Sponsored by: Wheel Design
C8 problems
Old Aug 4, 2023 | 07:37 PM
  #2801
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Look at his post again. He was replying to the post from @LS WON talking about heat in the C6-C7's. Although both were off-topic in a conversation about heat in the C8 frunk, @Minkster 's reply made perfect sense to the post immediately preceding it.
Old Aug 6, 2023 | 05:26 PM
  #2802
Ringmaster's Avatar
Ringmaster
Anyone else have a problem with the center console button?
Old Aug 7, 2023 | 07:01 AM
  #2803
Undy's Avatar
Undy
From: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Please be more descriptive.
Old Aug 7, 2023 | 11:51 AM
  #2804
Ringmaster's Avatar
Ringmaster
I pops out. Does not retract into the flush position. I'd tell my dealer but I'm afraid they would say the whole console has to be replaced.
Old Aug 10, 2023 | 12:21 AM
  #2805
MarkMeHopeful
Is the car out of warranty? Otherwise, why would you be afraid of what work has to be done to fix the problem?
Old Aug 10, 2023 | 08:29 AM
  #2806
StanNH's Avatar
StanNH
This is actually a common issue. The plastic latch breaks easily, and will pop out when the console cover is closed. Mine still worked, but I had to push it back in place.
Took my dealer two weeks to get the part and replace it under warranty. New one has been fine. Really a very minor issue, with a simple fix. The console does NOT have to be replaced, just the latch. It was about a ten minute job.
Old Aug 10, 2023 | 06:25 PM
  #2807
DaveV's Avatar
DaveV
HI, did that dash stitching ever get resolved.
Old Aug 11, 2023 | 10:42 PM
  #2808
Ringmaster's Avatar
Ringmaster
Thanks for the reply. I didn't know it was a common problem. I've never seen it mentioned. Glad to hear it doesn't require half the car to be taken apart to fix.
Old Aug 12, 2023 | 06:29 AM
  #2809
StanNH's Avatar
StanNH
I haven’t seen it discussed here, but it shows up on some of the FB groups. Dealer said they have done a few already.
Old Aug 12, 2023 | 02:09 PM
  #2810
Ringmaster's Avatar
Ringmaster
Is the part that's needed listed anywhere along with a diagram?
Old Aug 12, 2023 | 02:55 PM
  #2811
Ringmaster's Avatar
Ringmaster
I found the button (part # 84854320) on a Chevrolet parts sight. The pic showed a rod sticking out the back of the button with a "hook" on the end which I assume limits travel. Maybe that's what breaks. Do you think that's all that requires replacing?
Old Aug 15, 2023 | 08:50 AM
  #2812
Brokenwings's Avatar
Brokenwings
Default New problem
New problem…here is the view of the passenger mirror when I unlock the car. I turned off the auto fold and returned it to the normal spot manually. I’ll be visiting my dealership in the next few days 🤷🏻‍♂️
Old Aug 15, 2023 | 10:06 AM
  #2813
Red rag's Avatar
Red rag
By appearance it looks like it was bumped and rotated like most other breakaway mirrors. I’m guessing you need to reset it manually by twisting it back to the indent.
Old Aug 15, 2023 | 06:27 PM
  #2814
Brokenwings
That is what I thought at first. It happen every time I open the car, if I have auto fold on. The manager at the dealership said he needs to take pictures to submit them to GM for a replacement.
Old Sep 1, 2023 | 06:16 PM
  #2815
mattwo1232's Avatar
mattwo1232
Looks like I got the dreaded transmission CEL at 250 miles. Only had the car for 4 days
got the rear axle system off message first without CEL. turned off car and restarted with CEL now alongside the message.
Called onstar and they flashed codes P0700/P2817/P2818
took into dealership right away, I’m assuming worst case scenario that the transmission is faulty and needs replacement.
noticed a higher pitch whine coming from the exhaust when throttling past 2k RPM, figured it was just from the cold start….this sucks!
Old Sep 2, 2023 | 05:40 AM
  #2816
Ghost 23's Avatar
Ghost 23
Regrets, I feel your pain.
Old Sep 5, 2023 | 07:24 AM
  #2817
Mrchen's Avatar
Mrchen
members I wonder if this car has the "new" 2024 " transmission?????
To C8 problems
Old Sep 5, 2023 | 08:03 AM
  #2818
4camV8's Avatar
4camV8
Default Could Be A Simple Fix…
I have a 22. In the initial 800 miles it threw a CEL. Car acted/drove perfectly normal. Light went out before getting to dealer which was three days later. Once there, I asked that they pull the code(s). It had the general 0607 code and a tranny code (not sure which). Dealer kept it overnight as the had to consult with GM Technology for the fix. Initially GMT told them to replace the DCT TCM. It was/is supposedly out of stock. So I drove it home…
Three days later my dealer Tech called me. Said GM Tech contacted him about my car. New TCM no longer needed they can send code to remedy. GMT said they’ve seen this code in about 100 cars (over a year ago).
GMT asked him to ask me some specific questions. One of which was; am I or did I ever experience a WHINE from the driveline area? (Answer no) They said the WHINE is sometimes present and has been associated with this code. That it’s cause by a signal fault the creates “high pressure” (in the DCT lines/pump(s)) Said its not a big issue short term, but is long term if driven. But I reiterated, I have no whine. Because of that and the fact that the car had no active codes (only stored) it would be okay to drive until such time as I can get it back into the dealer for the TCM reflash.
My Tech said he’s not seen any sort of TSB from GM on this issue yet. Expects one is forthcoming.
If I had a driveline whine, I’d ask the local Tech contact GMT and get the particulars of high pressure DCT fluid/pump WHINE, the cause and remedy…
8k+ miles since the reflash/code send and no issues whatsoever…
Old Sep 5, 2023 | 02:28 PM
  #2819
Fast Dawg's Avatar
Fast Dawg
From what I understand the new designed DCT started being installed in C8s in late July.
Old Sep 5, 2023 | 09:23 PM
  #2820
Acpantera's Avatar
Acpantera
I spent a crazy amount of time going through this thread....retired guy privilege, lol. Seeing that Chevy has pumped out over 50,000 2023 Vettes this year, and probably at least 40,000 of them have hit the road by now, how well do you think Chevy did in the QC area? I have a 24 on order and reading stuff like this makes me nervous. I understand this thread is just a small snippet of the whole picture, but it can get ones attention. So all in all, can we say the recent C8's are reliable and durable cars in general?(engineered to take a beating on a track, right?) I've had some expensive cars break my heart before, but always had good luck with Chevy's.
