Corvette V12?
Old Feb 7, 2018 | 11:03 AM
  #261
PainfullySlow's Avatar
PainfullySlow
Man I LOVE reading this thread. Richard you really have an incredible vision as well as the skills to make it a reality. Tip o' the hat to ye, sir!
Old Feb 7, 2018 | 01:06 PM
  #262
Richard454's Avatar
Richard454
Originally Posted by 69ttop502
Richard, what symptom caused you to change the master bore?
Bill
Hey Bill-
HA- reading the owners manual would have been my first clue!!!
Actually I saw an episode of "Roadkill" and they upped the calipers to 6 pistonon an ElCamino- with the stock size bore MC they couldn't get enough braking out of it. I had an "Aha" moment- pulled out the Owner's manual - and that's what they (Wilwood) recommended!!! Anyway- glad I had not filled the system- so I now have a slightly used - never had fluid Wilwood 1" MC.
Thank-you SIR!!!
HA- I actually have double vision from my accident years ago!!!
I enjoy looking over your build as well-
Richard
Old Feb 7, 2018 | 01:42 PM
  #263
69ttop502's Avatar
69ttop502
Interesting Richard. I will be running the D8-6, D8-4 combo on mine in a manual brake configuration. But the piston area is the same as stock, so I wonder if I still should use a 1 inch bore master. I will check with them, and if 1 inch is recommended, I will buy your 1 inch if you are interested in selling it.
Bill
Old Feb 7, 2018 | 02:41 PM
  #264
calwldlife's Avatar
calwldlife
St. Jude Donor '22
glad you are back.
been very interested in your build.
i could never do what you have done!
Old Feb 10, 2018 | 05:04 PM
  #265
dmaxx3500's Avatar
dmaxx3500
WOW-- great work
Old Feb 11, 2018 | 08:47 AM
  #266
CPTCroaker's Avatar
CPTCroaker
Depending on my orders and report date I am hoping to make power tour as well. Look forward to checking your car out
Old Feb 11, 2018 | 02:12 PM
  #267
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
Amazing work as always. thanks for the updates.
Old Feb 17, 2018 | 03:32 PM
  #268
Moto One's Avatar
Moto One
Ok, so I was looking for info on Vac system C3 (seems I have inherited one) and came across this (2hr read), Richard I'll say Im impressed with the skill and time invested.
Mark.
Old Feb 18, 2018 | 12:03 AM
  #269
Richard454's Avatar
Richard454
Bill
Hey Bill-
Shoot me a email richard454 at comcast dot net. $100 plus shipping it's yours- no box- but have the bleed kit and I have the adapters for the Wilwood to stock OEM brake lines to the proportioning valve. Just need the two fill plugs and the washers (Part#240-8602 $1.99 at Summit)
Originally Posted by calwldlife
glad you are back.
Thank you!!!
Originally Posted by dmaxx3500
WOW-- great work
Thanks!!
Hey Jim-
That would be great to put a name to a face. Met a lot of forum members on the HRPT
Hey Brent-
Hope you guys are doing alright.
Mark.
Thanks Mark!!!
OK-
One big step forward. I have the cooling system all worked out.
Installed the new Dewitts radiator-connected up all the hoses and after several issues- I now have a system that holds over 10PSI for over 30 minutes!!!
I used the steam port to connect the gauge and the port on the upper radiator hose ran pressure, Ran it up to 20PSI and heard the Radiator Cap squealing- then dropped it down to 10-12PSI and let it sit, Sprayed every connection down with soapy water and no bubbles!!!
I did order a 1 3/4" SS 45º exhaust pipe piece-to fit between the upper half and lower half of the lower hose-as I'll use that to route the lower radiator hose at a better angle. Right now it's a little too close to the serp tensioner.
Here's the new bracket mounted- no side to side play at all!!!
Redneck pressure checker..... a black zip tie would look better...
How the pressure is controlled- Trusty old vicegrips
I pulled the 1" master cylinder to replace with the 7/8" and decided I would tackle the small drip I'm getting out of the clutch master cylinder. I check how tight... don't think I can tighten it any more...looks like I've been there done that. A quick Google search- and I'm not the only one with a problem- After looking around I find the best solution is to run a Breeze B9224-0356 Spring-Loaded T-Bolt Clamp.
So next is the oil system- put the pan back on- hook up the new dry sump lines-and check for leaks.
A little bit of wiring to finish up- connect the O2 sensor- and it should be start up time Part Deux!!!
Old Feb 18, 2018 | 02:05 AM
  #270
bowtie racing's Avatar
bowtie racing
Amazing fabrication and innovations. Thank you for sharing all this
Old Mar 6, 2018 | 08:03 PM
  #271
Richard454's Avatar
Richard454
Thank you!!!
OK- I finally started drilling up my SS sidepipes.
I read where drilling stainless requires more pressure and just keep it cool.
I found the best size and bit to start the hole- was 3/32 Dewalt split point cobalt. After drilling over 50 holes for one sidepipe- only used 3 bits!!! I had like 10 on hand - just in case!!!
So after years of messing with this idea- sidepipes from loud to quiet that will fit under the OEM covers and be able to flow 2 ½" straight pipe- I finally have a finished piece. Looks like it will work- hope to try them out next week.
I have 24 3/8" hole- has the same area as a 1.75" pipe- so some restriction going into the muffler- which is fine.
2½" pipe inside the muffler-
O2 sensor bung
Finished piece-everything band clamps together.
Cut-out motor will be mounted remotely- as there is no place thanks to the frame. I will use a 1/4 drive 90º piece - have the 1/4 flex in the pic
OPEN- loud 2½' straight pipe
CLOSED (and can vary in-between) exhaust will flow through the front perfs through the muffler and exit out the rear perfs. Theoretically the 2½" closed pipe will work as a hemholts resonator....
Old Mar 7, 2018 | 12:21 PM
  #272
Denpo's Avatar
Denpo
I love that side pipe idea. I'm really curious how they perform in term of power restriction and sound muffling. I'm actually contemplating the same procedure since lowering my floorpan won't leave any space (6'6" gotta 6'6") for the exhaust.
Old Mar 7, 2018 | 12:31 PM
  #273
Big2Bird's Avatar
Big2Bird
Denis. You still haven't finished that car?
Old Mar 7, 2018 | 01:13 PM
  #274
Denpo's Avatar
Denpo
Almost, until the SBC ate itself up on the first test drive. Decided to take a break and move on with my backup LS engine. Break is coming to an end (home renovations mostly), will resume the madness in a couple months.
(Sorry Richard for the thread squatting).
Old Mar 7, 2018 | 10:21 PM
  #275
Richard454's Avatar
Richard454
Your welcome to squat!!! Especially since we are both nearing a decade in our builds!!!
I'm thinking the straight pipes will not hurt the power- and the slight muffler effect of the perfs when wide open will knock a little bit of sound off.
As far as dropping the level down- If the pipe is half open -It still should flow as good as 2½" pipes. The area in the 4" pipe minus the 2½" pipe is about same.
IF it's not as quiet as I want- I can still add some exhaust packing the last 6 or so inches of the pipe. From what I have read- the glaspac type muffler I used doesn't really have much attenuation after 20" or so-and that's what I went with.
The big benefit will be less heat- as I am shielding it and using different layers of wrap.
Here's what's going around the muffler under the covers-
Here's how I am going to actuate the cut-outs- just use a flex coupler so I can tuck the motor underneath the car as the frame is in the way.
The pipe turn out lines up pretty well with the covers-
In a few minutes I can pull the pipes off - all connected with v-bands.
Old Mar 7, 2018 | 10:46 PM
  #276
caskiguy's Avatar
caskiguy
Amazing. Thanks for the education.
Old Mar 8, 2018 | 11:52 PM
  #277
Richard454's Avatar
Richard454
Just stuff I read on the internet....
Oh- forgot to mention the Federal Mogul Thermflex socks that I will put on the pipes next to the frame.
Supposedly used by big trucks around the turbo pipe-made out of baltic yarn .... supposedly work really well...
I got a set off eBay surplus -seconds cheap- they were the right size-
so I will try it out.
To Corvette V12?
Old Mar 10, 2018 | 10:24 PM
  #278
Richard454's Avatar
Richard454
Worked on getting my Flaming River Manual Steering rack in today.
I was anxiously awaiting the Fedex -delivery guy looked at me funny because I know I looked like a little kid at Christmas when I met him at the door!!!
Less than 10 minutes out of the box-
I was cutting of the cradle- milling down the aluminum mount to make it fit.
Success!!!!
Cut the cradle- I will weld some flat steel to strengthen it back up
Milled down the aluminum about 3/8"
Clearance -Clarence!!!
A simple AN fitting was all it took to make the Dry sump line go around the rack and pinion-
Way toooooo big to fit- I figured a large sway bar fitting would work-
I found one- should work great and give me the clearance- and looks to be a little more substantial than the original mount.
Old Mar 26, 2018 | 11:21 PM
  #279
Richard454's Avatar
Richard454
Some progress-
I'm helicoiling the block for the oil pan- all 40 of them! After pulling the pan off and on several times- I didn't want to strip any more out- after a few got buggered up.Cheap insurance to do it now.
Pan is ready to go- had some stuff beefed up on it- a couple spots looked sketchy.
Windage tray going on
Stainless steel hardware-
Bolt on the pan- connect the oil lines and put some oil in it!!!!
Here's where I am on the electric power steering-
A little- OK a lot of redoing on the column to mount the motor.
Shortened the column a little more- motor is closer to the firewall.
I went with a Speedway motor's column clamp- looks like it will work perfect.
As far as the steering shaft to the Flaming river rack?
The kit uses a convoluted bunch of u joints- supports and set screws.
I'm going with the factory Nissan intermediate shaft- factory splines- factory U-joints and it is adjustable length by design.
At the end of the factory u-joint-a 3/4" DD shaft fits perfect- which will be welded on a 3/4 to 9/16-26 as on the rack. So no set screws- either splined or bolted and notched w/ a bolt.
Here's the column slid together-
Wires for the wiper fit fine
Old Mar 27, 2018 | 07:24 AM
  #280
caskiguy's Avatar
caskiguy
Amazing. Nice work.
