM
  #144
THE TECH's Avatar
THE TECH
If he's willing to do better to be the guinea pig, I'd be down to do it.
Old Aug 12, 2008 | 10:44 PM
  #145
dre99gsx's Avatar
dre99gsx
I'm still missing some small details with regards to wiring, the key cylinder to be specific. A good few photos of the key cylinder front, back with good lighting. The schematic for the key cylinder should show ACC, ON, CRANK or something to that nature. Can't find them online.
I think we could use the same black button you've seen on my Supra. Just need to hog out the outer key cylinder plastic a bit for the button to fit. Red button may be too tacky.
I can either ship this where you have to cut and solder the ignition wires (I don't recommend quick-taps for those heavy gauge wires), or if I can find a connector that plugs into the ignition harness, plug and play.
Still don't have a solid candidate to give this a trial run.
Old Aug 12, 2008 | 10:59 PM
  #146
THE TECH's Avatar
THE TECH
I have a full FSM and can do the install like I mentioned above.
Old Aug 12, 2008 | 11:03 PM
  #147
dre99gsx's Avatar
dre99gsx
The SEARCH button indeed is my friend!
http://forums.corvetteforum.com/show....php?t=1951626
I ordered a lock from ebay. Give me a few days. I want to make sure my button will fit and look good. I'll have photos as well. From the looks of it, this will fit nicely. I think you guys will be please with the kit.
Judging from the ignition lock, I may have to leave the wires bare and have 'you' solder wires. I'm not sure everyone here can solder correctly. Have to think of the easiest way to connect about 6 wires to the ignition key cylinder harness.
Old Aug 12, 2008 | 11:39 PM
  #148
dre99gsx's Avatar
dre99gsx
Also, can I have a second person verify that after you LOCK with the inside door switch, closing the door (setting the alarm), wait a few minutes, unlock the door with your key, open it and wait a few minutes, that the alarm does not sound? I need to make sure this is consistent so that I can adjust the code accordingly.
Old Aug 15, 2008 | 12:05 AM
  #149
donkeykong's Avatar
donkeykong
This is shaping up to be a very cool project. I can't wait until it's completed.
Old Aug 15, 2008 | 02:37 AM
  #150
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Mine worked just as you described...
I'm up for Guinea Pigging also, I've torn my dash apart so many times it's put together with velcro now! I've got 20 plus years at component level repair on PCBs and do alot of LED mods for Forum members.
A thought about the VATS resistance, what about using a variable resistor and dialing in the correct resistance specific to a vehicle?
Tim
Old Aug 15, 2008 | 08:49 AM
  #151
Fastbird's Avatar
Fastbird
Pro Mechanic
Tim
Just my simple mind thinking here, but wouldn't the extra components for that drive the price up noticably?? The way I'm looking at it, anyone who tries to install one of these is going to have a certain level of technical and mechanical savvy, so it wouldn't be too much to leave the resistance and resistor figuring up to the end user. Just my $.02
Old Aug 15, 2008 | 01:43 PM
  #152
dre99gsx's Avatar
dre99gsx
The end user can buy a $0.20 resistor and just hack it himself. Should be fairly easy. But, it would be recommended to solder the resistor.
I just got a 2004 ignition unit. From the looks of it, you can probably snip off the two-wire connector that provides the resistance from the key to the computer and insert a resistor from the back, plug it into the computer side of the harness, and be done with it.
Alright, another thing I need. Does anyone know if the black plastic ignition cover is a separate part number? This is the part with the words OFF, ACC, ON written on it? I just test fit my Avalon button. It fits nicely in the bracket, so thats a plus. But, the plastic key cover needs to be cut. I can offer a pre-cut plastic if those parts are available separate or let the user cut it themselves.
I'll mod the one I have here and take a photo. See what folks think about the look of the button.
Old Aug 15, 2008 | 01:54 PM
  #153
dre99gsx's Avatar
dre99gsx
  #154
williocom's Avatar
williocom
sweet this is moving along nicely cant wait to get one
Old Aug 15, 2008 | 02:35 PM
  #155
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Old Aug 15, 2008 | 02:43 PM
  #156
03QSLVRZ06's Avatar
03QSLVRZ06
looking and sounding great.....
can't wait to see the final product
Old Aug 15, 2008 | 05:58 PM
  #157
Fastbird's Avatar
Fastbird
Pro Mechanic
Wow....if I only had the spare money to give this a shot, I'd be all over it. This is really starting to look good.
To C5 Tech gurus: C5 push button start.
Old Aug 15, 2008 | 06:45 PM
  #158
NemesisC5's Avatar
NemesisC5
Excellent Progress
Old Aug 15, 2008 | 08:49 PM
  #159
minitech's Avatar
minitech
Wow that looks good. Just get Tstar's prototype done and post up a group buy to see if you can get the price lower for everyone!!!
Old Aug 15, 2008 | 09:13 PM
  #160
John S.'s Avatar
John S.
cant wait for the end result. I hope this works. I'm saving my pennies now.
