C7 fast list!
Old Jun 2, 2014 | 01:35 PM
  #101
"BoneStock"'s Avatar
"BoneStock"
Originally Posted by jb306y
Year of the C7:2014, Non-Z51, M7, NPP, launch control
Tires used on the pass: stock tires 30 psi
Performance Mods (if any):None
Category submitted for: Stock on Stock
60'.............1.9285
330'...........5.2148
660'...........7.8774
660’ mph..... 91.95
1000'..........10.1526
1000' mph.... 107.89
1320'..........12.0748
1320’ mph … 116.79
Name of the track: KilKare
Date of pass: April 10th, 2014
Weather conditions: warm and humid
I've raced all over and Ohio is about .2-.3 slower than Atco or tracks in Florida.. I'm happy with a 12.07 first time on the track with it and with the M7. Without the traction control on, it just spun through 2nd gear. My last four passes were 12.801, 12.582, 12.322 and 12.0748 in that order.
I'm picking my z51 up on the 18th and i will then be out trying to break some records for the m7 at kilkare!
Old Jun 2, 2014 | 05:51 PM
  #102
PRE-Z06's Avatar
PRE-Z06
Originally Posted by Jimsgn
Just got the car back from Slowhawk Performance a couple of weeks ago and brought it to JW 's rental at Lebanon Valley on Friday. Ran with only 8 lbs boost ,waiting for roll bar then to 12 lbs and then ?
2014
M&H DR's 325/40/18 on CCW wheels
ECS -1500head ,Comp Cams custom cam ,LS-7 lifters,Brian Tooley dual valve springs ,KTec timing chain,Alky Control Methanol Injection, 3000 rpm stall converter,ARH 1 7/8 no cats ,stock mufflers.
60' 1.57
330' 4.416
660 6.805
660mph 103.09
1000' 8.848
1320' 10.570
1320'mph 130.3
Lebanon Valley
Date May 30, 2014
weather clear ,temp 70,humidity 60% D/A unknown
Congrats on the times! Curious if the car was tuned on the larger drag radials? Thinking it'd be faster on a 305/35r18 or even faster with a 315/30r18 if tuned for the shorter tire, hope that helps.
Old Jun 3, 2014 | 10:40 PM
  #103
Jimsgn's Avatar
Jimsgn
Default Maybe
You might be correct . Not sure what the different diameter tires would do to the computer. This was first time out so it will take a little trial and error to optimize times .Not sure of what we want rear ratio to be or if it should pass through the traps in third or fourth gear. My ultimate goal is to be able to hit the high nines and still keep the motor together .
Funny thing is best launch ( lowest 60' ) was at 1200 rpm's ,tried 1500, 2000 and a bonzi launch at 2500 none faster than my 1.57 @1200 rpm's .Go figure !
Old Jun 4, 2014 | 11:06 AM
  #104
Dameian's Avatar
Dameian
C7 Z51, Auto, Pfadt Kit 8psi, ARH, 18" Forgeline Drag pack with 325/40/18 M&H Radials... Here are the times and a video or two
PS added a 100 shot of nitrous just waiting to get some time to get back to the track!!
Old Jun 4, 2014 | 05:01 PM
  #105
PRE-Z06's Avatar
PRE-Z06
Wasn't sure if you're a Z51 or not. If so I can see the 325/40r18 working out perfectly for top of 3rd, but if not it appears 305/30r18 would be geared perfectly for top of 3rd with 2.56. Not sure how much the 315/30r18 would help if requiring the extra shift to 4th, but the gearing and parasitic loss from weight could be enough to offset it I imagine. Yeah flashing the converter usually gets the most rpm out of it off the line, no need to load it up and thin out fluid to try to get it to stall higher. Looking forward to you going faster next time!
Old Jun 4, 2014 | 05:04 PM
  #106
PRE-Z06's Avatar
PRE-Z06
C7 Track Day - YouTube
Impressive 60' for stock converter and 28" tall tires!
Old Jun 8, 2014 | 04:58 PM
  #107
wfarmer.z's Avatar
wfarmer.z
How do I get on the fast list? Friday night I went 11.643 @119.65. Bone stock with drag radials and have the time slip
Old Jun 9, 2014 | 12:49 PM
  #108
wfarmer.z's Avatar
wfarmer.z
Default c7 bone stock with drag radial
Old Jun 9, 2014 | 01:51 PM
  #109
TuneTimePerformance's Avatar
0TuneTimePerformance
Former Vendor
Originally Posted by wfarmer.z
Updated, what trans is in the car, what tires and is it a Z51?
Old Jun 9, 2014 | 02:09 PM
  #110
wfarmer.z's Avatar
wfarmer.z
Its a z51 auto stock, with mickey thompson drag radials
Old Jun 10, 2014 | 12:00 AM
  #111
Fore58's Avatar
Fore58
Nice run, Farmer.
Old Jun 10, 2014 | 02:55 PM
  #112
wfarmer.z's Avatar
wfarmer.z
Thank you.
Old Jun 13, 2014 | 08:15 AM
  #113
yell03's Avatar
yell03
Originally Posted by Fore58
Here is my time slip. Disregard the notes at the bottom......I did not use launch control. This was my very first time at the track with this car. I was a little surprised. I believe the car has a little more in it.....with just a little more rpm. I was probably around 1800 rpm on the last pass. Car is an A6 non-Z51. I used track mode and traction control off all three runs. Triple black convertible. Track conditions posted by Jeremy Formato on post #94......as we ran the same night. Please enter me on the fast list
Glad I saw this, I have a C7 A6 Vert non-z51 also.
I don't have NPP, does yours?
What was the weather like on your runs?
Old Jun 13, 2014 | 11:34 AM
  #114
Mike@NewEra's Avatar
Mike@NewEra
I went to the track 2 weeks ago with my C7 and ran 11.6 @ 126 mph. My C7 is M7 trans, stock tires, NEP VVT Cam, ARH mid length headers, NEP exhaust and that's it. The D/A was +2000. Timeslip below
Old Jun 13, 2014 | 11:59 AM
  #115
Fore58's Avatar
Fore58
Post#94 by Jeremy Formato will give you the accurate weather that day because we both ran the same day. My car has the NPP option. I really don't believe the mufflers make a difference at the 1/4 mile track. I am trying to be patient and wait until this fall to make another bone stock pass before I do other modifications. Hence, my car seems to be a little quicker than 11.94@116. I only had three runs with that being first time at the track.
Old Jun 13, 2014 | 12:04 PM
  #116
Fore58's Avatar
Fore58
That is one fast car with just a cam only. Is the VVT DOD or just the drop in cam? I know that Texas Speed had both for the Camaro.
Old Jun 13, 2014 | 07:59 PM
  #117
Jimsgn's Avatar
Jimsgn
forgot, yes its a Z51,thanks for the tire suggestion .the 3/4 shift comes at exactly the worst time ,just before the lights . Now Im waiting for a roll bar before I go back to the track .Then Im shooting for low 10's or into the nines . Shh no cage just trying to sneak by with a roll bar don't want to completely ruin the car like I did to my GN.
To C7 fast list!
Old Jun 16, 2014 | 07:47 PM
  #118
Mike@NewEra
Thanks! Its a vvt cam, DOD delete.
Old Jun 18, 2014 | 08:47 PM
  #119
jsb08Z's Avatar
jsb08Z
Anyone know about any shop or vendor sponsored days coming up at ATCO. Looking to run under 11.5 but have no cage and live NYC
Old Jun 19, 2014 | 02:44 AM
  #120
ChucksTuning's Avatar
0ChucksTuning
Former Vendor
I guess technically I am number 2 for the internal mods list. Stock heads, VVT cam/AFM delete, Kooks 2" headers, 3" B&B PRT, Halltech stinger.
https://www.youtube.com/watch?v=cSsr...ature=youtu.be
