Doorgunner's '68 Convertible Project
Old Apr 9, 2015 | 12:09 AM
  #1361
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by Brack c
That little Blaster is a neat little thing to have around . i have one like it ( plus a medium size cabinet *not hooked up yet * ) But im lucky enough to have a nice blasting cabinet at work that i use all the time , cleaning things during lunch .
Looking good DG , I finally jumped back into mine with both feet . Results / pics soon ....I cant believe i stopped working on it for so long ....Keep on , Keepin' on
Will do........that hour/minimum a day Rule works! I only spent an hour on the door to find out the lock failed.....
but that's better than completely assembling the door and the panel...then having to take it apart in a few days when the lock causes me to twist the key off trying to turn a jammed tumbler.
Old Apr 9, 2015 | 12:17 AM
  #1362
Zoomin's Avatar
Zoomin
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Been there, done that.
Just remember - if any thing is done right it's going to take a few attempts. At least that's my rule of thumb.
Old Apr 9, 2015 | 01:01 AM
  #1363
doorgunner's Avatar
doorgunner
AAAAAAAHAAA!
RIGHT is official after the 3rd-4th attempt!
That takes a LOT of pressure off me.
"I got it!"
Old Apr 10, 2015 | 12:42 AM
  #1364
doorgunner's Avatar
doorgunner
RVZIO! I GOT THE BOX OF STUFF YOU SENT!
Now I can make the grill area actually look like a '68 grill........
THANKS TO MEMBER WESCH FOR THE 2006 WRITE-UP AND HOW-TO PICS ON MY LAPTOP SCREEN!
I also picked up the new lock assembly....the new tumbler is on the left/the old disassembled tumbler is on the right----I will have to grind the male end off the new tumbler/dremel the female end off the old tumbler and solder it onto the new tumbler/sounds like lots of fun.......
A perfect fit inside the pushbutton sleeve (I won't re-crimped the sleeve onto the lock until I modify the end of the tumbler) ...I had it re-keyed to match the driver's door lock while I was at the locksmith....
69000
Old Apr 10, 2015 | 12:15 PM
  #1365
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Gunner, you need a C3 cover?
Old Apr 10, 2015 | 07:16 PM
  #1366
doorgunner's Avatar
doorgunner
Sure do.....pollen.....construction nearby....dust everywhere (sneeze!)
Old Apr 10, 2015 | 07:40 PM
  #1367
Calo69's Avatar
Calo69
I've got an extra one, brand new,still in box( late nite online, hit buy button twice) if you p.m. Your address to me it's yours, my contribution to your project
Old Apr 10, 2015 | 08:30 PM
  #1368
doorgunner's Avatar
doorgunner
NO DEAL................UNLESS I CAN PAY FOR SHIPPING!
While you're here.....wanna' see some Extreme Bubba?
The new '74 GM tumbler on the right with the male stub ground off/the original crumbling tumbler on the left with the female extension cut off..................................
The best JB Weld that money can buy..........................
The original female end is attached to the new '74 tumbler...........
I need to let the JB Weld cure for 24 hours.....then I can press the extension into the modified tumbler.....................
Tomorrow I will drill two .030 diameter holes 180* apart into the newly attached female end and press roll pins into the drilled holes for extra strength
Old Apr 10, 2015 | 08:39 PM
  #1369
Calo69's Avatar
Calo69
How about you make a donation to charity of your choice in amount of shipping cost?
Old Apr 10, 2015 | 09:05 PM
  #1370
doorgunner's Avatar
doorgunner
St. Jude Children's Hospital!
Old Apr 10, 2015 | 09:53 PM
  #1371
Calo69's Avatar
Calo69
Great, p.m. Me info to send.
That JB will hold on a connection like that?
Old Apr 10, 2015 | 10:23 PM
  #1372
doorgunner's Avatar
doorgunner
I cleaned it and cut some 1/32" deep grooves across the surfaces of the mating parts before adding the epoxy. The two pressed-in roll pins will eliminate any stress when turning the key (a well cared-for lock only needs fingertip pressure to turn the key)
(I repaired a 2" diameter hole in the lower case of a motorcycle saving $500 over buying a new case.....the oil drain plug was in the center of the repair...removing/re-installing the drain plug showed me how strong the JB Weld was...and NO leaks!)
Now..................the stuff won't hold a June bug down without the correct preparation.
Old Apr 11, 2015 | 12:31 AM
  #1373
Calo69's Avatar
Calo69
Thought you might need some kind of scratch coat on surfaces to help, but I don't know anything about Junebugs. Good luck
Old Apr 11, 2015 | 10:26 AM
  #1374
doorgunner's Avatar
doorgunner
The lock epoxy still needs a few more hours of curing-time, so I'm going to straighten the garage up......AGAIN.....so I can actually see/walk around the car!
Then I need to put it on jackstands to install the new driven gear in the transmission and connect the new speedometer cable. The odometer worked well with the new cable after I installed the new odometer gear-shaft and spun it with an electric drill.
Out to the garage!
Old Apr 11, 2015 | 10:41 AM
  #1375
MrJlr's Avatar
MrJlr
I REALLY love that you are taking a bastardized 68 and making her a 68 again.
Hats off to you!
Old Apr 11, 2015 | 10:52 AM
  #1376
doorgunner's Avatar
doorgunner
Hats off to you!
"It takes one.........................to make one!"
(God is working on me....I'm working on the car....hopefully we'll both be completed around the same time!)
Old Apr 11, 2015 | 08:00 PM
  #1377
loup68's Avatar
loup68
Army
Door gunner, I thought that I should inform you that Roger's brackets are for 69's. They are much sturdier and more reasonably priced, than the flimsy and very expensive 68 reproduction ones. Lou.
To Doorgunner's '68 Convertible Project
Old Apr 11, 2015 | 10:30 PM
  #1378
doorgunner's Avatar
doorgunner
Lou.............................."We rookies need all the help we can get!"
I worked on the lock more today between errands....the 1st roll pin is pressed in.....
It is cut flush with the tumbler.................
The hole is drilled for the 2nd roll pin across from the first one........
The 2nd roll pin is pressed in and cut off flush also............
The assembled lock is pressed into the stainless pushbutton and crimped together (I had to use the new dust cover/the original dust cover door would not close when installed into the new tumbler).....OOOOPS---this pic was taken before the new dustcover door was installed and before the lower end of the case was re-crimped onto the tumbler........
The pushbutton assembly is installed into the housing (I probably have the arm installed on the wrong side of the housing/I'll find a pic on the forum or maybe the AIM)...................
Tomorrow the assembly will go into the door and the door panel will finally be installed
Old Apr 11, 2015 | 10:54 PM
  #1379
chazde3's Avatar
chazde3
Good looking lock you have there dg.
Old Apr 11, 2015 | 11:05 PM
  #1380
doorgunner's Avatar
doorgunner
Thanks.....it took a while and I was nervous about modifying a lock (as usual) but now I have matching locks that are in nearly new condition (if I run across a decent '68 passenger lock I will buy it).
Now I will be able to park the car in public places since the new alarm is also working......(I previously never let it out of my sight-even with the ugly flaking paint- when I drove it into town)
