Lost all communication help!
Old Jun 4, 2010 | 07:38 PM
  #101
Superman09's Avatar
0Superman09
Former Vendor
First numbers are in OHM 20M, second numbers are OHM 200K
A (Purple)- infinity
B (Dk Green)- 6.43, 107.2
D (orange)- infinity
E (Lt blue)- 0.18, 64.5
F (Dk blue)- 0.03, 10.8
G (grey)- 0.19, 62.7
H (blue/white)- 5.74, 112.2
J (pink)- 0.01, 0.1, 2.1 (200)
L (white)- 0.17, 61.1
M (lt green)- 0.27, 13.7
Old Jun 4, 2010 | 09:06 PM
  #102
Superman09's Avatar
0Superman09
Former Vendor
also FWIW I have a new BCM in my garage in case.... and new radio
Old Jun 4, 2010 | 10:23 PM
  #103
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Those readings dont make sense. Take them in the X2K scale and see what they are. Make sure that you have a solid constant chassis ground
Originally Posted by Superman09
ok so I will be wanting to read OHM? Should I set it to 20M, 200k, 2k, or 200?
Old Jun 5, 2010 | 05:26 AM
  #104
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Jon,
What type of Meter did you get? Analog (needle) or Digital... Make sure the leads are plugged into the correst holes for measuring resistance (Ohms) some have another plug in for high voltage or measuring watts. As Bill said, we should be seeing 750 Ohms on most or some of the leads.
Bill's right, those readings are whacked! Although the open on D is interesting... Is the OEM Radio still plugged in?
Tim
Old Jun 5, 2010 | 08:47 AM
  #105
Superman09's Avatar
0Superman09
Former Vendor
No, radio is UNPLUGGED. I am using the negative terminal on the battery as the ground. Should I use a different? Will jump down the meter (it is in OHMs) and submit new readings! Thanks!
Old Jun 5, 2010 | 08:55 AM
  #106
Superman09's Avatar
0Superman09
Former Vendor
Not getting any reading on the 2k other than the pink reading very low (I am assuming this is the radio considering I have it unplugged)
Old Jun 5, 2010 | 09:04 AM
  #107
lucky131969's Avatar
lucky131969
The radio is the orange wire Jon. Since you have it unplugged, your original reading of infinite makes sense now.
The last reading you took for the pink(which goes to the remote lock receiver) appeared to be 2.1 ohms. Is it still the same? If so, that is an issue.
Old Jun 5, 2010 | 09:06 AM
  #108
Superman09's Avatar
0Superman09
Former Vendor
Yep, that Pink wire is definitely far different than the others!
Old Jun 5, 2010 | 10:06 AM
  #109
Superman09's Avatar
0Superman09
Former Vendor
I have lt green and dk green jumped at the moment and am going to drive it to my golf tournament today and see how that goes in reduced engine power. IOf you have any idea per those readings as to what the issue may be... looking like the pink wiring is out of the loop!
Old Jun 5, 2010 | 03:32 PM
  #110
Superman09's Avatar
0Superman09
Former Vendor
Car drives fine but damn I gotta figure this stuff out so I can get the interior back together and use of windows and such... all it does it drive, lol.
Any idea on the pink wire issue?
Old Jun 5, 2010 | 04:38 PM
  #111
Superman09's Avatar
0Superman09
Former Vendor
Orange wire reads 10.9 on 200k with radio plugged back in
Old Jun 5, 2010 | 05:13 PM
  #112
Superman09's Avatar
0Superman09
Former Vendor
Anddddd we're up and running!
Tim called me up on the phone and he advised I yank the Pink wire from the connector and see what it does... well I'll be damned! Everything communicates now! Except the RFA but that's because that's the pink wire obviously!
So it appears I toasted the RFA which was giving me all the trouble.
REALLLLY want to thank everyone who helped me out, Madmatt, Lucky, BC, and of course Tim who all chatted with me extensively and even called me over the phone to narrow this down!
Big thanks!
Oh yeah, and I learned a Sh*t ton about the electrical system and my car in general!
-Jon
Old Jun 5, 2010 | 05:20 PM
  #113
tstar's Avatar
tstar
Cool! I have a spare RFA for a 99 I'll send you tomorrow...
Now you're on the hook to help out the next owner that plugs up the Buss with noise! LOL
I'll tell ya, Matt, Lucky and Bill epitomize what this Forum is/should be about! Hats off to you three gentlemen!
Tim
Old Jun 5, 2010 | 05:47 PM
  #114
Superman09's Avatar
0Superman09
Former Vendor
Tim
Add yourself in there with them Tim!
Old Jun 6, 2010 | 09:43 AM
  #115
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Big thanks!
-Jon
Tim
I know I haven't been able to put in any input lately, but I have been able to follow the comments in the early morning.
Jon I am glad it is sorted out and the culprit is found.
Will you still need to install the other BCM you picked up?(due to the PINK wires delima)
You guys are too much, I have had help from BILL too and LUCKY has certainly helped in my threads - a big thumbs up for you all
Thanks,Matt
Old Jun 6, 2010 | 12:55 PM
  #116
lucky131969
Big thanks!
-Jon
So through this experience, you learned how to troubleshoot and isolate the class 2 serial bus, and learned how to use a meter. As a result, your resistance measurements revealed the pink wire having a abnormal low resistance...and you found it!
Good job Jon
Old Jun 6, 2010 | 08:24 PM
  #117
Superman09's Avatar
0Superman09
Former Vendor
Thanks guys, I learned a TON from you guys. I owe you all a bunch so whenever you need anything just give me a shout!
I do not need the new BCM so I will either keep it as a spare or post it back up for sale
To Lost all communication help!
Old Jun 16, 2010 | 11:30 PM
  #118
Superman09's Avatar
0Superman09
Former Vendor
Follow up:
I appears the RFA unit is NOT my issue.....
-HOWEVER a HUGE thanks to Tim for sending me out a RFA to try out, I will get that back in the mail to you, but HUGE thanks, what a guy!
Anyways, I put the good RFA module in, reconnected my pink pin that I have had pulled from the star connector and right back to my issue. reduced power, everything, car won't run. Pulled pink plug again, back to normal with just no control of tire pressure or use of keyless entry..... any ideas?
Old Jun 16, 2010 | 11:34 PM
  #119
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The PINK wire is your issue. Remove the module and starr bus shorting buss & Measure it to ground and see if it reads INFINITE. If not,,find the short or issue.
BC
Follow up:
Old Jun 17, 2010 | 03:23 AM
  #120
tstar's Avatar
tstar
BC
You're going to have to follow that wire Jon and see where it's shorting out...
Tim
