Another poverty Splitter installed
Old Oct 25, 2015 | 05:15 AM
  #141
kotik's Avatar
kotik
I just wanted to point out that poverty splitter does work. I notice a tad more stability at the front end. Front feels a bit more planted above 130mph
Old Oct 25, 2015 | 10:46 AM
  #142
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by Dr Man
I installed mine this afternoon. I just removed the factory screws, installed the splitter using the same screws. Seems very solid, I did not drill any other holes or install the scrivets I bought. Has anyone else done this? Sure are a ton of screws in it already.
But all the existing screws are on the back edge...You need the additional screws to keep the leading edge tight against the bumper.. Remember, the whole purpose of the splitter is to increase downforce on the front end and it is under constant pressure at higher speeds.
I recommend using the matching bumper cover screws (with backup nut inside the bumper cover) for extra security over the plastic rivets...
Old Oct 25, 2015 | 11:05 AM
  #143
nmvettec7's Avatar
nmvettec7
Old Oct 25, 2015 | 03:35 PM
  #144
Bob Holinski's Avatar
Bob Holinski
I just ordered a splitter from Amazon. $98.54 with free shipping.
Amazon.com: Genuine GM Spoiler Package Part# 22922352: Automotive Amazon.com: Genuine GM Spoiler Package Part# 22922352: Automotive
Old Oct 25, 2015 | 03:40 PM
  #145
Skid Row Joe's Avatar
Skid Row Joe
Good info!
Old Oct 25, 2015 | 04:25 PM
  #146
nmvettec7's Avatar
nmvettec7
Bob, that was a great find. Lowest price I have seen to date and free shipping on top of that.
Old Oct 25, 2015 | 06:09 PM
  #147
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Looks like it went up about $10.
Old Oct 25, 2015 | 09:52 PM
  #148
Dollartree's Avatar
Dollartree
[IMG]https://cimg6.ibsrv.net/gimg/www.corvetteforum.com-
vbulletin/640x480/80-spoilerfasteners_9e8678442f68d902b5d718c d70c703ed9760525d.jpeg[/IMG]
Where do you find the matching bumper cover screws?
Old Oct 26, 2015 | 07:38 AM
  #149
Bob Holinski
Originally Posted by rmorin1249
Guess I DID get a great deal. Same supplier raised his price a bit but still not a bad deal compared to others out there.
Old Oct 26, 2015 | 11:27 AM
  #150
BIC's Avatar
BIC
A lot of Amazon items are constantly fluctuating in price. It may go back down that $10 the next hour or day.
Old Oct 26, 2015 | 12:12 PM
  #151
TEXHAWK0's Avatar
TEXHAWK0
The dealer's PDI shop had extras in a box....
but you can also order OEM hardware from clipsandfasteners.com including the matching u-nuts.
The threads are M4.2-1.41 w/17mm washer (u-nuts are #20339, I think GM#11516397)
You might get lucky and find some at the local auto parts store.
http://www.clipsandfasteners.com/v/v..._catalog58.pdf
Old Oct 26, 2015 | 12:20 PM
  #152
TACHY's Avatar
TACHY
Originally Posted by Rooster OG
Can that be painted?
I had mine painted carbon flash by professional body shop prior to install and has held up fine (so far).
Old Nov 3, 2015 | 04:58 PM
  #153
iclick's Avatar
iclick
They may be playing games with your IP address. I've seen other sellers jack the price up after I've looked at the item more than once, then reducing it a week later. I presume they're keying on your IP address and hoping you won't notice the price increase should you decide to order. Caveat emptor.
Old Nov 3, 2015 | 05:44 PM
  #154
rmorin1249's Avatar
rmorin1249
It's back down below $100.
Old Nov 3, 2015 | 07:24 PM
  #155
REDBULLIT's Avatar
REDBULLIT
I just got this splitter from them great price, I also got a z06 grille from them a few weeks ago and paid $179.00. Sometimes you can find great deals.
Old Nov 3, 2015 | 08:51 PM
  #156
scottsh's Avatar
scottsh
Too bad there aren't poverty side skirts...
Old Nov 3, 2015 | 09:50 PM
  #157
REDBULLIT's Avatar
REDBULLIT
I agree!
To Another poverty Splitter installed
Old Nov 4, 2015 | 08:53 AM
  #158
pltmgr's Avatar
pltmgr
Originally Posted by nmvettec7
Here's a set of C7carbon.com GTX Fiberglass side skirts. I painted them myself in Carbon Mist Metallic. These are the Z06 style side skirts. Came in fiberglass, paid $389.00 delivered in Jan 2015. They are priced slightly more now. The poverty splitter has not been painted. Straight out of the box.
I have about $525 into both the side skirts and splitter and cost of materials to paint the side skirts. I installed all parts myself. The appearence is awesome.
C7Jake has the poverty splitter and the ACS brand side skirts which are are priced several hundred dollars more than the C7carbon.com
You can decide which ones to buy. The Z06 style is sold by many vendors and at many different price points. They are essentially all the same in style and all look alike. Only difference is the material they are made . True Carbon Fiber material of course is the most expense by far.
Awesome looking Vette. Where did you get the paint?
Old Nov 4, 2015 | 09:00 AM
  #159
crazybiker51's Avatar
crazybiker51
Old Nov 4, 2015 | 10:12 AM
  #160
nmvettec7's Avatar
nmvettec7
Originally Posted by [B
pltmgr[/B];1590834122]Awesome looking Vette. Where did you get the paint?
pltmgr:
Several places:
Wet Sanding paper came from Home Depot 2000 & 3000 Grit
Adhesion Promoter came from AutomotiveTouchUp.com
Base Primer Came from Home Depot Rustoleum Product
Paint came from Home Depot..Carbon Mist Metallic Paint (Rustoleum Product) $7.00 for the spray.
Clear Coat came from Home Depot High-Gloss Automotive Clear Coat (Rustoleum Product)
All great products all high-quality products.
Easy to do, just take your time and be sure to let all coats sprayed dry thoroughly. Sometimes when painting parts like this, people become impatient and never wait enough time for the coats to dry properly. I painted my side skirts over a 3 day period.
Applied the following: Wet sanded 2000 grit, 2 coats of the Adhesion promoter, 2 coats of primer, wet sanded lightly 3000 grit, then sprayed 3 coats of the Carbon Mist Metallic and 3 coats of clear coat. Then polished with Meguiars 205 and then applied a coat of wax.
Results just as good as an auto paint body shop. Saved a ton of money and spent less than $25.00. Since I do a lot of auto detailing I had a lot of the base supplies already.
Hope this helps.
