New crate engine is now a steam engine....bad problem...
Old Mar 29, 2006 | 12:48 AM
  #1141
MsVetteMan's Avatar
MsVetteMan
  #1142
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Originally Posted by MsVetteMan
.....it's springtime here, and I got a bass boat with a 150 on the back, that will outrun my vette that's in the garage.
...would that be on water or on land???
***sorry, couldn't help myself.
Old Mar 29, 2006 | 12:51 AM
  #1143
MsVetteMan's Avatar
MsVetteMan
Dat would be the point.........on land...........
Old Mar 29, 2006 | 12:53 AM
  #1144
GDaina's Avatar
GDaina
I think it would be wise to keep quiet AND NOT aggravate the vendor. The more you speak, the deeper you dig your hole.
Let the vendor first examine the engine, let them tell you what the resolution will be...then and only then get excited one way or the other. In the meantime...SHHHHHHHHHHHHHHHHHHHHHH.....
Old Mar 29, 2006 | 12:58 AM
  #1145
MsVetteMan's Avatar
MsVetteMan
Originally Posted by GDaina
I think it would be wise to keep quiet, not to aggravate the vendor. The more you speak, the deeper you dig your hole.
Was doing good at that until the email surfaced. I guess it was to even things up. lol. I'm cool......expect to get screwed, and will move on.
Hey, y'all want to see pics' of the family while we waste some time?
Here's little Johnny..........aint he cute.........
Old Mar 29, 2006 | 07:46 AM
  #1146
jim2527's Avatar
jim2527
Normaly I dont drive my vette to work during the week. But..............today, I going too....in your honor.
We should have a 'drive your vette on sunny spring day' day in your honor.....
Old Mar 29, 2006 | 07:58 AM
  #1147
tonyd21266's Avatar
tonyd21266
Trouble in Paradise. Think I either blew a head gasket, or have a cracked head. Cranked her this morning and backed out into the driveway to let her warm up and check all the fluids. Noticed water coming from under the car, looked and water was spraying out of the right side header!! Immediately cut her off and checked the oil.....milky, really milky. Dayum......I (we) followed the instructions to a tee, and the motor never got over 200*. Never lost oil pressure, and still show very good oil pressure. Motor will crank easy, but has a little rougher idle. Only drove her a 1/2 mile yesterday.
Gotta call blueprint engines in the morning........dayum........
I sure hope it's just a gasket. What a bummer.
Should I drain the oil and water, retorque the heads, and try again? Any chance the head just got loose? Or do I definetely need to pull the head?
Man crate engines are crap!!!!!!!!
They are targetmasters made in Mexico
Let me tell you why yours was a hunk of crap and did what it did
the gasket faces on the heads are thin as crap pair that up with the engine block where the deck is almost half as thin as a hi nickle unit. must i not mention the steel gasket
Old Mar 29, 2006 | 08:23 AM
  #1148
mandm1200's Avatar
mandm1200
Another week or two of this and there should be enough material here to make a movie. I wounder who MSVetteMan will choose to play his role?
Old Mar 29, 2006 | 08:26 AM
  #1149
tonyd21266's Avatar
tonyd21266
Originally Posted by jotto
OUCH! I wouldnt do anything until you have called the engine company...if you followed all instructions then surely its covered by a warranty? If you start pulling parts they might turn around and say yah booh sucks, you pulled head etc, you voided warranty...no disrespect meant to engine company but here in Uk, if they can squirm...they will.
GOOD LUCK!
I do auto machining and engine building
we do not guarraty any speed engines as they are usually tortured.
most of these engines are crap that was thrown together for a quick overhaul meaning new ring and bearings and if something is totally shot
also they do not balance this condition either if a new piston is thrown in
now you give them the engine they will swear to go you did it god luck if you follow this advise
Do your self a favor and go find a hi nickle core at a core yard and get it tanked bored and new new cam bearings and freeze plugs dont be talked into doing decking unlees your app calls for it or the block is untrue more then .002 crass laterally
get the crank cut and get a kit from engine kits.com balance the pistons your self on a gram scale and you can get away with doing the rods but not side to side but that is over rated unless you are going all out
the crank should be done on a hines machine
here is a counterweight trick
keep your old pistons to so you can match them to your old if you are talking less then 20 grams then you dont need to balance the crank
also if the pistons are a lot lighter or heavier
you will see drill marks maybe 3 on every counterweight in the engine
the trick is to weigh your old pistons if you are heavier drill those hole out and keep count of the metal on a scale to you reach the weight of the old pistons if you are light use an epoxy like marine tex and a little lead and gue in the holes to match the piston weight difference
not that hard
tools
torque wrench
balancer puller
gear puller
feeler gauge
plastigage
valve spring tool
all this crap will cost a bean a bean 50 or barrow it from a friend
tank the heads and get a 3 angle valve job and get new valve liners
use your old springs if the cam isnt out of site and add .030 shims see blow or get new one if using a cam bigger then .480 see below for specs
now the trick i reveal go buy how to rebuild you small block chevy or how to hot rod it
with the price of the book, machining and an engine kit a sb should cost you less then 800 let them balance and add 300
if you want with the 1000 you save buy a set of used performance heads off ebay and get the valves done less then 500 and put the other 500 on a hundred to one horse.....
get the point
Old Mar 29, 2006 | 08:58 AM
  #1150
Als70sschevelle's Avatar
Als70sschevelle
3rd Gear
Default Good luck I am with you.
I am also from the Chevelle list. I am with you and I am also following along. I am hopping for the best for you. I feel the builder should stand up after finding out that it was not your fault. Good luck MVM
Old Mar 29, 2006 | 09:26 AM
  #1151
mpett1's Avatar
mpett1
2.)
Just like Wal-Mart if you want to return something you have to return
the product to where you purchased it from before anything can happen. This
has not happened as of yet.
plant
and see what we do. We have nothing to hide.
Keith Kirk
Product Manager
http://www.cardomain.com/ride/635955
I wouldnt compare Wal-Mart ( A muli billion dollor company ) To his company and I would be at all negitive with custormers. Were did this guy learn is customer service skills at..
Old Mar 29, 2006 | 09:53 AM
  #1152
bashcraft's Avatar
bashcraft
not that hard
tools
torque wrench
balancer puller
gear puller
feeler gauge
plastigage
valve spring tool
get the point
No, I don't get the point. If this is the way you rebuild engines, I can see why you don't guarantee them.
Plastigage? If you can't get your hands on a set of micrometers, you shouldn't be touching the inside of an engine.
Old Mar 29, 2006 | 09:58 AM
  #1153
MsVetteMan's Avatar
MsVetteMan
Old Mar 29, 2006 | 10:08 AM
  #1154
stinger7474's Avatar
stinger7474
1st Gear
Default ?
I don't think they were unfair until now. I wouldn't give someone their money back for something that for all I know might not even be broke. As far as the email I received, dude sounds p1$$ed. I myself am amazed at how far this thread has reached. My brother in law sent me an email yesterday telling me where to find this thread. And we don't even visit the same sites.
Old Mar 29, 2006 | 10:13 AM
  #1155
MsVetteMan's Avatar
MsVetteMan
WTF? Motor rerouted.......yesterday afternoon in was in NE. Now it's being routed back to Mo.?? They may just be sending it back to me. lol...........dump it back in my lap.......lol.....naw........
Pro Number: I692864991
Web Pro #:
Pro #:
Pickup Date: 03/23/06
Origin: CANTON, MS
Destination: KEARNEY, NE
Pieces: 1
Weight: 535
Status: IN ROUTE TO KANSAS CITY, MO ESTIMATED DELIVERY DATE 03/29/06
Old Mar 29, 2006 | 10:14 AM
  #1156
rihwoods's Avatar
rihwoods
Keep cool....
Old Mar 29, 2006 | 10:17 AM
  #1157
GDaina's Avatar
GDaina
Plastigages will give you ballpark numbers. Don't be so quick to jump on this guy, he's only giving sound advice to a newb engine assembler. If you've read the entire thread, this is his first attempt at assembling.
Regarding mikes, most home users don't own a set of mikes and can't justify the cost for a one shot deal.
If you venture into this guy's shop, how much you want to wager you will see the mikes in use?
To New crate engine is now a steam engine....bad problem...
  #1158
MsVetteMan's Avatar
MsVetteMan
You have no idea how I am.
Old Mar 29, 2006 | 10:25 AM
  #1159
MsVetteMan's Avatar
MsVetteMan
Does anyone know if Norris Marshall (owner and founder of Marshall/Blueprint Engines) is still involved with the company day to day?
I have fowarded a couple of emails straight to Marshall and requested they be given to him. Surley the he is aware of this? Maybe not, but if I worked for him, he would be.
Wonder if he is an old hard **** that would kick me in -----? Or, is he a man that has called the "boys" on the carpet over this? Tick, tick, tick....
Old Mar 29, 2006 | 10:31 AM
  #1160
68sbShark's Avatar
68sbShark
Web Pro #:
Pro #:
Origin: CANTON, MS
Pieces: 1
Weight: 535
You think they refused delivery???
I give you credit for keeping your cool (until that email surfaced, at least). And I agree that you have made no negative comments towards the builder. Other people may have, though . I hope that this can be resolved with both parties being satisfied with the outcome. You get a new stroker, Blueprint gets a crapload of good PR. Everyone is happy.
~Rich
