C7 fast list!
Old Nov 22, 2014 | 06:34 PM
  #261
yell03's Avatar
yell03
Originally Posted by Fore58
Cut a 1.69-1.70 and you will be in the 11.6-low 11.70s. if you are spinning your car can do it on a well prepped track.
Hey Yell03,
I just could not come out as hard......spinning and fishtailing. I definitely can see 11.70's which is my goal in stock form. Actually, I was surprised to see 11.88 with a not so good 60ft.[/QUOTE]
Wow, I think the fastest guys are able to just stomp it and go.
Ask Snorman what he does.
I don't think they have to roll in to the throttle, but ATCO is prepped very well.
Old Nov 22, 2014 | 06:55 PM
  #262
Fore58's Avatar
Fore58
Originally Posted by yell03
Hey Yell03,
I don't think they have to roll in to the throttle, but ATCO is prepped very well.[/QUOTE]
It was just a bad and struggling night at Bradenton Track. I had six runs and all 5 were 12 second runs.....just could not get off the line without spinning. So I just back off a bit on the 11.88 run. And that was somewhat in the better lane. Just to let you know, I pretty much a drag racer but only with those fast motorcycles. I just think the cooler weather had a little effect on the track. I will be going again in the future for more improvement.
Old Nov 22, 2014 | 07:17 PM
  #263
yell03's Avatar
yell03
It was just a bad and struggling night at Bradenton Track. I had six runs and all 5 were 12 second runs.....just could not get off the line without spinning. So I just back off a bit on the 11.88 run. And that was somewhat in the better lane. Just to let you know, I pretty much a drag racer but only with those fast motorcycles. I just think the cooler weather had a little effect on the track. I will be going again in the future for more improvement.[/QUOTE]
That is rough, I can tell you know what you are doing, just bad track prep.
Old Nov 23, 2014 | 03:05 PM
  #264
nicosupercarlife's Avatar
nicosupercarlife
Cruising
Default Nice vette and time!
Originally Posted by Snorman
Year of the C7:
Tires used on the pass: Stock OEM Michelin Pilots
Performance Mods (if any): None
Category submitted for: Bone Stock on Stock Tires
60'.............1.683
330'...........4.807
660'...........7.389
660’ mph...94.61
1000'..........9.613
1320'..........11.496
1320’ mph…118.96
Name of the track:
Date of pass: 11/4/13 (Atco timeslips dates are incorrect)
Weather conditions: (include Density Altitude, if known): ~1200'-1500'
Video of 11.67 pass made a few weeks earlier in ~400' DA at Atco:
S.
Digging the rubber burning!
Old Nov 23, 2014 | 07:18 PM
  #265
wfarmer.z's Avatar
wfarmer.z
2014 Z-51
Tires OEM Michelin Pilots
Performance mods: none
Category: bone stock on stock tires
Weather: 46 degrees, 66% humidity
Track: Richmond dragway
Date: 11/22/14
E.T 11.44@ 120 mph
Old Nov 23, 2014 | 07:53 PM
  #266
yell03's Avatar
yell03
Originally Posted by wfarmer.z
2014 Z-51
Date: 11/22/14
E.T 11.44@ 120 mph
Fastest A6
Old Nov 23, 2014 | 10:48 PM
  #267
Fore58's Avatar
Fore58
Records are made to broken. Congratulations Farmer
Old Nov 24, 2014 | 04:54 PM
  #268
Richmond427's Avatar
Richmond427
Go Will Farmer and your C7 California Chrome!! Break you own record!
Old Nov 24, 2014 | 09:16 PM
  #269
Fasterproms's Avatar
0Fasterproms
Former Vendor
Name:  c7 time 10.25.jpg
A&A Supercharger 6.5 psi, Fasterproms Ported Heads and Custom Cam, 93 Octane, M7, No Methanol or E85
Built and Tuned by Jeremy Formato at Fasterproms
Currently the 2nd Fastest Manual C7 in the World
Congratulations to Vengeance, for the record.
I only had one opportunity at the track to go for the record at this power level. After numerous oil-downs and track clean-ups, it took me until the 3rd pass to get there. Unfortunately, I now have to return the car to stock because I have another project car coming and I am running out of time.
Old Nov 26, 2014 | 12:54 AM
  #270
wfarmer.z's Avatar
wfarmer.z
Thank you, your car appears fast . If you have to feather the throttle, then track prep is off. Or temp. Is to low ! I use low for the burn out, you cant do to much DR'S or Stock! then, shift to drive before stageing. Don't try & launch over 1,800. If it won't hook all at once 60' is done. Good luck, these cars remind me of the 57 Chev. We ran in the mid 60' blue printed, 5:13 rears stock 283's turning in the 12s beating the GTOS & SS 396 Chevelles. But everything was in the 60' any mistakes & we were done!
Old Nov 26, 2014 | 09:12 AM
  #271
Fore58's Avatar
Fore58
Thanks Farmer for your personal insight on the matter. Actually, I left at idle and floored it on a few passes. That probably caused me to break the tires on the 60's. On my very last pass, I just settled down just to make a good pass.....11.88. The track prep at Bradenton was very tricky on this time out, so I was dealing with two elements......track prep and low track temperature. There was a lot of down time due to cars breaking down, so it was difficult for me to get in the rhythm if you know what I mean. And you are right, if it wont hook the 60' is done and a not so good ET. I'll try to do a better job next time out.
Old Nov 27, 2014 | 01:08 AM
  #272
wfarmer.z's Avatar
wfarmer.z
Default 11:88 pass !
Great pass, I know exactly what you mean ! Don't know what your DA was cold temp was helping you, but hurting your lanch, must have good track prep! Good Luck, have a nice Thanksgiving.
Old Nov 27, 2014 | 10:08 AM
  #273
Stephen02Z06's Avatar
Stephen02Z06
Good job, Will!
Old Nov 27, 2014 | 10:24 PM
  #274
wfarmer.z's Avatar
wfarmer.z
Originally Posted by Stephen02Z06
Good job, Will!
Thank you, that means a lot ! Hope you had a great thanksgiving.
Old Nov 29, 2014 | 05:34 PM
  #275
wfarmer.z's Avatar
wfarmer.z
2014 Z -51
Date: 11-29-14
Category: bone stock on stock Michelin pilots
Weather: 45 degrees, 38% humidity
Track: Richmond Dragway
E.T: 11.37@ 119
Comment : Great track prep and weather was pretty good.
Old Nov 29, 2014 | 05:49 PM
  #276
Fore58's Avatar
Fore58
Wow Farmer!.....you weren't playing around.
Old Nov 29, 2014 | 06:28 PM
  #277
Chris23120's Avatar
Chris23120
I was at Richmond Dragway today racing my CTS-V and had the pleasure of watching Mr. Farmer's C7 run probably ten 11.3x passes. Very impressive consistency, especially since some of them were hot laps. He should bracket race that car!
To C7 fast list!
Old Nov 29, 2014 | 06:38 PM
  #278
Fore58's Avatar
Fore58
Good lookout!
Old Nov 29, 2014 | 07:24 PM
  #279
yell03's Avatar
yell03
2014 Z -51
Date: 11-29-14
E.T: 11.37@ 119
11.372 puts you at #1, the next best is 11.377, that is cutting it close
Old Nov 30, 2014 | 12:38 AM
  #280
wfarmer.z's Avatar
wfarmer.z
Default at last !
Thanks, that was the best we could do! Track prep by Johnny Davis & his guys was outstanding. We ran 11.385 11.384 11.373 11.372 . We left the track really down thinking thč A-8 had run 11. 370 only to find out it was 11.377. Snorman said 30s were possible he was right. We new the A-8 could out run the A-6 with almost 123mph. But we thought we saw a weakness, with its 4:56 1st gear they might have trouble hooking with stock tires. Only way we could beat him would be 60' it worked today. Thanks to Zack, Matt, Justin. This has been alot of fun !
