Sponsored by: Wheel Design
C8 problems
Old May 27, 2020 | 10:08 AM
  #241
cwmobley's Avatar
cwmobley
Prior to the frunk hood release episode, when I put the car into reverse, I got a blue screen with a message to repair the backup camera. I have seen this several times previously. I then continued out of the parking lot onto the street where the hood released upward as I accelerated. Prior to the incident, I did not receive any message on the instrument panel referencing "trunk open". Could this imply a computer problem?
Old May 27, 2020 | 10:31 AM
  #242
Jordan6908's Avatar
Jordan6908
Put me down as one of the Frunk guys. No message till frunk was in my face. Took to dealer and 2 2020's in body shop same issue!!! come on GM help out...
Old May 27, 2020 | 10:55 AM
  #243
RapidC84B's Avatar
RapidC84B
@Jordan6908 did you accidentally open it and not see the message? Or are you saying it was fully and properly closed and opened on it's own?
Old May 27, 2020 | 11:02 AM
  #244
Jordan6908's Avatar
Jordan6908
Cant tell. I thought it was closed but dealer thinks people are hitting inside ( 1 button to open) and no dash indicator is coming on until hood is already up!!!! 3 cars in one body shop same problem.
Old May 27, 2020 | 11:24 AM
  #245
carriccp's Avatar
carriccp
Originally Posted by cwmobley
Prior to the frunk hood release episode, when I put the car into reverse, I got a blue screen with a message to repair the backup camera. I have seen this several times previously. Could this imply a computer problem?
I've had this issue with mine (see pg1 I think it was) randomly since picking the car up from the dealer. They replaced the camera and it didn't help, so ordered the video module. When I get it replaced (if it ever comes), I'll report back, but hopefully it fixes it. No issues with my frunk, so it's not related.
Old May 27, 2020 | 12:15 PM
  #246
StickerDick's Avatar
StickerDick
Great Thread, Thank you to everybody that is adding in relative information.
Old May 27, 2020 | 12:19 PM
  #247
tdrake2020's Avatar
tdrake2020
Originally Posted by sprayer
Because they are engineers and the smartest ones. Maybe if they set it to 5mph it would have been better and forced action, but what do ordinary people know.
I'm an engineer, but..... engineers are human and also screw up from time to time. The only time you're not screwing up is when you're not doing anything.
If I were calling the shots I wouldn't let the driver be able to take the car out of park if the "frunk" were not properly latched. We don't need to go back to the days of "suicide frunks and doors". I've called GM and have asked them what was the thinking behind their "82 mph" open frunk speed limit. I'll post the answer if/when I get it.
Old May 27, 2020 | 09:08 PM
  #248
24/Eray's Avatar
24/Eray
There is going to be a safety recall on that frunk issue. I can't imagine at this point there won't be. Which is a good thing.
Old May 27, 2020 | 09:10 PM
  #249
sprayer's Avatar
sprayer
Not sure how this issue did not pop up in the 4 years of testing or what ever it was. Or that no safety is in place for this not to happen.
Old May 27, 2020 | 09:14 PM
  #250
RKCRLR's Avatar
RKCRLR
Last minute software tweak?
Old May 28, 2020 | 09:13 AM
  #251
C8J's Avatar
C8J
I guess we will have to pre-flight out C8s now.
As if one doesn't every time it is put to bed or pulled out.
Old May 28, 2020 | 11:33 AM
  #252
cwmobley's Avatar
cwmobley
Dealer confirmed that new hinges are in stock at chevy warehouse. The car is scheduled to go to the body shop on Monday. The repairs are to be covered under warranty. No mention of a fix for the release issue.
Old May 28, 2020 | 11:53 AM
  #253
C8fnatic's Avatar
C8fnatic
So what is the issue? For them to come up with a fix, they first have to figure out the issue. Did the hatch release because of a software malfunctioning (if so, I'm going to tape my hatch down....) or did you accidentally (1) leave the hatch open, (2) pull the cord next to the brake pad or (3) hit the switch on your key fob or on the driver side door?
Old May 28, 2020 | 02:48 PM
  #254
RapidC84B's Avatar
RapidC84B
Interesting... if they're covering it under warranty then that implies a defect; or could be using "good will" option at the dealer level. If it ere user error then you'd be SOL.
Old May 28, 2020 | 03:38 PM
  #255
c54u's Avatar
c54u
You can temporarily remove fuse 18 behind the glove box to disable the front trunk release until a proper solution is arrived at.
There are a couple of relays as well, 6 and 9.
Old May 28, 2020 | 10:12 PM
  #256
24/Eray's Avatar
24/Eray
late change to electrical system. Maybe new pathway or circuits? Never know with electronics. A weak ground or some anomoly activates something and the hood flies open in your face.
Why the hell they didnt figure out a way to have some speed limiter to next to nothing and a constant "dinging" is beyond my comprehension.
Old May 29, 2020 | 12:32 AM
  #257
500's Avatar
500
Originally Posted by tdrake2020
This is no joke.... I have a foam turbine powered jet that I have 100 flights on. Flies about 170 mph. The exhaust temp is around 1200 F. Here's a link to a video...
https://www.youtube.com/watch?v=kW-a0fhC738&t=4s
Very cool, what's the cost of that little bullet?
To C8 problems
Old May 29, 2020 | 12:43 AM
  #258
500's Avatar
500
$2500 ready to fly. You need a special waiver to fly one if you want to be insured.
Not bad. If it crashes from any kind of altitude is it toast or do the foam wings etc absorb most of the impact? Hard to fly and any restrictions on where can you fly it from?
Old May 29, 2020 | 01:20 AM
  #259
MauiC8's Avatar
MauiC8
...And how does this belong in the “C8 problems” thread? Please keep this thread on topic to help your fellow members.
Old May 29, 2020 | 11:49 PM
  #260
500's Avatar
500
Ask the person who posted the video a few up from here ...see my post #257 where I quoted it...looks like it was just deleted after this post
