Priya's 79 chrome bumper conversion project
Due to the downward sloping angle of the rear decks, using more of the 70-73 ACI rear clip not only lengthens the rear end of the finished car, it lowers the position of the ACI rear clip relative to the rear of the 79. This creates a couple of, in my opinion, unacceptable alignment problems with the join between the rear quarter panels of the 70-73 ACI rear clip and the 79 rear quarter panels.
On C3 Corvettes there is a horizontal character line at about the mid point of the quarter panel - "B" in the picture below on the 70-73 ACI rear clip and "C" on the 79. On the 68-73 rear quarter panels this character line is parallel to the ground. On the 78-82 cars (and perhaps the 74-77 ones?) that character line is not parallel to the ground but rather slopes upward slightly towards the rear of the car. When grafting on a 68-73 rear clip you need to blend these character lines together (so I think it best to use as much of the donor rear clip's quarter panels as possible) . In order to do that best the angle of character line "B" on the 70-73 rear clip needs to intersect the character line "C" on the 79 quarter panel at point "D". As you can see in the picture with the 70-73 ACI rear clip cut at the 8 & 1/4 inch mark (point "A") the position of the donor tail light area is lowered and the 70-73 "B" character line angle is too low to intersect the 79's "C" character line at point "D".
Similarly, with the lower position of the 70-73 ACI rear clip due to its increased length at point "A", the bottom of the 70-73 ACI quarter panel (point "E") does not line up with the bottom of the 79 quarter panel (point "F"). So, it appears to me at this time that I need to shorten the rear deck of the 70-73 ACI rear clip at point "A" to six inches to raise the entire 70-73 ACI rear clip relative to the back of the 79 even though this means the upper quarter panel width on the two rears won't match.
I'm feeling really fortunate I realized this before I proceeded with the longer ACI rear clip even though this is going to be a great deal more work than I anticipated. All the same I may cut the 70-73 ACI donor clip at the 7 inch mark and mock it up again to check once more rather than immediately cutting it at the 6 inch mark.
Just a thought,
When we were doing R&D we often used the blue foam boards to mock up the changes and parts.
If I was unsure of the final look I wanted or the transition points I would trace the side profile on to the foam - you can cut it with an old electric kitchen turkey carving type knife or a hack saw blade ( blade makes a mess with little ball type dust , keep a shop vac handy). Fine tune the shape with sand paper 60 or 80 grit.
It's light and easy to shape. Home Depot has it, broken sheets are often vastly reduced.
Depending on the brand of the foam, Gorilla Glue, West System's epoxy etc will glue it together if you need thicker sections. Polyester resin eats it.
You can lay West Systems with cloth on it to make a mold and then cut the foam out. (West System's has a great website for their products and uses)
This may help give you the final look you desire, then trace that and make the cuts...
If anything I can add Priya. Is to get the rear clip where YOU want it and where it looks great to you. DO NOT worry about panels feature lines and all that...becasue THAT can be dealt with. And trying to keep your laminating to a minimum and that causes you to settle for a 'look' that just does not get you excited...then you are doing yourself an injustice.
Regardless if you have to laminate one inch seams or 5 inch seams....to me ...it is not that big of a deal when all that matters is the end result is what it NEEDS to be.
Making cuts in some areas a can relax the panels and allow them to be moved to lessen an off set panel. I have to do it quite often on new aftermarket hand laid parts.
DUB
You can do as you wish...
BUT I do not laminate in the seam that you began to prep for filling. I simply apply some of the VPA and that is all. No need to waste the time or material in applying fiberglas resin and mat...but like I wrote...do as you wish.
You already know how stout the VPA is.
****EDIT****
I grind the adhesive down a bit...I widen the seam so when I am grinding I am going further out past the lines of where the panels are. SO..I basically prep the seam all the way to the top of the main body line at the top of the quarter panel and fender....tapering it as I go up and down. Then I will go down below the seam about 2 inches or so. I dish out the seams where the facotry glue was..and taper it further out to like where I just stated. I do not grind all the way down and find the bonding strip...no need for that. You want to go down at least 1/8"+ at the deepest point
What this does is allows a smooth gradual dish so when I go in with the VPA I have no sharp edges that I have to try to fill in. And because I am applying the VPA all the way to the top and below the actual area where the seam was....when I am done blocking the seam...the VPA can easily be 4 inches wide. And due to I dished out the factory adhesive...there will be no way for the factory seam to ever show up.
DUB
To make the resin easier to work with I thinned it with acetone which may have not been the solution to the extra thick resin. Although I wiped off the runs when I left the garage more runs appeared later on - what a mess! Also, as shown in the picture below it looks as though enough resin ran out of the mat so that it is insufficiently saturated near the top of the fiberglass work.
Hopefully tomorrow its hard enough to sand.
Anyone out there have experience with the West System that could comment on your tribulations?
Keep up the inspiration for all of us.
Txs
Dennis (Bman)
That West Systems epoxy sure is hard to work with.
IF your resin/hardener are cold...you should not use it due it it will be thick as all get out.
Set the can in the sun to warm it up and you will find the viscosity will change A LOT and be much thinner.
Hopefully you contacted West Systems and they said it was OK to thin it with acetone. You are dealing with an epoxy resin and not a polyester...which the acetone could effect it can cause it not never harden fully and have to be all done over again.
I will keep the rest of my thoughts/comments to myself.
DUB
I don't like using a heat gun to speed it up , I think its better to let it go naturally, my point is I really hope yours does go off , but your going to have to grind at least that top part back !
No big deal , these cars are 3 steps forward and 2 back all the time
Last edited by bazza77; Mar 23, 2017 at 07:46 PM. Reason: was it 3 forward and 2 back or 2 forward and 3 back ?
RVZIO
It's fun to follow your build and see your challenges and accomplishments. Keep up the great work - can't wait to see it finished.
