Sponsored by: Innova
Old Mar 25, 2015, 01:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Android Head Unit & Backup Camera Installation
Old Dec 6, 2015 | 08:36 PM
  #261
lucmac's Avatar
lucmac
Originally Posted by bjmsam
SW1 and SW2 are likely equivalent to KEY1 and KEY2 in which case no interface is required (just use the purple (6) and dark blue (7) wires from the car as explained in Post 1).
Yep, look at 11:10 into the video for info on the steering wheel set up and at 12:45 some info on setting up the front camera as well. Wished I'd have found this video a day or two ago plus a couple more about the HU! :-)
Old Dec 7, 2015 | 10:05 AM
  #262
jbomx363's Avatar
jbomx363
Originally Posted by Skanlez
Does the app require a premium cost?
It cost me only $10. Lifetime upgrades/maps are free.
I just looked at the site.. wow... price went up from 4yrs ago. $25 or so for:
Lifetime license for Android
High-quality offline maps
Free map updates
Free POI and speed camera updates
Real time traffic, of course, takes data and is an additional charge.
There are some other in app purchases available but I'm not sure what they are as I only use it when going out of town.
http://www.sygic.com/
Old Dec 7, 2015 | 11:03 AM
  #263
jbomx363's Avatar
jbomx363
So in essence, the only module required for the newer HU's should be the PAC OS2X(keeps onstar and is for bose or non bose) and an antenna adapter (that comes with the RP5-GM11) since the newer HU's have SWC built in right?
I contacted pumpkin about specific ISO adapters and they need pictures of the radio plug to give me specific one.
I'm supposing the universal ISO is fine.
Old Dec 8, 2015 | 06:50 AM
  #264
lucmac's Avatar
lucmac
Free map updates
If anyone is curious the first 7 days of the free version lets you use the full premium features. The free version doesn't do turn by turn navigation. You can see a side by side of free vs premium here.
http://www.sygic.com/gps-navigation/...m#toggle-table
For me it looks like a good backup plan app but wouldn't replace Waze and Google tethered to my phone for real trips. Waze is getting really good where I live since there are so many active users providing constantly updated accurate info.
Old Dec 8, 2015 | 07:25 AM
  #265
lucmac's Avatar
lucmac
Anyone care to share photos of where they mounted the USB, AUX(is anyone using it really?) , MIC, and where is the microusb slot?
The problem with this general automotive forum is it lacks the option to show all pictures in a thread. Really bad. That's in invaluable tool and it boggles me why it wasn't implemented. I see it on every other hobby forum I use and it would show up under the thread tool selection. Anyone know the administrator and willing to ask them to add the option? Shouldn't cost them anything.
Old Dec 10, 2015 | 08:46 AM
  #266
jbomx363's Avatar
jbomx363
So...I emailed them to see if they had a specific ISO adapter..this is what they said:
"You will need an special ISO cable for your car if you purchase C0255,or the radio will not work in your car."
HUH? Can't I just use a universal ISO adapter?
Old Dec 10, 2015 | 05:05 PM
  #267
bjmsam's Avatar
bjmsam
Or just do this:
Cut the ISO plug off of the new head unit (HU) harness and connect the wires to those of the same color from the PAC harness (I used solder and shrink tubing).
Old Dec 11, 2015 | 12:16 PM
  #268
Trios's Avatar
Trios
Or just do this:
This is what I did.
Old Dec 11, 2015 | 12:48 PM
  #269
jbomx363's Avatar
jbomx363
Or just do this:
DOH! I read that and didn't relook.
Thanks.
Old Dec 16, 2015 | 08:00 PM
  #270
lucmac's Avatar
lucmac
Is there no way to get the on star built in microphone and speaker to work with these android head unit's car phone app?
Is there a common place people are putting their mics and how are the wires being routed?
Where are people tapping into the rear light circuit for the backup cam? All the back in one of the tail lights?
Basically any advice on where to put the accessories, even the iPod and USB cables and how to discreetly run the wires for everything including front and rear cameras would be good to know about now as I have all the components but want more specific install info.
My installer says to try and install all cameras from the inside due to the thieves and jackasses liking to rip off cameras. I've seen an interior rear camera install example but not a forward one. Any one have any suggestions?
Thanks!
Old Dec 17, 2015 | 11:35 AM
  #271
jbomx363's Avatar
jbomx363
That's what I was hoping pictures of..all the ports/mics, etc.
Old Dec 17, 2015 | 06:51 PM
  #272
bjmsam's Avatar
bjmsam
I don't know, but I like the idea!
I ran them out the right side and tucked them into the glove box, but they are rarely used since MicroSD, BlueTooth and WiFi satisfy my connectivity requirements.
Yes, as described:
For the camera, connect the power and ground to the passenger-side reverse lamp wiring. Reach in from the exhaust side to twist out the bulb socket, pop the wire routing clip out for more length, remove a few screws from the under body panel behind the rear tire and pull the socket through so there is room to work on it. Drill a hole behind the inner brake light, feed the wire through and seal with silicone (or a grommet). Remember to run the RCA wire up through the center console before snapping that back in place.
Old Dec 18, 2015 | 09:42 AM
  #273
lucmac's Avatar
lucmac
Thanks. I think I follow this easily enough except could you add just how you routed all the wires in general from the back to the front? I really don't want to tear into anything unnecessarily or reinvent a worse routing path for the wires and I also want a neat and hidden install as much as possible.
Also, I've gotten two different manufacturers double D plastic covers and neither one seem especially suited for cutting up for the oversized front face. Can you tell me make/model you used and can you send any closeups of the final install? I think maybe I'm being too much of a perfectionist here and if I could see a couple more examples of the final installs I might be happy with the surgery I've already done to one of them.
There are a couple of videos here and there that show a few areas of interest in the camera or head unit installs but the majority of the job like how to route the wires from the back camera and the front camera are never shown, optimal place to route and place the microphone, ipad chord, etc are still left out. It'd be awesome to know when there's just to choice but to drill a hole through a panel and where the best place to do so is.
Interestingly enough, though others said places like Best Buy would do the labor, I contacted a couple of places around here and they didn't want anything to do with just the labor of installing this in a vette so I haven't found a convenient option not to end up doing this myself which is why I'm digging deeper for details on neat and clean installs with minimal 'drilling or pulling things apart' to make it happen. ;-)
Old Dec 18, 2015 | 10:28 AM
  #274
lucmac's Avatar
lucmac
Default repurposing Onstar for a better cell phone experience
Well, we may be in luck. Found a product and install video and it that looks you can add anytime to the vette after you install a new head unit as long as the head unit retains the original on star functionality.
http://www.costartech.com/pb/products/bluestar.html
Old Dec 18, 2015 | 05:20 PM
  #275
bjmsam's Avatar
bjmsam
I simply ran the wires from where they entered the cabin behind the tail light, under the rear floor panel and under the center console. It was super straightforward, so I didn't take any pictures.
See the first post for the exact part I used and the best closeup I have. They are cheap, so buy two just in case.
The Metra 95-3304 Double DIN Installation Kit has a 173mm x 97mm opening that must be modified to fit the 178mm x 102mm HU bezel. To do this I used a caliper and masking tape to mark 3mm from each side. I then used a rotary tool with my largest cut-off wheel on medium-low speed to trim away the excess. For the bottom I used a sharp utility knife to slice through from the back at the first corner. The top I left alone. It turned out nicely.
That Costar Bluestar module is interesting but why not simply feed the OnStar microphone outputs to the HU inputs and use the app that's already installed?
Old Dec 19, 2015 | 07:55 AM
  #276
lucmac's Avatar
lucmac
I did buy two mounting dash and different brands and don't like either. One has a curved front design that doesn't look right but can be made to fit just ok and the other has gobs of thick Plastic that doesn't want to be cut where it need to be cut and is curved even worse.
Moving to the next couple of items. I can't figure out how to get the front camera to operate. It comes up with a caution sign that I can't figure out how to overcome. I can't find any safety type item in a configuration setup that I haven't experimented with and I've put 12 volts in the 'brake in' line to see what does and neither have any affect. There are only two inputs for video that are marked. One is labeled camera and works great standalone with the rear light input 12volt line set high. The other is just the video in that's part of the DVR in lines. Their website and their online pdf never make a mention of this function. Any ideas? I need to find for a general Eonon user forum...
Old Dec 19, 2015 | 12:36 PM
  #277
Trios's Avatar
Trios
Looks like the caution sign for when you try and use the DVD with the vehicle 'in motion.' There should be a parking brake input, put 12v on that (or ground it) and see if that overcomes it.
This is why I used a composite video Y (into the rear cam input) and a switch to turn on the front camera; I only use it to safely park, not to DVR my drive, so I didn't want to have to deal with any extra configuration in the device.
To Android Head Unit & Backup Camera Installation
Old Dec 19, 2015 | 06:35 PM
  #278
lucmac's Avatar
lucmac
It's probably a multi-purpose warning. It shows up when you select a video input and it detects there is no signal in from the video source.
I didn't need a switch to get a forward and rear camera to work. There's a shortcut labeled AVIN which I put on the home row of anchored buttons across the bottom and when you select it you automatically get the forward camera in (assuming you hooked it up to Video In line) and when you put the car in reverse it automatically shows the rear camera and then when you take it out of reverse it automatically goes back to the front camera. Also, there's the password protected option that disables the lockout of video while in motion nanny state feature.
I never did get the front camera app that I took a picture of the screen to work. Yes, I tried the parking brake connected to 12v and that didn't change a thing but hindsight says this other way is just as good if not better. The only annoyance now is that neither camera I got has an option to reverse the video with a switch on the camera or by cutting any wires that come with the camera for this reason so the front camera is reversed. None of the built in software image reverse options seem to apply to the AVIN feed. Not an issue when all you're really worried about is just not running into something in front of the car while parking.
getting there...
Old Dec 29, 2015 | 03:04 PM
  #279
lucmac's Avatar
lucmac
Default my project is done! works great
so here's a really bad video I took but you'll get the point.
and here are some still shots. I hadn't actually really finished the tie wrapping and securing the wires through the engine area completely and hadn't cleaned up the car and the area so 'excuse the mess'...
One thing you'll notice is the rear camera is slightly offset and the pictures are of me testing whether I wanted the camera cocked slightly inwards or straight back and I decided to go with straight out, perpendicular to the car's longitudinal axis. You also see how from where it's mounted I can see the towel and just a slight part of the car's bumper to keep things in perspective.
With the firewall penetration, I could not find a firewall bushing anywhere so I made one from a snap bushing that I CA glued in place the used a LOT of ATV sealer from the inside and outside after the wires were routed. I also left a lot of wire slack in the rear of the car and in the engine compartment with the knowledge that these cheap cameras will need to be replaced over time so all the service wire and all the slack you could ever want are there without having to remove the center console and head unit down the road for this maintenance.
https://lucmac.smugmug.com/C6-Corvet...Unit/i-GQMsqLJ
Old Dec 29, 2015 | 05:26 PM
  #280
bjmsam's Avatar
bjmsam
Nice installation and overview! Glad to see how well the head unit handles front and rear camera switching. I absolutely agree with what you said at 1:41 in the video:
The more I researched, the more I realized I didn't want, you know, Pioneer or Kenwood... just too limiting.
Congratulations!
