Engine Vibration
Old May 4, 2009 | 11:40 PM
  #61
Numb's Avatar
Numb
For what it's worth, I had an engine vibration that I was starting to think might be internal. I was using a clutch and flywheel that were both supposed to be zero balanced from the factory. I finally tore the car apart and took the clutch and flywheel to a machine shop. Sure enough, the pressure plate was 20 grams out. Had it rebalanced, and now the motor revs smooth as butter.
Old May 4, 2009 | 11:47 PM
  #62
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I'd like to think that's going to be my problem but the issue at hand is that the clutch on my car was already in use on my original motor and the clutch went from box to car. Unless some amazingly freakish coincidence caused the clutch to be out of balance at the same points and weight as the stock flywheel if it had weights added, I don't see the clutch being the issue. My main reason for tearing it all apart is to check the pilot bearing, and if that turns out good I'm going to run the car without the TQ tube attached and see if the vibration is still there. If it is, I'm going to pull the clutch and send it for balancing so I KNOW the flywheel has a neutral balance, then I'm going to reattache the flywheel and check again. If it continues, pretty much solidifies that it's an internal issue.
Old May 5, 2009 | 09:15 AM
  #63
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Just a heads up, but I believe that the Textralia's are neutral balanced as a unit and not seperate components, that's why there is mark on them from the factory showing the alignment point so that you put it back together correctly to keep it in balance.
Old May 5, 2009 | 09:30 AM
  #64
lucky131969's Avatar
lucky131969
Ok, I'm playing catch up here. Do I understand correctly that the clutch and flywheel were not purchased as an assembly? i.e. flywheel and clutch balanced as an assembly?
Old May 5, 2009 | 09:59 AM
  #65
Fastbird's Avatar
Fastbird
Pro Mechanic
No, this is a standard Tex OZ-700 kit with the billet flywheel. I REALLY wish there was a way I could crack the motor off without a flywheel on it. That would completely rule out the clutch at that point.
They are marketed and sold as a balanced unit, and I haven't seen any reports of one being out of balance. Not familiar with the mark you're talking about, but know that the way that the dowel pins are set up that you can only put it together one way.
Old May 5, 2009 | 10:11 AM
  #66
lucky131969
Thanks. I can only imagine how frustrating this is. Just keep isolating the motor, you'll find the issue.
That is correct, and exactly how my OZ-700 was.
Old May 5, 2009 | 10:33 AM
  #67
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I have a Tex Twin so it was a little different I guess, as mine had marks.
Old May 5, 2009 | 10:44 AM
  #68
Fastbird's Avatar
Fastbird
Pro Mechanic
I found one other thing last night it could possibly be. Apparently the Gen III/IV motors are VERY sensitive to how the flywheel is torqued down. If not done in a very specific manner it might not seat right. Another thing to check I guess.
At this point I'm almost feeling like I should do something while I'm in here, like upgrade the clutch or something. Money however, dictates otherwise.
Old May 5, 2009 | 11:49 AM
  #69
K RIPPER's Avatar
K RIPPER
Totally interesting thread,got some pretty sharp minds responding to your prob.,can't add anything except to say it always seems when a car fights you this hard in the end it's worth it,in that it runs better than expected,like the car is saying "you want me to run hard ,well you're gonna have to work for it" don't get discouraged,from the input you got they like myself have sometime had a build that frustrated and fought you every inch of the way I certainly have had my share .....GOOD LUCK
Old May 5, 2009 | 03:14 PM
  #70
Numb's Avatar
Numb
Yeah, the manual says to tighten the bolts down incrimentally in three passes, normal star pattern. I've always done it that way, but it seems like you would have to really screw up to get the flywheel bound up at an off angle. Even though it seems unlikely, I'd still take the clutch and flywheel to a machine shop and at least have them check the balance... it's quick and cheap, and you might get lucky. Peace of mind if nothing else.
Old May 5, 2009 | 03:43 PM
  #71
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW. This is a post worth watching. Good luck on resolving this issue.
Old May 5, 2009 | 04:28 PM
  #72
Fastbird's Avatar
Fastbird
Pro Mechanic
Provided it vibrates with the TQ Tube out today (IF I can get it out and feel like tightening up the manifolds to start the car), that's my next move.
I have to laugh at how I plan to run the car. No belts, no steering rack, no wheels, no downpipes, wastegates, or exhaust.........just funny to me.
Old May 5, 2009 | 10:51 PM
  #73
Fastbird's Avatar
Fastbird
Pro Mechanic
Pilot bearing is fine. Not going to bother running the car without the TQ tube. Going straight for the clutch pull and balance. If that doesn't do it........insert record length of expletives here.
Oh....btw.......doing the tq tube on your own SUCKS. I don't have a tranny jack so I ended up with both my hydraulic jacks under the rear cradle to keep it's fore/aft shifting to a minimum, and put my shop stool under the front of the tube. Rolled right out.
Old May 5, 2009 | 10:56 PM
  #74
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I didn't think it was the pilot bearing as they usually make a lot of noise (squealing) when they go bad.
I don't think it's the clutch either based on the fact that it worked fine before the swap.
My guess is that it's the motor. I hope you get things worked out.
Old May 6, 2009 | 06:22 AM
  #75
Atok's Avatar
Atok
Man I feel your pain. This sounds very familiar to me. We had an oval track race engine once with a slight vibration just as you described. After a few checks we decided it wasn't bad enough to worry about and ran the engine that season. In the last race of the year it knocked the oil pump pick up off, even broke the tack weld we had holding it in place. Also destroyed the harmonic balancer over the season. Crank bearings were toast due to lack of oil and vibration. It's amazing how much grief a simple vibration, barely noticeable, can cause down the road. In our case it was internal balance just off slightly. Oval track racing so the engine always operated at high RPM which probably accelerated the failure.
Based on what you are saying, my guess would be internal balance.
Old May 6, 2009 | 07:40 AM
  #76
Fastbird's Avatar
Fastbird
Pro Mechanic
So if it turns out to be internal, what are my odds of recouping money previously invested with peripherals and installation I paid for that I will have to redo??? TSP has already said they won't cover that, but for an engine that had issues from day 1, I think I've got a pretty good case to sway them.
Old May 6, 2009 | 08:48 AM
  #77
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would first figure out what the problem is and then deal with getting it fixed.
If it's TSP fault (i.e. motor unbalanced), then they should pay for all of the labor and parts to fix the problem.
To Engine Vibration
Old May 6, 2009 | 08:57 AM
  #78
Fastbird's Avatar
Fastbird
Pro Mechanic
It's going to be a few days before I really know for sure what's going on. My next opportunity to get the clutch out of the car will be Thursday night. Today I'm going to call around to try to find a local shop that can spin balance a clutch. So if I get lucky I'll be dropping the clutch off on Friday.
While that's being done, I'll probably address taking the TQ tube apart this weekend to check the bushings just in case. Worst case scenario I spend ~$100 to get new ones as a preventative measure. Don't think the TQ tube is bent or way out of whack though becuase the pilot bearing looks immaculate.
Gotta pick up a remote bleeder while I'm at it. There's no way I want to have to drop everything again so I'm trying to address everything I can while the driveline is out.
I know I haven't said it before, but I really appreciate everyone's help with this. I really do.
Old May 6, 2009 | 10:06 AM
  #79
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
If the issue ends up being internal balance, what is your next step? If you had someone near with balancing equipment there is a good chance that the imbalance could be corrected with the engine in place.
Thanks for posting your progress, as others have point out, it makes for an interesting read and I'm sure it can help others identify balance issues.
As far as doing all the work yourself, that can really suck as you point out. No other vett owners near you to give a hand? I hope it all works out for you which I'm confident it will.
Old May 6, 2009 | 10:29 AM
  #80
Fastbird's Avatar
Fastbird
Pro Mechanic
Well, my next step is to pull the motor, tear it down to the short block, and have it shipped to TSP because for them to cover it they MUST do the work.
Admittedly, it's self induced. I've got a couple of buddies who have offered to help but schedules didn't line up, and I don't really know any Corvette guys locally other than Anthony01 and he's been hard to get a hold of recently.
