Lost all communication help!
Old Jun 3, 2010 | 09:17 PM
  #61
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! Doesnt take much. just a piece of simple speaker wire to connect the two pins together on the one with the most wires.
  #62
Superman09's Avatar
0Superman09
Former Vendor
Ok cool, just want to make sure those are the correct ones? Same connector, light green and dark green wires?
Old Jun 3, 2010 | 09:18 PM
  #63
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes!
Old Jun 3, 2010 | 09:19 PM
  #64
Superman09's Avatar
0Superman09
Former Vendor
Brb!
Old Jun 3, 2010 | 09:27 PM
  #65
Superman09's Avatar
0Superman09
Former Vendor
No dice
Both ground caps removed, ran wire between M and B and the same No Comm.
Old Jun 3, 2010 | 09:32 PM
  #66
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OK
All is NOT lost. There are TWO things that can cause NO COMMS. A shorted or damaged comms wire OR loss of power to the module. Most likely the BCM.
Your going to need that meter. There are TWO or more 12 VDC power supplies to the BCm and PCM. One is connected to battey feed and is HOT at ALL TIMES. The other is switched power from the ignition switch and is HOT in RUN and STATRT. I bet you missing the 12 VDC from the ignition feed.
Check all the BCm and PCM fuses. There are many.
Bill
Old Jun 3, 2010 | 09:33 PM
  #67
VettesandZs's Avatar
VettesandZs
My car(2004) is doing the same thing. It started after sitting all winter, here is the thread I started, you can take a look, but not sure if it will be any help.
http://forums.corvetteforum.com/c5-g...possessed.html
Old Jun 3, 2010 | 09:34 PM
  #68
Superman09's Avatar
0Superman09
Former Vendor
OKAY! HOLD ON!
I was just making a video to show you guys how the car was acting. At the end I went to show what it does when I crank the engine and holy **** it fired and ran! The engine runs now with M and B jumped, but I still have no communication ANYWHERE....
Old Jun 3, 2010 | 09:35 PM
  #69
Superman09's Avatar
0Superman09
Former Vendor
Every fuse was checked last night and all are well. Except #1 was blown, I got all excited to find it was my cigarette lighter that never worked... makes sense, didn't fix my issue, lmao
Old Jun 3, 2010 | 10:13 PM
  #70
lucky131969's Avatar
lucky131969
Originally Posted by Superman09
OKAY! HOLD ON!
Cool. Now jump M, B, and G together. See if the car runs, and check for communication again.
Old Jun 3, 2010 | 10:17 PM
  #71
Superman09's Avatar
0Superman09
Former Vendor
dark green, light green, and grey all on the same connector and leave the ground cap for the 4 wire connector still off?
Old Jun 3, 2010 | 10:33 PM
  #72
Superman09's Avatar
0Superman09
Former Vendor
Old Jun 3, 2010 | 10:36 PM
  #73
lucky131969
Yep.
Old Jun 3, 2010 | 10:40 PM
  #74
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
After you try that, reconnect it all back up and see what happens.
Bill
Old Jun 3, 2010 | 10:51 PM
  #75
Superman09's Avatar
0Superman09
Former Vendor
I have communication now with the PCM and IPC, everything else shows No Comm. still.
Engine will not run now however, fires and instantly dies again.
Old Jun 3, 2010 | 10:52 PM
  #76
lucky131969
Please explain what is connected(jumpered)....and what is disconnected.
Old Jun 3, 2010 | 10:56 PM
  #77
Superman09's Avatar
0Superman09
Former Vendor
M, B, G jumped, both connectors have ground plug disconnected
To Lost all communication help!
Old Jun 3, 2010 | 10:57 PM
  #78
Superman09's Avatar
0Superman09
Former Vendor
Bill
Reconnected everyting back up and we are back at square one. No Comm. with anything and engine won't run.
Old Jun 3, 2010 | 11:01 PM
  #79
lucky131969
Now that the IPC and PCM are communicating, can you get any codes?
Old Jun 3, 2010 | 11:19 PM
  #80
Superman09's Avatar
0Superman09
Former Vendor
Ok, well jumping them this time gained communication with the BCM!
I get 1 code from the PCM: P1626 H
I get 4 codes from the BCM: B0605 H, B2587 H, B2592 H, U1255 HC
No codes from the IPC
Everything else No Comm.
THis is with light green, dark green, grey jumped
