Sponsored by: Wheel Design
C8 problems
Old Nov 23, 2020 | 09:00 PM
  #681
iKonPerformance's Avatar
iKonPerformance
Hopefully GM will get these issues fixed soon enough.
Old Nov 24, 2020 | 11:19 AM
  #682
Hillslam's Avatar
Hillslam
2020 C8 of the Year Finalist - Unmodified
Thought I'd give an update on my overheat situation quoted below.
The dealership called me back and told me that a "quick disconnect" coupling on the water pump failed and no longer will hold coolant. They are ordering a new pump and connect.
I asked if the new connect will fail just like the last - they didn't have an answer to that.
Some more info on the incident:
Interesting that there was no indicator on the dash of low coolant. First indication I had of a problem was the sound of the engine fans going nuts full bore and the rising oil and coolant temp.
At first the car instructed me to idle the engine (I had already pulled over at this time). I did so but the temp kept rising. So I turned the motor off but left accessories running so I could watch dash. The fans kept running and the temps kept rising (no idea how much coolant I had left in the car at this time. Oil temp kept rising too.
Eventually both hit the max side of the gauges. I think I saw oil temp at 297 degrees. Eventually the right side info panel popped up a message saying my oil was now at 0% and needed to be replaced. (Note - it wasn't low or empty).
I told the tech that and directed them to change the oil.
I also asked them the power wash the bay and belly pans of all coolant so I'm not smelling coolant baking for the rest of my ownership (car has 512 miles).
The service manager told me that in order to replace the pump they need to drop the engine so they will be able to clean the inside. We'll see how well they do that.
I just hope nothing warped or coked internally during this heat episode. We will see.
Originally Posted by Hillslam
Add me to the overheat pool.
Just passed 510 miles car overheats.
Pulled over. Awaiting tow.
Back and bottom of car have a film of coolant.
Old Nov 24, 2020 | 11:23 AM
  #683
Hillslam's Avatar
Hillslam
An interesting side note. I asked if I was the first 2020 they had in for service, and the service manager said no they had two previous, both valve spring issues. I'm right in the window for that build timeframe issue, so maybe I have another service trip awaiting me in my future. At least mine wasn't the first 2020 their tech got to work on....
Old Nov 24, 2020 | 11:59 AM
  #684
Grey's Avatar
Grey
Hope it all goes well guy, best of luck to you.
Old Nov 24, 2020 | 11:18 PM
  #685
srosenbldr's Avatar
srosenbldr
Did you lose all the coolant? My upper radiator hose came off.
Old Nov 24, 2020 | 11:35 PM
  #686
Hillslam's Avatar
Hillslam
I was still getting a temp reading so I don't think it ALL dumped. I don't know where this "quick detach coupler to the water pump" that failed is exactly located on the engine, how high it is, so when it went how much coolant was still lower than that spot. I do know it was NOT cooling the engine even at idle.
Really trying not to dwell on what possible block/head/ring/etc damage or heat warping may have occurred.
My plan is to get it back from the dealer and run it like a scalded ape. If it's going to present problems I want them showing up right away.
Old Nov 25, 2020 | 12:10 AM
  #687
RockSolid's Avatar
RockSolid
Back in the late 60's I saw my Dad run his new 1968 Chrysler Newport Custom ( with a 330 HP Magnum 383 and 200 miles on the ODO) until it seized and destroyed the engine, after it lost all oil pressure. He did this to avoid a dealer rebuild/patch job, worried about the damage done by the extreme heat.
Old Dec 4, 2020 | 09:14 PM
  #688
BC_C8's Avatar
BC_C8
Have you figured out a way to fix that yet? I cant figure how to get to those water spots.....frustrating.
Old Dec 4, 2020 | 09:46 PM
  #689
BC_C8's Avatar
BC_C8
Old Dec 4, 2020 | 11:38 PM
  #690
Grey's Avatar
Grey
Fix what?
Old Dec 6, 2020 | 12:32 PM
  #691
FabioGarcia17's Avatar
FabioGarcia17
3rd Gear
Please help!
Hey! I just joined because I need help with my dads c8 corvette.
the car wont open the rear trunk. I've tried with the car key, and from the inside buttom, but the trunk wont open and the lights flashes like the usually do.
the front trunk/ frunk do work perfectly.
I dont know what to do. the only way I able to open the trunk is by taking of the license plate off and using the physical car key to open the trunk manually.
does any of you know what might be happening with the car?
Help, please!
Old Dec 6, 2020 | 12:42 PM
  #692
Grey's Avatar
Grey
How long has the car been sitting ? Have you pushed the rear trunk button on the back of the car? Is the battery low? Start the car if able and let it warm a minute, see if it opens then.
Old Dec 6, 2020 | 12:44 PM
  #693
Grey's Avatar
Grey
Also check manual, do you have the car in valet mode?
Old Dec 6, 2020 | 12:50 PM
  #694
FabioGarcia17
3rd Gear
hey Grey, thanks for the quick response.
when I press the rear trunk button the lights of the car flashes, but it does not open, and we have used the car regularly, but everything happen right after we washed the car about 2 days ago.
Old Dec 6, 2020 | 12:55 PM
  #695
Grey's Avatar
Grey
Pressure washer by chance? Try the rear key behind plate. Plate has to be removed to access it.
Old Dec 6, 2020 | 01:00 PM
  #696
FabioGarcia17
3rd Gear
It was hand washed with a regular water hoes pressure.
yes, thats how we have been doing it to open it. we take the licenses plate off to open the rear trunk, but we want to be able to open the trunk the way it is suppose to work.
Old Dec 6, 2020 | 01:01 PM
  #697
Grey's Avatar
Grey
Warranty time buddy. Call your dealer of choice.
To C8 problems
Old Dec 6, 2020 | 01:42 PM
  #698
RockSolid's Avatar
RockSolid
I would find this quite irritating if it happened to me. I'd take it to the dealer and drive it right up his service bay.
Old Dec 12, 2020 | 05:49 PM
  #699
Firstsupercar's Avatar
Firstsupercar
Originally Posted by C8PRO
Hello Folks,
To keep it short, not good news..... My car is now in the service department for a full transmission replacement. My odd/even gear issue reappeared and GM immediately decided to swap the transmission and to send back my transmission for forensic work. Apparently they have identified a failure with something inside the transmission preventing the odd gears to engage and only keep changing bt even gears. For additional details on my issue you can see my earlier posts. While I am not happy about having to go thru this, I commend GM for the decision to replace the transmission and to send it back to fully understand this issue to prevent a potential painful recall situation in the future. I wish GM technical support contact me directly for a dialog on my situation and for ways they can compensate me for this very unfortunate situation.
I will keep posting as get more updates. omeprazole Magnesium
C8PRO
how does a new transmission go bad . I'm worried now about buying this car
Old Dec 12, 2020 | 06:08 PM
  #700
Jimp94605's Avatar
Jimp94605
Not trying to minimize your issue but with all the C8 DCTs out there this is the first I heard of an issue. Forums like this tend to make issues bigger than they are. Id prefer a new tranny than have a dealer tech take it apart.
Has anyone head of this happening before?
You will be fine and on the road soon embarrassing hellcats!
