C7 fast list!
Old Nov 18, 2014 | 08:23 PM
  #241
wfarmer.z's Avatar
wfarmer.z
Im not a 100% sure but I think the A8's are shifting into 5th towards the end of a 1/4, Thats another shift or two than the A6. I guess my question is does the extra shifting of the A8 equal out and thats why its not alot of time difference??
Old Nov 18, 2014 | 09:48 PM
  #242
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Originally Posted by Fore58
Well it seems like I am not making a point here since I have never driven an A8. The only point I am making here is that the A6 and A8 are still close as far as quickness and 1/4 mile times. Some members are making or giving assumption that the A8 is so much faster than the A6. We all know by now that the A8 transmission is superior over the A6 in almost every aspect. However, that doesn't mean that A8 is going to destroy the A6 at any given time at the track. As far as mod comparison take this for instance.....Farmer went 11.31@121 with DR's only, Brent went 11.06@125 with Headers, DR's and tune. I believe that headers and tune should be worth at least two tenths. Now for a comparison, Farmer should be able to pull off 11.11 with the same mods but then I would be speculating. And, I would call that very close. Hence, both cars are probably running in the best conditions for drag racing. Just my thoughts and that's all.
I got your point, I just thought you were not getting mine. First off we are comparing stock which means no programming. My point was that the biggest difference is mechanical, when a auto trans shifts it has to disengage and then engage a clutch that is driven by hydraulic fluid. There are some things in that sequence that you can calibrate on the timing of. You also have torque management at play to make sure nothing is damaged during this process. Because the A6 has less gears the spread between the gears is larger so the RPM drop is greater. So what happens during the shift is that you have torque management helping to reduce power in the engine (your foot is full throttle) so that the RPMs drop down to where the clutch for the next gear can fully engage. When this is all done, lets' say you lose 2500 RPMs and it takes a certain amount of time for that to happen. On the A8 the gear split is less, so maybe the RPM's only drop 1500 RPM's. so everything happens faster on the shift. But the shift is not the only issue. Your making your shift at 6000 RPMs, minus 2500 is 3500, this is the new starting point for the next gear. On the A8 your are dropping from 6000 to 4500, right in the meaty part of the power band. This is why the A8 will always be faster comparing apples to apples. Will, yes even making the extra shift, it is still going to go faster. Nothing can really be done about that. Now a new gear in the diff will help because it will change the how easier the engine can accelerate the car from lower RPM after the gear change.
Old Nov 19, 2014 | 12:36 AM
  #243
Fore58's Avatar
Fore58
This time I understand your point....thanks for enlightening us about the mechanics/technical part of the A8.
Old Nov 19, 2014 | 07:27 AM
  #244
wfarmer.z's Avatar
wfarmer.z
Thank, J Abbot knows alot more than I will ever know about these cars, but I would like to say to all the A6 guys, Dont give up. Everyone on the list is fast and deserves alot of credit. Snorman get your car out, we could use your help! Iv been racing since 1967 and we would not have believed stock cars would be running in the 11's !! Thanks again to tune time, this has been alot of fun!!
Old Nov 19, 2014 | 10:09 AM
  #245
Fore58's Avatar
Fore58
Actually, I would like to see more A8's out on the track. There is only one that is standing tall for right now.
Old Nov 19, 2014 | 10:55 AM
  #246
Greg Quillen's Avatar
Greg Quillen
Like to see A8 on the road course. Find more out about the over heating issue gm trying to fix for the Z06
Old Nov 20, 2014 | 03:16 AM
  #247
wfarmer.z's Avatar
wfarmer.z
I have a Zo6 on order from Hendrick, i have been told order Constraint on the A8 will go off Dec 10th !
Old Nov 20, 2014 | 01:03 PM
  #248
Late Model Racecraft's Avatar
Supporting Vendor
Royal Purple Raceway 11/20/2014
Getting Ready to crack off a WR Run.
LMR @ Royal Purple Raceway Houston, TX.
Worlds Fastest & Quickest C7
Old Nov 20, 2014 | 01:34 PM
  #249
Supporting Vendor
2nd Run of the Day
Old Nov 20, 2014 | 02:32 PM
  #250
Supporting Vendor
3rd Run of the Day
Old Nov 20, 2014 | 03:13 PM
  #251
TuneTimePerformance's Avatar
0TuneTimePerformance
Former Vendor
Originally Posted by Late Model Racecraft
3rd Run of the Day
Nice passes! Was this one of the cars that is already on the list? Or another one I need to add lol
Old Nov 20, 2014 | 03:16 PM
  #252
Supporting Vendor
This is the one that ran a 9.95.
Old Nov 20, 2014 | 03:28 PM
  #253
Supporting Vendor
9.39!!
Old Nov 21, 2014 | 12:58 AM
  #254
Fore58's Avatar
Fore58
New Personal Best: Submitted for an update
2014 A6 Convertible Stock Fast List
Bradenton Motorsports, Bradenton Florida
1.795 60ft
7.703
92.52
11.88 1/4 mile time
118.31 mph
Old Nov 21, 2014 | 01:41 AM
  #255
wfarmer.z's Avatar
wfarmer.z
Wow, Great Run, i ran a 10.
85/128 at Richmond in John Hampton's CTSV Cadillac must be unreal to run a 9.39 !
9.39!![/QUOTE]
Old Nov 21, 2014 | 01:52 AM
  #256
wfarmer.z's Avatar
wfarmer.z
Nice run, I ran 11: 85 on my 1st run in June at Richmond, I was amazed all the magazines said 12s, but then we saw Snormans time !
7.703
92.52
11.88 1/4 mile time
118.31 mph[/QUOTE]
Old Nov 21, 2014 | 07:20 AM
  #257
Fore58's Avatar
Fore58
7.703
92.52
11.88 1/4 mile time
118.31 mph
[/QUOTE]
Thanks Farmer.....It always feels good to run quicker than the magazine. Anyway, I had a rough time at the track with spinning issues. Bradenton Track wasn't that good for street tires and not that well prepped. One pass I ran 13 seconds......let out on that pass. Before my very last pass I just smoke the tires to heat them up properly. I could not launch hard as I would like. As you can see, my 60 ft is still not in par with you guys. I believe that my will run 11.70's if I could just get that 60 ft down.
To C7 fast list!
Old Nov 21, 2014 | 04:33 PM
  #258
yell03's Avatar
yell03
1.795 60ft
7.703
92.52
11.88 1/4 mile time
118.31 mph
Nice run, what was the temp at the track?
I checked for you, DA was -422, too bad track wasn't prepped better.
Thanks Farmer.....It always feels good to run quicker than the magazine. Anyway, I had a rough time at the track with spinning issues. Bradenton Track wasn't that good for street tires and not that well prepped. One pass I ran 13 seconds......let out on that pass. Before my very last pass I just smoke the tires to heat them up properly. I could not launch hard as I would like. As you can see, my 60 ft is still not in par with you guys. I believe that my will run 11.70's if I could just get that 60 ft down.[/QUOTE]
Cut a 1.69-1.70 and you will be in the 11.6-low 11.70s. if you are spinning your car can do it on a well prepped track.
Old Nov 21, 2014 | 06:32 PM
  #259
SteveDoten@ARH's Avatar
SteveDoten@ARH
Premium Supporting Vendor
I'm really glad people are taking these cars out to the track and using them as they were intended.
Glad to be part of the vast majority of the fastest/quickest times.
We appreciate the all those choosing ARH and look forward to helping anyone optimize thier LT1/4 the best we can.
Steve
Old Nov 22, 2014 | 06:28 PM
  #260
Fore58's Avatar
Fore58
Cut a 1.69-1.70 and you will be in the 11.6-low 11.70s. if you are spinning your car can do it on a well prepped track.[/QUOTE]
Hey Yell03,
I just could not come out as hard......spinning and fishtailing. I definitely can see 11.70's which is my goal in stock form. Actually, I was surprised to see 11.88 with a not so good 60ft.
