Doorgunner's '68 Convertible Project
Old Jan 7, 2021 | 10:48 AM
  #5701
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by Andy Tuttle
As Mr Spock would say.... "Fascinating!" Can't wait to see it finished Tony!
A.T. ! Long time, No See. I finally got my replacement fuel sending unit...the original gave out-the windins were worn thru.
It should be driveable in a few days.......
Except for the fact that I haven't finished the front clip yet.
Old Jan 12, 2021 | 01:00 PM
  #5702
doorgunner's Avatar
doorgunner
The PTSD has been yanking my chain, but I managed to install the new tank sending unit AND begin fiberglassing the area where the filler hose passes through the back wall of the cargo area..
You are seeing the left side, rear area of the cargo storage which I enlarged by removing the fuel tank.
The storage area is now 52" deep from the seats to the rear wall...plenty of room for my wife's suit cases and the soft top when it is folded down
The white material under the new fiberglass is a teflon cover over the opening in the floor to access the sending unit. I will use a dremel tool to cut the area aloose from the floor...then add rivet-nuts and machine screws to hold the cover in place.
Old Jan 12, 2021 | 01:11 PM
  #5703
Priya's Avatar
Priya
I love seeing somone bring their dream to life
Old Jan 12, 2021 | 01:35 PM
  #5704
doorgunner's Avatar
doorgunner
How's it going Priya......up to your eyeballs in snow again?
As long as I don't turn into Rumpplestiltskin trying to complete all the mods!
Old Jan 12, 2021 | 01:54 PM
  #5705
Priya's Avatar
Priya
We got somewhere around 12-18 inches in one snowstorm in November, it was a struggle to get in and out of my parking space and the roads were treacherous but since then no snow to speak of. I've been doing nothing much through December although my AMC Eagel SX/4 needs work. I've managed to motivate myself to spend a few days here and there on it since the New Year. I'm currently (well, the hubby and me) installing a 1 micron fuel filter for a Cat diesel as there is constant rust from the fuel tank clogging up the carburetor and I can't get a new fuel tank. The filter is like 8-10 inches long and 4 or 5 in diameter - I sure hope it does the job as the rust has been getting past standard automotive filters.
Old Jan 12, 2021 | 10:21 PM
  #5706
doorgunner's Avatar
doorgunner
ONE MICRON!
Convert Units: 1 Micron = 0.00003937" diameter
A human hair is 0.004" in diameter.
That filter will literally stop a COVID sneeze from passing through it!
Does the tank have an electric fuel pump...you probably know to measure the output pressure and volume of flow after installing the new filter. Same deal with a mechanical fuel pump.
Old Jan 12, 2021 | 10:32 PM
  #5707
Priya's Avatar
Priya
No, its a mechanical pump. The spousal unit thinks it may create a vapour lock problem because of the size of the filter and the extra plumbing to move the filter to the inner fender. He says if that's the case I may have to build a heat shield for the filter and mount and duct cold air from in front of the radiator to behind the shield.
Old Jan 13, 2021 | 07:07 AM
  #5708
doorgunner's Avatar
doorgunner
Just be sure the pump can "pull" enough fuel through the filter and into the carb before you do all the plumbing.
Old Jan 13, 2021 | 10:09 AM
  #5709
loup68's Avatar
loup68
Army
Priya, why can't you get a replacement fuel tank, I do realize that the car is very old. Is this for your Eagle? Maybe someone can fabricate one for you. I went through this crap with a Buick "Nova" ( Skylark ?) gasoline tank.
An old girlfriend had an AMC Matador and it was a cool car. Lou.
Old Jan 13, 2021 | 11:25 AM
  #5710
Priya's Avatar
Priya
I'll tell my husband.
This is for my eagle. No one makes a new tank for it, you can get a new tank for the Eagle 4 door, 2 door, and station wagon. People on ebay sell a gas tank that fits them and they say it fits the SX/4 but it doesn't. I bet that Matador was a sweet ride!
Old Jan 19, 2021 | 02:38 PM
  #5711
doorgunner's Avatar
doorgunner
I'm back! First...the bad news...about a weak back I re-injured my week back...V.A. said they'd think about it
The Good news...the PTSD is at a minimum so I can actually think halfway clearly..
I will finish the access panel to the gas tank sending unit / plumb line to charcoal cannister (aviation thing )
and then correct the remaining minor interior. problems./dirty carpet/driver seat cushion on order/repair ammeter.
Ahhhhh...'tis good to have half the brain cells functioning again!
Old Jan 20, 2021 | 11:43 AM
  #5712
OldCarBum's Avatar
OldCarBum
Hey Tony,
Good to hear you are doing well and you’re able to start making progress again.
Old Jan 20, 2021 | 01:36 PM
  #5713
doorgunner's Avatar
doorgunner
Hey Tony,
Thanks Everyone...I will work with the pain...most of the work can be done sitting behind the car or laying in the cargo area to finish the access panel in the cargo floor corner.
Yep....there is THAT much room back there!
I also just got a late present from Santa. I didn't realize how worn the sill plates were until I set them next to the new plates.......aafter years of looking at "old stuff" it doesn't look that bad until you get the "new stuff"
Old Jan 20, 2021 | 01:41 PM
  #5714
Hopper12's Avatar
Hopper12
Hey DG, I know what you mean about the sill plates. They really make a difference because they are front and center when a door is opened.
Glad you're back. Bad backs and such are tough. Wishing you the best. I'm about to tear the rear out of our '68 and redo it all. Good winter/covid projects. Hang in there, Paul
Old Jan 21, 2021 | 01:07 AM
  #5715
doorgunner's Avatar
doorgunner
Thanks Paul ! Being a machinist I noticed how the stub axle retaining clips were curved over slightly, which meant the groove each retainer fit in was not deep enough. That caused the clips to fail and pop off the stub shafts. I machined the grooves deeper per the machinist's handbook and have had no problems in 6 years.
BEFORE.....
THE WEAR PATTERN LOOKS GOOD......
THIS COULD HAVE BEEN BAD......
I DO NOT KNOW IF THIS WAS A COMMON PROBLEM...OR THE GROOVING INSERT WAS WORN OUT WHEN MY PARTS WERE MACHINED?
Old Jan 26, 2021 | 05:06 AM
  #5716
doorgunner's Avatar
doorgunner
I'm Back from the E.R.....again....lower spine
The gauges have 6 years of sanding dust removed.........sorry about the fuzzy pics.....
The clock is repaired....again..........
Old Jan 26, 2021 | 05:12 AM
  #5717
doorgunner's Avatar
doorgunner
To Doorgunner's '68 Convertible Project
Old Jan 26, 2021 | 11:54 AM
  #5718
OldCarBum's Avatar
OldCarBum
Hey Tony,
Have you looked at the quartz clocks from Corvette Central?
I purchased one for my 73 and they look identical to the OEM.
Old Jan 26, 2021 | 01:13 PM
  #5719
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Hey Tony,
Do those quartz cloks have a smooth sweep or the incremental "ticking" movement?
Old Jan 26, 2021 | 01:46 PM
  #5720
international blue's Avatar
international blue
Mine doesn't work.....I set it to three minutes past 5:00 (pm)......and believe its always right!
