Sponsored by: Innova
Old Mar 25, 2015, 01:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Android Head Unit & Backup Camera Installation
Old Dec 29, 2015 | 11:46 PM
  #281
Naldinator's Avatar
Naldinator
Got one under the tree this Christmas.
Just need to figure out which adapter to get to maintain the onstar/chimes.
Really do not care about onstar but want the chimes.
Old Dec 30, 2015 | 03:40 AM
  #282
lucmac's Avatar
lucmac
I can vouch this works.
Amazon.com: PAC RP5-GM31 Radio Replacement Interface With Built-In OnStar Retention/Steering Wheel Control Retention/Navigation Outputs for Select GM LAN Vehicles: Automotive Amazon.com: PAC RP5-GM31 Radio Replacement Interface With Built-In OnStar Retention/Steering Wheel Control Retention/Navigation Outputs for Select GM LAN Vehicles: Automotive
Old Dec 30, 2015 | 02:09 PM
  #283
Naldinator's Avatar
Naldinator
FYI Dennis @ Double D Mods hooked me up with the adapters and what not. Great guy!
Old Feb 2, 2016 | 01:35 AM
  #284
Terry Humiston's Avatar
Terry Humiston
What head unit did you finally use? The 7" ? Why did you use the RP5-GM31 when everywhere I check it recommends RP5-GM11? Thanks for the great posts..
Old Feb 4, 2016 | 09:30 PM
  #285
383's Avatar
383
How do you chose one? There is so many that look the same but have a pretty large price spread. How do I know what one is best?
I would like to use mine for recording track and AX sessions with Torque(or track addict) obd2 Bluetooth and a 10k external GPS. Will they all work for that?
the one Im looking at has Android 4.4 quad core kitkat 16gb and 7" screen
Not sure if this link is "legal" here but here goes
http://www.ebay.com/itm/Android-4-4-Quad-Core-7-Double-2Din-Car-DVD-Stereo-GPS-Radio-BT-OBD2-WiFi-3G/121858666788?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3Dd4e99e125d9045dfb14be0cdc539de69%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D381197607525
Old Feb 5, 2016 | 07:44 AM
  #286
lucmac's Avatar
lucmac
http://www.ebay.com/itm/7-Double-2Din-Car-Stereo-GPS-Pure-Android-4-4-Radio-WIFI-3G-Ipod-R-OBD2-Camera-/291616999801?vxp=mtr&hash=item43e5ba4979
That's the head unit I bought but it was on sale before Christmas for around $220. Not really a big difference. As to the PAC module, I had a friend who is a dealer for them look up the right one and order. At the time it was like 100 with free amazon prime shipping. I didn't question it. It works fine.
Old Feb 5, 2016 | 08:43 AM
  #287
bjmsam's Avatar
bjmsam
Amazon is now an option for folks uncomfortable with purchasing from overseas vendors via eBay (not that I encountered or have heard of others encountering problems). For example, my head unit was sold by Pumpkin, a vendor I can recommend without reservation (very responsive and helpful).
Old Feb 5, 2016 | 09:31 PM
  #288
383's Avatar
383
are the steering wheel controls slow to react?
Old Feb 16, 2016 | 10:06 PM
  #289
383's Avatar
383
How do you acess the usb for music? Mine is only seeing the SD card I cand find the usb flash drive anywhere in the system. Do i need to update the HU software?
Also where did you guys plug in the 2 RCAs on the PAC? I left mine disconnected, should I plug them in to something? Stock bose amp?
Old Feb 17, 2016 | 06:20 AM
  #290
lucmac's Avatar
lucmac
My steering controls aren't slow and I've never tried the USB port. I use Pandora via Bluetooth on my phone or from the pandora app on the HU using my phone as a hotspot.
I don't even have a usb drive with music anymore but if I get time I'll experiment this weekend.
Old Feb 23, 2016 | 02:14 AM
  #291
Z2Z's Avatar
Z2Z
Amazon.com : JOYING 7 Inch 1024*600 HD Capative Multi-touch Screen Automotive Android 4.4.4 Universal Car Audio Stereo Head Unit 2 Din RK3188 Quad Core 16GB ROM Radio GPS Navigation System with Multiple Button : GPS & Navigation Amazon.com : JOYING 7 Inch 1024*600 HD Capative Multi-touch Screen Automotive Android 4.4.4 Universal Car Audio Stereo Head Unit 2 Din RK3188 Quad Core 16GB ROM Radio GPS Navigation System with Multiple Button : GPS & Navigation
I just purchased this one from Amazon. I used the PAC RP5-GM11 interface. With the car in accessory mode I get a constant hiss and with it running I get alternator whine. My car is a 2009 that had the base radio and no Bose system.
Any Ideas?
Old Feb 23, 2016 | 07:16 AM
  #292
bjmsam's Avatar
bjmsam
Any Ideas?
Sounds like a bad ground. There are a few ideas here.
Old Feb 23, 2016 | 01:40 PM
  #293
Z2Z's Avatar
Z2Z
Thank for that. I didn't think to try using Google, but I did use the forums built in search. Most of the info that I have found is for people that are using external amps. They are grounding the RCAs or using GLIs. I have no amps and no BOSE amp. I'd like to try using a better ground than the one provided be the PAC. Any suggestions on a good place to use as a ground near the HU?
Old Feb 24, 2016 | 05:50 PM
  #294
Z2Z's Avatar
Z2Z
Problem Solved! I had to use the "amplified" port on the PAC unit. I'm not sure why because I have a base audio system. Anyway it all works great now. I'm really happy with it so far. I'm glad that the OP was able to get the steering wheel controls to work.
I used the latest quad core model from "Joying". It has a slightly larger 7" screen but loses the DVD ability. I got the one that still has a few hard buttons and most importantly, an actual volume ****. Speaking of the volume ****, it's almost a perfect match to the factory HVAC *****.
Old Feb 26, 2016 | 05:12 PM
  #295
Trios's Avatar
Trios
Thank you for this! I just moved up from a C5 to a C6 and will be upgrading to a new Android head unit. This one looks fantastic with the stock interior; I'd just have to get rid of that 'joying' name at the bottom, looks hokey.
Old Feb 28, 2016 | 08:48 PM
  #296
bjmsam's Avatar
bjmsam
Originally Posted by bjmsam
I used Google Image Search to find an appealing image, saved it to the HU and used the Wallpaper Wizard app to set it as the background. The exact image I used is here:
This site generates customized backgrounds:
Originally Posted by whitehooptie
Use this website
http://solidlystated.com/design/corv...per-generator/
Same one I used to make mine. You might have to crop the image a little more on Paint or something.
Old Mar 1, 2016 | 12:43 PM
  #297
starvinmrvn's Avatar
starvinmrvn
What dash kit did you use for your install? I am about to order the same unit.
To Android Head Unit & Backup Camera Installation
Old Mar 1, 2016 | 06:23 PM
  #298
Z2Z's Avatar
Z2Z
I mused the same one as the OP. I had to trim it to fit just like he did too. It was pretty easy to do, just take your time.
I also used the wire harness. It worked great and was really simple. I have used Axxess harness' in the past will never go back to them.
Old Mar 14, 2016 | 02:06 PM
  #299
starvinmrvn
Big thanks to the OP and all that have contributed to this thread! I managed to get all my wiring soldered and correct the first try and my install went super smooth with the PAC Module. If anyone comes across a dash kit that doesn't have to be cut to fit send us a link! Mine came out okay. . but could be better.
My only current question is does anyone know how to let audio keep playing when the car is put into reverse?
Old Mar 14, 2016 | 03:08 PM
  #300
bjmsam's Avatar
bjmsam
Great!
Like this:
attenuation when shifting into reverse can be adjusted or eliminated if desired:
