Doorgunner's '68 Convertible Project
Old Nov 19, 2021 | 11:47 AM
  #6221
Dirty Dalton's Avatar
Dirty Dalton
Well done Sir! Carry on.
Old Nov 19, 2021 | 12:52 PM
  #6222
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I glued the Reflectix inside and out, then wrapped it in masking tape until the glue dries.....the stuff ought to work great for cupholders, too .....
Some finish sanding and chase the rivets nuts threads with a tap...by this afternoon the shifter repair panel gets stripped of the masking tape and I'LL start bonding it to the hole in the car tunnel.
Nice fiberglass work Tony.
Great as always.
Next thing you know you'll be screwing down the convertible top lid and glassing over the seams.[/QUOTE]
Funny you mentioned that. I do have plans to add sails to te removable hardtop to give it tne Coup- appearance wnen the hardtop is installed.
thanks OCB...its rough getting back in the groove!
Originally Posted by Priya
Congratulations!
As long as thePTSD will allow me! I think there is 1" clearance between the top of the trans. And the bottom of the shifter insulation
Old Nov 19, 2021 | 12:53 PM
  #6223
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Great as always.
LOL...I remember that!!!!
Old Nov 19, 2021 | 01:03 PM
  #6224
doorgunner's Avatar
doorgunner
Great as always.
LOL...I remember that!!!![/QUOTE]
you remember the sails mod? Remind me of evrything else i forgot
Old Nov 19, 2021 | 01:30 PM
  #6225
OldCarBum's Avatar
OldCarBum
I remember thinking that you are so much better than I am at this and I would have never attempted to take on the project you have.
You're thread is always a good read and an inspiration.
Old Nov 19, 2021 | 02:13 PM
  #6226
The Phantom's Avatar
The Phantom
… where were you when I needed you? Very well done Sir.
Dave
Old Nov 19, 2021 | 03:19 PM
  #6227
doorgunner's Avatar
doorgunner
Dave
probably in the corner of my room fighting off the PTSD and flashbacks.
thanks for the compliment. The forum members taught me everything!
Old Nov 19, 2021 | 07:16 PM
  #6228
doorgunner's Avatar
doorgunner
Step #12......?I'll let it cure and sand the inner edges smooth tomorrow......
Old Nov 20, 2021 | 12:54 PM
  #6229
doorgunner's Avatar
doorgunner
Before......
After.....
Cured & Sanded....still need to do a better job on shift cable exit hole,
Clean up sanding dust & install new Reflectix on tunnel....I need to rework out of place shifter cable exit hole.
Old Nov 21, 2021 | 09:46 AM
  #6230
Pegan2261's Avatar
Pegan2261
Originally Posted by doorgunner
before......
after.....
Cured & sanded....still need to do a better job on shift cable exit hole,
clean up sanding dust & install new reflectix on tunnel....i need to rework out of place shifter cable exit hole.
wow, nice work!
Old Nov 21, 2021 | 12:36 PM
  #6231
doorgunner's Avatar
doorgunner
teamwork !!
I MAY be scoring a forward Sprag Assembly for my 4L60E I am rebuilding to replace my TH400....
the THAT 400 will fit on the coffee table in the Cave/Vette garage
Old Nov 21, 2021 | 02:22 PM
  #6232
Giddy-up Go's Avatar
Giddy-up Go
teamwork !!
Not the coffee table in the house?
Old Nov 22, 2021 | 12:12 AM
  #6233
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
teamwork !!
Are you also going to add an engine to that coffee table so it'll move around the cave/garage under it's own power??
Old Nov 22, 2021 | 01:23 AM
  #6234
doorgunner's Avatar
doorgunner
pics...or it's not going to happen.
Why, Yes...until the 4L60Elite is ready to bolt up.
Old Nov 22, 2021 | 07:12 AM
  #6235
Tom69's Avatar
Tom69
2018 C3 of Year Finalist
Before......
Dang...that's pretty, I wouldn't cover that up!
Old Nov 22, 2021 | 11:16 AM
  #6236
doorgunner's Avatar
doorgunner
Thanks T.......the new Reflectix will make it nice and shiny/block engine heat/muffle engine-transfer noise
Back to the garage in a few minutes. I had to repair driver-side rusted kick-up where it is welded to horizontal frame....
1/2 of the weld has rusted away.
I may even weld anot upgrade brace from the inner part of the crossmember to the driver kick up for more support...I should have done it when body was lifted 8" for body mount replacement spacers.
Old Nov 22, 2021 | 08:09 PM
  #6237
doorgunner's Avatar
doorgunner
I made a sloppy but sturdy repair where the frame meets the kickup.....I'll repair the hole in the kick up near the T/A pivot bolt and straighten out the sloppy weld when I feel better. The T/A support also needs a patch where I drove screwdriver through to check for a rust sandwich.....I used .200" thick mild steel flatware for strength.......
To Doorgunner's '68 Convertible Project
Old Nov 22, 2021 | 08:19 PM
  #6238
caskiguy's Avatar
caskiguy
You need about a 5/16" to 3/8" weep hole in the bottom left corner correct ?
Looking good.
Btw, Happy Thanksgiving DG !
Old Nov 22, 2021 | 08:54 PM
  #6239
doorgunner's Avatar
doorgunner
Looking good.
Happy Thanksgiving to you! (It's still a rough time of year for us missing Blake)
I'm thinking about a 7/16" hole since it's a restomod/I also deleted the 3/8" frame extension that normally goes past the vertical insert that receives the drain hole.....
the original drain hole on the passenger side had an inch of mud-clay blocking it closed.
Old Nov 22, 2021 | 10:23 PM
  #6240
Vibguy's Avatar
Vibguy
Please explain the weep/drain hole idea. I think I sealed up my floor like a drum. Is that bad?
