IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Sep 24, 2005 | 10:18 AM
  #101
ROD BROWN's Avatar
ROD BROWN
Default A good idea?
I was down at the Rite Aid Drugs Store and bought some baloons(your choice of colors).I cut the solid end off and pulled them over the connections after I cleaned the connectors.They fit real snug and I don't think water will seep in between the connector and the ballon.Total cost $1.50.I hated to spend the buck and a half ,BUT-----
Old Sep 24, 2005 | 01:44 PM
  #102
TriVetteNut's Avatar
TriVetteNut
Default Electrical Probems
Bill,
Where can I get a good manual such as the one that you have shown with the ground points. I'm having FOB, BCM and other problems probably related to a poor ground. Does the manual state which of the ground points are terminals or connectors?
thanks,
Bob
Old Oct 4, 2005 | 09:48 PM
  #103
02ElectronZ's Avatar
02ElectronZ
Default The dreaded C1214 HC
Bill,
I found the frame rail ground connections. They were not that dirty. Is ground point 202 in the passenger toe board compartment by the fuse panel and BCM?
thanks,
Matt
Old Oct 13, 2005 | 07:52 AM
  #104
MLEN1UM's Avatar
MLEN1UM
Ttt
Old Oct 17, 2005 | 07:26 PM
  #105
abealz's Avatar
abealz
1st Gear
Having some problems described here with my 2002 convertivble 6-speed. Yesterday my drivers side controls quit working. gages pegged out, reduced eningine power, service vehicle soon, low fuel, air bag light traction control light.
I read your post on cleaning the gronds but the pictures are not loading.
Need some help!!
Andy
Old Oct 20, 2005 | 11:00 PM
  #106
The Director's Avatar
The Director
Woa...I think I have the grounding problem big time. Been getting a rash of random codes. Service Active Handling, Service ABS, Service Traction Control, Reduced Engine Power, Low Tire Pressure...heck, you name it.
Bill's info is just what I needed to hear but the pics are gone now - just Red Xs. I sent you an email Bill, can you update this post or send me some details, pics, or whatever so I can work on this?
Thanks.
Old Oct 20, 2005 | 11:09 PM
  #107
The Director
Woa...I think I am having the ground problem big time. Been getting a rash of random codes lately. Service Active Handling, Service ABS, Service Traction Control, Reduced Engine Power, Low Tire Pressure...heck, you name it.
Bill's info is just what I needed but the pics are gone - nothing but red Xs. Bill, I sent you an emai. Can you update this post or send me some details and a few pics so I can locate the connectors?
Thanks man.
Old Oct 22, 2005 | 05:20 PM
  #108
vettefool's Avatar
vettefool
the pictures that Bill originally posted will no longer open. guess they timed out. sure would be great if all this was in tech tips. thanks again Bill for your information.
Old Oct 30, 2005 | 07:24 PM
  #109
sodabar's Avatar
sodabar
1st Gear
Default 98 electrical problems
My 98 suddenly started acting up, battery voltage 13v, DIC reads 11
Hood lamp flashes Monitored load relay clicks, and interior lights flash,
starter just clicks, then after a few trys, it starts, but relay and lights still flash.
Won't stay running. I cleaned battery cables and tightened them, unscrewed ground bolts and cleaned. Where are the chassis ground connectors located.
Doug
Old Oct 31, 2005 | 08:53 AM
  #110
RAO-3's Avatar
RAO-3
Any chance the pictures can be re-posted? They don't seem to be in this thread any more!
Ray
Old Oct 31, 2005 | 04:21 PM
  #111
B. Stewart's Avatar
B. Stewart
What happened to the photos??
Old Oct 31, 2005 | 05:45 PM
  #112
M_T_0's Avatar
M_T_0
the marine stores sell a couple of products in a spray can, some of it is called corosen block this is a penitrating dielectric which leaves a good amount of protection on the wires. I use this stuff in my offshore boat and it even works where the salt water is spashing on the componets but needs to be replaced once a year in that application, on the C5 grounds 1 application should do it.
More Than Zero
Old Nov 2, 2005 | 12:01 AM
  #113
Black 79's Avatar
Black 79
A couple of ounces of 2 stroke oil per fill up has "solved" my 0 miles DIC read out for over 5000 miles now!
Old Nov 2, 2005 | 04:32 PM
  #114
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks like all of the pictures are back!
Hope you all can open them.
Bill
Old Nov 2, 2005 | 09:39 PM
  #115
jakestyr's Avatar
jakestyr
Default fuel sending unit
Bill; I had that same fuel sending unit problem last fall. I put a can of B-12 fuel system cleaner ( Wallmart ) in with a full tank -- let it set for 10 days -- fixed the issue. Before it would run down to about half a tank and go to 0.Of course then all the low fuel lights would come on. It did that for every tank ( approx 20 ) and never since. Maybe worth a try.Great post on the grounds! Thanks!
Old Dec 5, 2005 | 08:52 PM
  #116
game on's Avatar
game on
Just a thank you note for all the info you have provided on the forum.
We should think of your info as Christmas, Birthday, etc. presents from a good Samaritan. Like the American Indian, a gift without expections.
Thank you.
Old Dec 5, 2005 | 08:59 PM
  #117
GUSTO14's Avatar
GUSTO14
Bill
Bill, the first thing I did after reading your original post was check and clean all of the grounds... sure enough I found enough corrosion to convince me if it wasn't yet a problem, it soon would be...
Thanks for all of your help... GUSTO
To IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Dec 6, 2005 | 12:36 AM
  #118
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks!!
I pass all the info that I find helpfull for C5's to all of you so that you can ENJOY your C5!
I just purchased a C6 and Im sure that I will be able to do the same on that model one day!
If you have a question on something related to C5's please let me know. I will do my best to help you figureout your problems.
BC
Old Dec 26, 2005 | 09:12 PM
  #119
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Good Stuff.... TTT
Old Jan 5, 2006 | 02:17 PM
  #120
BretCutler's Avatar
BretCutler
Pictures vanished again! Or at least i can't view them. I am going to try to find the grounds tonight. I get the 11 volts indicated from the battery and 13v when running. I also had the fuel gage problem a while back. Doubt that this is a problem that can fix my radio but the reception is terrible. I guess if it had low voltage getting to it that would cause that.
Anyone explain where the grounds are for me so i don't look for hours and find nothing? Thanks everyone,
Bret
